Go to Post I find it quite amazing that this thread has been continuously active for more than two years. - Stephanie [more]
Unread 01-11-2006, 08:44 PM
Xufer's Avatar
Xufer Xufer is offline
8 Seasons and as stable as ever
AKA: Working, 2/4 degrees complete still schooling...
FRC #1740 (The Cyber Colonels)
Xufer is a splendid one to beholdXufer is a splendid one to beholdXufer is a splendid one to beholdXufer is a splendid one to beholdXufer is a splendid one to beholdXufer is a splendid one to behold
Send a message via AIM to Xufer Send a message via MSN to Xufer Send a message via Yahoo to Xufer
Lightbulb Dewalts Used Last year
This year a few mentors and alumni from Team 521 Broke off and started a New team a few towns over.
Our machining capabilities are fairly limited and we are looking for a simple way Change gear ratios. The Nothing but Dewalts paper looks promising and we spoke of using them last year, but in the end decided against it. What i am wondering is how they faired in competition last year? I know many teams used them last year if you could explain any problems you had with construction or in competition that would be great.
Also has anyone thought about putting the new minibike cim into a dewalt deill transmission? If so was it successful?
Thanks a lot!
-The members of team 1470
If saftey is first and i put FIRST ahead of everything, then i must be the safest guy in the world.
Team 521 Alumni -- Team 1740 Mentor-- Go Go 1740!
Sometimes I think I've been doing this too long and other times I think I haven't done this enough... but all the times I'm sure I'm crazy
Photonics, It's Your Future
Unread 01-11-2006, 09:37 PM
Jeff Pahl's Avatar
Jeff Pahl Jeff Pahl is offline
likes to look at shiny things...
FRC #5148 (New Berlin Blitz)
Jeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond repute
Re: Dewalts Used Last year
We used two of them last year, with the CIM motors. They were rock solid and are still working great after several months of demos and student "practice" with the robot. I highly recommend them!! The plate that goes between the yellow drill housing and the CIM to mount the whole thing is very easy to machine, you can get by with a drill press and a bandsaw as long as you lay the holes out accurately. However, machining the press-fit hole for the motor shaft in the existing Dewalt gear is not something to try with limited machining capabilities. Just plan on sending them out to be EDM cut.
We never did set them up to shift, the drivers seem to like them in 2nd so we just leave them there.
Unread 01-11-2006, 09:51 PM
Xufer's Avatar
I mostly worried about the servo shifting. That seems like a possible week point in the design.
A few years back i remember a team (i belive 177 bobcat robotics, i may be wrong) taking the drill motor housings and adapting the fischerprice motors to them. I belive they had a problem with the drills getting caught between 1st and 2nd.
Thank you.
Unread 01-11-2006, 10:23 PM
Richard Wallace's Avatar
I live for the details.
FRC #3620 (Average Joes)
931 built two NBD units with FP motors last year. One raised (rotated) the outboard section of our arm via a 2-stage sprocket system. The other was a spare.
We never needed the spare.
Richard Wallace
since 2003
Unread 01-11-2006, 10:40 PM
Stu Bloom's Avatar
Stu Bloom Stu Bloom is offline
I REALLY want to be Andy Baker
FRC #1018 (RoboDevils)
Stu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond repute
Send a message via AIM to Stu Bloom Send a message via Yahoo to Stu Bloom
We used them last year and will definitely be using them again this year (for drivetrain, with CIM motors). Tremendously robust and relatively light weight WITH shift-on-the-fly capability.
I was also concerned about the servos being strong enough to shift these transmissions, but if you remove the detent clip under the shifting ring they work just fine.
Good Luck!!
Stuart Bloom
Mechanical Engineer
Rolls-Royce Corporation
FIRST Team 1018 - Pike HS RoboDevils
My activity for 2012:
  • Boilermaker planning committee
  • Israel Head Ref - DONE (and it was FANTASTIC!)
  • Boilermaker Regional (with 1018) - DONE
  • Midwest Head Ref - DONE
  • WORLD Championships (with 1018) - DONE
  • IRI Head Ref - DONE
  • CAGE Match Head Ref
Unread 01-11-2006, 11:11 PM
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
I can say with confidence that these transmissions are FIRST-friendly.
We have just plain never had a failure.
I know of about 50 teams that use them. None have reported to me being unhappy with them. I would not/do not hesitate to recommend using them.
Joe J.
Team #88, TJ2
Unread 01-11-2006, 11:35 PM
Stu Bloom's Avatar
Also, for those interested, check my post HERE for more information/links and a source for the sometimes difficult-to-find parts you will need.
Stuart Bloom
Mechanical Engineer
Unread 01-12-2006, 12:51 AM
Henry_Mareck's Avatar
Henry_Mareck Henry_Mareck is offline
FRC #0418 (Purple Haze / LASA Robotics)
Team Role: Student
Henry_Mareck is a jewel in the roughHenry_Mareck is a jewel in the roughHenry_Mareck is a jewel in the rough
Send a message via AIM to Henry_Mareck
we never had any problems with shifting, though we modified the shifter for only 1st and 2nd gear, never third. Worked great, defintley reccomend them. We have sent the sun gears off to be machined already(i think), and have already done the interface plates on our cnc mill for this year.
Unread 01-12-2006, 01:46 AM
Xufer's Avatar
Im glad to hear these transmissions worked out so well for everyone i really hope we get to try them out this year.
Unread 01-12-2006, 06:38 PM
Xufer's Avatar
What is the estimated or actual weight of the Chippua + Dewalt package? Including the servo for shifting. but not including any out put gears/or sprockets.
Unread 01-19-2006, 08:58 PM
Bill_Hancoc's Avatar
Bill_Hancoc Bill_Hancoc is offline
Volkswagen Enthusiast
AKA: Bill Hancock
FRC #0573 (MechWarriors)
Bill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud of
Send a message via AIM to Bill_Hancoc
what are some peoples suggestions for mounting a CIM-DeWalt combo to be chained to a single wheel?
Thanks for the help
MechWarriors 573
Unread 01-19-2006, 09:08 PM
Xufer's Avatar
Thanks for the help
See i was wondering about wether i want to put one on each wheel or combine the two first, but im not too sure about combining motors via chain. so i would also love to see some ideas.
Unread 01-19-2006, 09:57 PM
AKA: Dr. Joe
FRC #0088 (TJ2)
There are other papers and threads on this topic, but here is my 2 cent again:
There is a very strong advantage to having a chain couple the 2 motors and the 2 (or 3 or more) wheels on each side: when a wheel if off the ground, the power from both motors is automatically diverted to the wheel (or wheels) that are still on the ground.
2 wheels each with its own motor with out a linkage such as chain between them saves a bit in weight and packaging (potentially), but when a robot rocks you back on your hind wheels during a pushing match, that wheel out in front that is off the ground is not doing you any good.
Joe J.
Team #88, TJ2
Drill Motors Removed? Illegal this year? Chris_Elston Motors 12 01-12-2005 09:04 AM
First Year Team Assistance - MOEmentum: FYI Mr MOE General Forum 0 01-07-2005 02:07 PM
How did you thank your engineers/mentors/sponsors this year? Bharat Nain Thanks and/or Congrats 15 08-01-2004 09:18 PM
Starting a college team mtrawls Starting New Teams 23 04-28-2004 09:58 AM
