Go to Post I don't care if my team wins. I care if they try their hardest to win. - pfreivald [more]
Unread 12-01-2006, 17:30
ahmed ahmed is offline
synOrange
#0843 (White Oaks Wildcats)
ahmed is an unknown quantity at this point
Send a message via AIM to ahmed Send a message via MSN to ahmed Send a message via Yahoo to ahmed
Gold-plated fusebox
Are we allowed to modify the 40-amp gold plated breaker panel if we're not using all of it?
Unread 12-01-2006, 17:48
Re: Gold-plated fusebox
In 2003 we were able to cut apart the four independent fuse holders if they were able to be mounted and insulated. We were not able to modify the larger four way with a single input connection. This device was only available when teams could no longer find the independent fuse block in 2003.
Unread 15-01-2006, 21:45
Rick Thornbro Rick Thornbro is offline
#0217 (ThunderChickens)
Rick Thornbro will become famous soon enoughRick Thornbro will become famous soon enough
I couldn't find the exact rule but, I don't think that FIRST would allow the fuse block to be modified. I would ask for clarification before modifying the block.
Unread 17-01-2006, 12:54
skimoose's Avatar
skimoose skimoose is offline
Parent/Mentor/Engineer
AKA: Arthur Dutra
FRC #0228 (GUS)
Team Role: Electrical
skimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond repute
In 2004 we simply unscrewed two of the four fuse/breaker holders and wire connectors from the terminal block, and this was allowed. I'd post the rule to the Q&A forum at FIRST for an official ruling. We did this because those 40 amp breaker units are really heavy.
2009 CT Regional Motorola Quality Award
2010 VRC Connecticut Championship Winners & Amaze Award
2010 VRC Championship Divisional Energy Award
2010 WPI Regional Winner
2010 WPI Regional Engineering Inspiration Award
2011 WPI Regional Chairman's Award
2012 WPI Regional Finalists
Unread 23-01-2006, 18:10
pyroslev's Avatar
pyroslev pyroslev is offline
VirginiaFIRST FTA
AKA: Jack of all trades, Master of few
no team (Forget not 616)
pyroslev is on a distinguished road
Simply reusing an old thread.
I found a place to order them from. I am 90% they match but I want an electrical gurus opinion. http://www.knukonceptz.com/productDe...prodID=FB-3448
A quick response would be great
Thanks
Unread 24-01-2006, 07:15
John,
Close but no cigar. Although this is similar in style it is not the same part. Sorry.
Unread 24-01-2006, 13:24
Justin Stiltner's Avatar
Justin Stiltner Justin Stiltner is offline
The big guy
Justin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud of
Send a message via ICQ to Justin Stiltner Send a message via AIM to Justin Stiltner Send a message via MSN to Justin Stiltner Send a message via Yahoo to Justin Stiltner
This is actually from a post by rickerstine but the breaker panels from first in 2004 are being sold at a surplus company that first sold them to.
http://www.resunltd4u.com/ Price is $9.00
scroll down the first page and you will see it.
direct link here http://www.resunltd4u.com/display.asp?item=MAXI-4
Justin Stiltner
Lead Robot Inspector, VCU Regional
Unmanned Systems Lab, Virginia Tech
KI4URQ
Unread 24-01-2006, 14:50
pyroslev's Avatar
VirginiaFIRST FTA
Thanks for the assist.
Unread 30-01-2006, 14:31
N3OW N3OW is offline
FRC #0869
N3OW is an unknown quantity at this point
Exclamation Re: Gold-plated fusebox
We are looking for one as well and have not had any success in finding a Maxi 4 have you been able to locate one? if so would you please share that information as to where you found one.
Thank you
Jay
Unread 30-01-2006, 14:35
The big guy
Maby I should have been more clear... this appears to me to be the same panel as we are using this year.
Justin Stiltner
KI4URQ
Unread 02-02-2006, 19:01
FRC #0869
We recieved a replacement maxi block that was recommended, but there is no common bus. We are looking for suggestions.
Unread 03-02-2006, 07:19
If your block is four independent fuse holders, you must use the power distribution block. (Black plastic base with three metal blocks.) Each of the independent parts of the power dist. contains a #6 input port and 4 #10 output ports with screw hold downs. Make sure these are tight at regular intervals. You have been able to remove the unused portion of this block in the past to save weight. I haven't checked to see if a Q&A has asked that this year.
UFH: Bill Gold CD47-Bot Unsung FIRST Heroes 27 19-08-2005 17:41
Ideas for my Gold Award Project Sarah Bowes General Forum 4 24-06-2005 18:25
Bringing home the gold? 4n0nym0us_1 Championship Event 17 14-04-2004 10:30
Crazy Idea, looking for comments archiver 1999 74 23-06-2002 22:56
Hey, Hey Bill Gold Ken Loyd General Forum 2 08-11-2001 06:09
