Go to Post Nah, I never crash or break anything... - Elgin Clock [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
Unread 11-01-2006, 13:36
Ed Sparks Ed Sparks is offline
Engineer/Mentor/Inspector
AKA: FirstCadLibrary Guy, Inspector Dude
FRC #3959 (Formally with FRC-34)
Ed Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond repute
Send a message via AIM to Ed Sparks Send a message via Yahoo to Ed Sparks
Re: Size of foam balls please
Our "Poof" ball is 6.825 inches in diameter and weights 0.400 lbs.
Ed Sparks
MECH TECH FRC-3959
Unread 12-01-2006, 08:34
Nitroxextreme's Avatar
Nitroxextreme Nitroxextreme is offline
Relation to Mrs. Steve
AKA: Jon
FRC #1626 (Falcon Robotics ; 190 (Gompei and The Herd))
Nitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to behold
Send a message via AIM to Nitroxextreme
These balls even right off of the manufacturing line won't be the same
One of our POOF balls weighed 180g and another was 183g
"He needed a chuck norris lesson in FIRST"...."I will give him a round house kick to the face...with gracious professionalism"
Unread 12-01-2006, 12:31
Elgin Clock's Avatar
FRC #0237 (Black Magic)
Originally Posted by SirCharles982
and there is some questioning if the poof soccer ball is the same as the basketball. im pretty sure there about the same weight and react the same way as the basketballs, i mean they're made of the same materials, just a slightly different cover/mold.
NO. They are different. The soccer ball is larger.
I will prove this later tonight and provide a link.
Stay tuned.
Unread 12-01-2006, 15:35
Eric Scheuing's Avatar
Eric Scheuing Eric Scheuing is offline
FRC #0999 (MechaRAMS)
Eric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud of
We calipered it. It's 6.75 inches.
2005-2007: Bobcat Robotics 177
2015-20XX: MechaRAMS 999
Unread 12-01-2006, 15:50
Mark Pettit's Avatar
Mark Pettit Mark Pettit is offline
Addict
FRC #0991 (The Dukes)
Mark Pettit is a name known to allMark Pettit is a name known to allMark Pettit is a name known to allMark Pettit is a name known to allMark Pettit is a name known to allMark Pettit is a name known to all
Stay tuned.
Elgin,
Just the model name per the manufacturer should be proof enough:
See the manufacturer's sites regarding these products:
Soccer Ball
Basketball
Mark Pettit
Team #991 - The Dukes
Brophy College Preparatory
Phoenix, Arizona, USA
THE DUKES: Humans Competing In The Unlimited Class
Unread 12-01-2006, 21:33
EricRobodox's Avatar
EricRobodox EricRobodox is offline
AKA: Eric... I think a lot
FRC #0599 (RoboDox)
EricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant future
Send a message via AIM to EricRobodox
I measured 6.9 inches on one ball that we have and 185 grams.
Unread 12-01-2006, 22:03
DonRotolo's Avatar
Back to humble
FRC #0832
We measured three balls as follows:
180g
181g
183g
The scale is only good +/- 1g though.
(That's about 6.3 oz. (180g) for the metrically challenged.
For diameter, we measured just a hair under 6.875 for all three, they are very consistent.
There is a thickening, a heavy 'lump' in the middle of the black side (well, it's black on our three plus another one I saw) that is heavy enough to cause the ball to always stop with that spot down.
The skin is very thin - how do you describe it? - much like the thin skin of most any molded foam ball you have even seen. It is not open-pored like the surface of a cut piece of foam rubber.
Hope this helps.
Don
Unread 12-01-2006, 23:03
Umm Errr...
I weighed one that was 185.327g. Why could our school possibly need a scale that measures milligrams? I have no idea.
1139 Alumni
Unread 16-01-2006, 22:25
DonRotolo's Avatar
Back to humble
FRC #0832
OK, now that we got the rest of our order, we measured a total of 20 balls.
Average weight is 183.5 grams
Standard deviation is 2.55 grams
We unscientifically noted that balls also have different levels of hardness, and it doesn't correlate to weight. For example, our 187 g ball is a lot softer than a random 183g ball (as measured by pushing on the face opposite the hard spot).
With that being said, I don't think 3 grams in either direction will matter much.
Don
POLL: have small balls been abandoned? Solace General Forum 44 04-09-2004 17:53
New Jersey Regional Status Aignam Regional Competitions 144 21-07-2004 17:04
Thoughts on the competiton balls Petey Regional Competitions 26 14-03-2004 09:31
Good strategy? tkwetzel Rules/Strategy 45 17-02-2004 21:18
Will ANYONE mess with the black balls? archiver 2001 0 23-06-2002 22:35
