Go to Post "FIRST: We take young human beings, born in captivity, educate them in science and technology, and re-release them into the wild." - kmcclary [more]
Unread 12-01-2006, 10:50
Total Meltdown Total Meltdown is offline
Programming Mentor
AKA: Sean Edwards
FRC #0172 (Northern Force)
Total Meltdown is an unknown quantity at this point
Send a message via AIM to Total Meltdown Send a message via Yahoo to Total Meltdown
Camera not powered...?
Hey Dudes, I'm having a problem with the camera. I finally figured out how to get it mounted, the servos and everything are hooked into the Robot Controller, but when I power on (Backup battery charged and plugged in), the Camera doesn't do anything. The Servos reset to their default position ok, but the Camera itself seems to have no power. I'm sure that the PWM cable is in the right spot for 7.2v power, and it's plugged into an unused PWM spot, but it's still not getting power, and thus I can't connect to it with labview, and the Robot Controller is like "wtf?" and does nothing.
Any ideas?
Unread 12-01-2006, 11:02
Pat Fairbank's Avatar
Pat Fairbank Pat Fairbank is offline
Circuit Breaker
Pat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond repute
Send a message via MSN to Pat Fairbank
Re: Camera not powered...?
I hate to ask the obvious, but is the camera's power switch on?
Patrick Fairbank
Team 254 | Mentor (2012-)
Team 1503 | Mentor (2007-2011)
Team 296 | Alumnus (2001-2004) | Mentor (2005-2006)
patfairbank.com
Kingofl337's Avatar
You didn't see anything....
AKA: Adam
FRC #0501 (Power Knights)
There is a small switch on th PCB did you flip that?
Unread 12-01-2006, 11:24
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
I ran into similar problems last night. The items I went through to get mine working were:
1) Make sure 7.2 vdc battery is charged and connected.
2) Verify correct orientation of PWM cable providing power to the camera, on both ends.
3) Connect serial cable (actually a PWM cable) to camera rs-232 port and TTL board on RC.
4) Pan servo to PWM-01 on RC.
5) Tilt servo to PWM-02 on RC.
6) Camera power switch in ON (up) position.
7) Tether between RC and OI.
8) +12 vdc to RC
If all those are correct, it "should" work.
Unread 12-01-2006, 12:01
Kevin Watson's Avatar
La Caņada High School
FRC #2429
Any ideas?
If you downloaded the code yesterday, there was a window when the available code was messed-up. download the code and drop in the corrected serial_ports.c and you should be good to go. I swear, sometimes it seems like FIRST has got a room full of monkeys writing code. Maybe the monkeys should spend less time flinging fecal matter at each other and more time testing the code before posting it <grin>.
-Kevin
Kevin Watson
http://kevin.org
Unread 12-01-2006, 12:17
X-Istence X-Istence is offline
Melt the RC controller!
AKA: Bert JW Regeer
X-Istence will become famous soon enoughX-Istence will become famous soon enough
Send a message via AIM to X-Istence Send a message via MSN to X-Istence
-Kevin
One little screwup should not get us mad at you, the code you provide is awesome!
My Blog!
Unread 12-01-2006, 16:11
Programming Mentor
AKA: Sean Edwards
Yes, the power switch is on, I have 12V DC power, and 7.2V from the Backup battery, but I know the camera isn't on because the little lights on the board don't light up like the manual said they should. And no, I downloaded the code a few days ago. I think I had it compiling Wednesday night at the first Programming meeting (Good job on that, by the way), but I downloaded it a day or two before and just never did anything to it.
I'm 99% sure it's a power thing though, cause even bugged code would make Something happen. As it stands now, I have no power, and the laptop doesn't see it as connected when I plug in the serial cable to connect to LabView.
Unread 14-01-2006, 01:54
Programming Mentor
AKA: Sean Edwards
HAH! Fixed it. There was a nut that was touching two of the wires in the board, and it was causing a short circut, untimately causing the camera to puke. It's fixed now, and no harm done, but Keep an eye on whoever puts the camera together! It's a very easy mistake to make!!
How To Use the Google Camera generalbrando Kit & Additional Hardware 2 07-02-2006 16:00
Scripting Setup and the Camera + Serial Port Drivers CJO Programming 22 11-01-2006 17:42
Unresponsive camera neilsonster Programming 9 17-02-2005 08:51
Kevin Watson's Kick-off Demo Code! Mr. Lim Programming 27 22-01-2005 03:38
CMUCam2 Camera Code - Are important parts commented out? Mr. Lim Programming 4 14-01-2005 12:11
