Go to Post Still waiting for the "GDC Member" position to open up. Got my resume all set for that one. - Tetraman [more]
Unread 12-01-2006, 11:47
Nitroxextreme's Avatar
Nitroxextreme Nitroxextreme is offline
Relation to Mrs. Steve
AKA: Jon
FRC #1626 (Falcon Robotics ; 190 (Gompei and The Herd))
Nitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to behold
Send a message via AIM to Nitroxextreme
Speed Sensor
I'm looking for some kind of sensor that can measure speed/velocity of a moving wheel. I considered encoders/gear teeth sensors but I'm out of interrupts.
Ideally I'd like to find something that would return an analog value based on the speed...
Any ideas?
Thanks
"He needed a chuck norris lesson in FIRST"...."I will give him a round house kick to the face...with gracious professionalism"
Unread 12-01-2006, 12:24
Mike's Avatar
Mike Mike is offline
has common ground with Matt Krass
AKA: Mike Sorrenti
FRC #0237 (Sie-H2O-Bots (See-Hoe-Bots) [T.R.I.B.E.])
Mike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond repute
Re: Speed Sensor
What about using a seperate board, and have it communicate to the IFI board via a serial connection?
http://www.mikesorrenti.com/
Unread 12-01-2006, 13:57
Shu Song's Avatar
Shu Song Shu Song is offline
Melodious Footware
AKA: *Crash!* Shuuuuuuuuuuuu
FRC #0639 (Code Red Robotics)
Shu Song has much to be proud ofShu Song has much to be proud ofShu Song has much to be proud ofShu Song has much to be proud ofShu Song has much to be proud ofShu Song has much to be proud ofShu Song has much to be proud ofShu Song has much to be proud of
Send a message via AIM to Shu Song
Re: Speed Sensor
You can use accelerometers, which you have to integrate to get the speed. I don't know if they are included in the kit this year, but they were definitely in the kit last year.
Code Red Robotics - Team 639
Ithaca High School| Ithaca | New York | USA | Earth | Sol System | Milky Way | Universe | Some Alien's Locker
WINNER of the 2005 Finger Lakes Regional, thanks to teams 191 and 494.
WINNER of the 2004 Canadian Regional, thanks to teams 33 and 1112
WINNER of Delphi: Driving Tomorrow's Technology Award at the 2007 Finger Lakes Regional.
Unread 12-01-2006, 13:58
Chriszuma's Avatar
Chriszuma Chriszuma is offline
Jack of all trades
AKA: Chris Hammond
FRC #0068 (Truck Town Thunder)
Chriszuma is just really niceChriszuma is just really niceChriszuma is just really niceChriszuma is just really nice
Send a message via AIM to Chriszuma
Re: Speed Sensor
Well then you would lose your serial port. What you could do is get one of those fancy 360-degree position sensors (they run about $50 though), because it outputs analog voltages, looping back to zero when it gets to the top of its range. You could take the difference in position to get the speed. You would have to gear it down substantially though, since it would be mighty hard to detect limit resets when it's going half a turn every loop.
2006 T3 World Tour: Great Lakes - Waterloo - Palmetto - IRI
2006 Awards: Motorola Quality - RadioShack Innovation in Control
My website: http://zuma.phire.org/
Truck Town Thunder's website: http://trucktownthunder.com/
Unread 12-01-2006, 14:21
Re: Speed Sensor
There is a 2 axis accelerometer in the kit this year.
An accelerometer will give you an accurate velocity reading (after a simple integration. Remember: position, velocity, and acceleration are all interconnected) for the robot as a system. If you are checking overall velocity, this will be fine. If you need each individual wheel's velocity, it may not be the best solution.
If you can tell me, how are you out of interrupts? There's good ol' interrupts 1 and 2 (as configured in Kevin's encoder code), but you can also set your code to run interrupts off pins 3-6. Do you really have 6 interrupt driven sensors? I'd be afraid of interrupt overflow before I ever worried about not having enough hardware interrupts to work with. See the interrupt source at www.kevin.org/frc for more info.
There is also a gyro included in the kit this year.
Unread 12-01-2006, 14:41
Re: Speed Sensor
There are six general I/O pins on the Robot Controller which can cause interrupts. We used three encoders on our robot last year, and I know exactly how to modify the interrupt code to handle more. Just how many interrupting devices are you using, anyway?
Unread 12-01-2006, 14:51
fowlerm's Avatar
fowlerm fowlerm is offline
Bringing .NET to Robots
AKA: Matthew Fowler
FRC #0312 (Heatwave); FRC #1369 (Minotaur)
fowlerm has a spectacular aura aboutfowlerm has a spectacular aura aboutfowlerm has a spectacular aura about
Re: Speed Sensor
There are two serial ports on the controller that you can use - the TTL level port (USART2) and the RS232 program port (USART1).
Unread 12-01-2006, 15:07
Re: Speed Sensor
The TTL port is likely to be unavailable for such a custom circuit, since it's the preferred way to communicate with the CMUcam.
Unread 12-01-2006, 15:22
kaszeta's Avatar
kaszeta kaszeta is offline
FRC #0095 (Grasshoppers)
kaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of light
Re: Speed Sensor
Out of interrupts? How many are you using? Coming from someone whose team had 4 interrupts running at once last year, be very, very, careful.
Unread 12-01-2006, 15:27
lupjohn's Avatar
lupjohn lupjohn is offline
AKA: Larry Upjohn
FRC #0692 (FemBots)
lupjohn is an unknown quantity at this point
Re: Speed Sensor
Any ideas?
Thanks
Hi all;
the dual axis accelerometer has an X and Y output that are analog voltage that is proportional to acceration. There for the input to the controller would use 2 analog ports and need to have a support routine relating the Analog to digital output to acceleration of the robot in the X and Y directions. This could be done with integer math only and could even be written as inline assembler code for optimal speed. Just a few thots from an old mentor. LRU.
Unread 12-01-2006, 16:49
Kevin Watson's Avatar
La Caņada High School
FRC #2429
Re: Speed Sensor
Originally Posted by Tom Bottiglieri
If you can tell me, how are you out of interrupts? There's good ol' interrupts 1 and 2 (as configured in Kevin's encoder code...
Actually, I've got updated encoder code that can use any of the interrupts. The first two are just like last year's (optimized for velocity control) plus the upper four are optimized for position control, but can also be used for velocity control. I'll have it up after I finish some documentation.
-Kevin
Kevin Watson
http://kevin.org
Unread 12-01-2006, 17:44
Kingofl337's Avatar
You didn't see anything....
AKA: Adam
FRC #0501 (Power Knights)
Re: Speed Sensor
The Kit includes a accelerometer, a gyro, and two gear tooth sensors. You can use EasyC and drag and drop them into the code. There is also information in the help file on getting them going.
Unread 12-01-2006, 18:38
SoftwareBug2.0's Avatar
AKA: Eric
FRC #1425 (Error Code Xero)
Re: Speed Sensor
Do as Mike says, except have the external processor output a pwm signal which you then have another circuit change into analog, since that's what you're hoping for.
Unread 12-01-2006, 21:04
intellec7's Avatar
intellec7 intellec7 is offline
108 programmer
AKA: Gustavo
FRC #0108 (SigmaC@ts)
intellec7 is on a distinguished road
Send a message via AIM to intellec7 Send a message via MSN to intellec7
Re: Speed Sensor
A tachometer (an AC motor in reverse) gives voltage and frequency output porportional to the velocity of its shaft, but these arn't very precise at low speeds.
I have heard many different things in regards to using a microcontroller other that the RC, is it allowed? Can I forexample use a PIC or someother microcontroller to handle low level stuff?
Unread 12-01-2006, 21:07
Tatsu Tatsu is offline
Audiophile and Physicist.
AKA: Tatsu Hashimoto
FRC #1072 (Harker Robotics Team)
Tatsu will become famous soon enough
Send a message via AIM to Tatsu
Re: Speed Sensor
I think so, the rules dont specifically write about how we cant make a PIC. as long as its outputs go to the RC, they're okay..
We're going to use 2 low-g high precision Motorolla accelerometers (1 axis) run it through a kalman filter on a PIC or STAMP or whatever and output an analog signal..
be sure to eliminate every possible source of bias before your integrator (PIC in this case) or else your v measurements will be vastly off
air speed sensor for rc plane Greg Needel Technical Discussion 19 07-10-2005 23:43
Speed of banner sensor Kashi Chan Electrical 7 06-03-2005 20:00
PID control loops - closed loop feedback KenWittlief Technical Discussion 56 26-04-2004 21:27
Quick Optical Sensor Question zorro Technical Discussion 10 21-01-2003 06:39
What else do we want? archiver 2000 63 23-06-2002 23:19
