Go to Post 256:1 gear reductions provide surprisingly little torque once the gears have failed. - Kevin Sevcik [more]
Unread 12-01-2006, 13:56
V8GTORacer V8GTORacer is offline
The Mad Scientist
FRC #1803
V8GTORacer is an unknown quantity at this point
Send a message via AIM to V8GTORacer
Exclamation Quick Q for "noob" at first
For cooling of the bot, are we allowed to use regular computer fans (in addition/to replace supplied fans)? I heard somewhere that last year we werent and couldn't find anything in this year's manual about it.
Friends don't let friends drive rice.
<~that dude rules!
Intel P4 pwns all.
Unread 12-01-2006, 14:04
Re: Quick Q for "noob" at first
Some teams find that the mechanical design they have chosen causes the motors to run hot. Frequently teams use a 12 volt fan blowing directly on the motors. You can find these fans at Digikey or any of the other common vendors. There is no real need to cool the other components, the speed controllers have their own fans and the rest of the electronics do not run hot in normal operation..
Unread 12-01-2006, 14:39
John Gutmann John Gutmann is offline
I'm right here
AKA: sparksandtabs
FRC #0340 (GRR)
John Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant future
Send a message via AIM to John Gutmann Send a message via MSN to John Gutmann Send a message via Yahoo to John Gutmann
Yes, you can use the computer fans.
It helps if you mount the fan to the same plate you mount the motor to.
Unread 12-01-2006, 16:09
coastertux coastertux is offline
Penn State Class of 2010!
AKA: Steve
FRC #1640 (sab-BOT-age)
coastertux is just really nicecoastertux is just really nicecoastertux is just really nicecoastertux is just really nicecoastertux is just really nice
Send a message via AIM to coastertux
Make sure you mount the fans so nothing can get pushed into them...
It's no fun bringing a 10,000 RPM fan to a complete stop with your finger (or any other object for that matter)!
"The important thing is not to stop questioning. Curiosity has its own reason for existing. One cannot help but be in awe when he contemplates the mysteries of eternity, of life, of the marvellous structure of reality." ~Albert Einstein
DHSE '06, PSU '10 (Eberly College of Science - Chemistry)
Unread 12-01-2006, 16:36
The Mad Scientist
FRC #1803
ok thanks guys
<~that dude rules!
Intel P4 pwns all.
Unread 12-01-2006, 16:58
Conor Ryan Conor Ryan is offline
I'm parking robot yacht club.
FRC #4571 (Robot Yacht Club)
Conor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond repute
Heres something intresting, good topic.
Now most of the motors in the kit tend to run pretty cool, and the further away from stall torque they are, the cooler they will run. From experince and what I've heard from other teams is that if any motor in the Kit run hot, it's the small Fisher-Price motors (not the Really Big Cims, or the Mini Bike Motors) What do people do to combat that effectively?
Fans do take a bit of time to move the heat out of the area with the motor, whats an easy way of speeding this up? Add a heat sink. How? Take some copper or the best heat conducting material you can find, and wrap some of the motor in it. Add a fan or two, and it'll run nice and smooth. The kit muffin fans are good enough, if you wanna go and deck your robot out in all fancy computer case fans, check the electronics rules first, and check the connections on them.
Unread 12-01-2006, 18:33
SoftwareBug2.0's Avatar
AKA: Eric
FRC #1425 (Error Code Xero)
Originally Posted by Conor Ryan
...if any motor in the Kit run hot, it's the small Fisher-Price motors (not the Really Big Cims, or the Mini Bike Motors) ...
...Add a heat sink. How? Take some copper or the best heat conducting material you can find, and wrap some of the motor in it. ...
My team did this in 2004. We used the drill motors which did tend to get hot.
We had two big aluminum blocks that were both mounts and heat sinks. Each piece had half of a circle on one side, and then screwed together to make a whole circle that the motor would go into. We used some thermal paste next to the motor and where those blocks attached to our main frame. That part of our frame was fairly heavy stock so that helped transfer even more heat.
Unread 12-01-2006, 19:09
At this point in the design cycle I would recommend looking at your drivetrain design, to keep the motor RPMs high, so you dont need a fan
it should be easier to design in one more set of gears in your drivetrain, to get the motor RPMs up, than to design for bad design and fabricate monster heat sinks and fans.
You can run those drill motors all day long, at their intended speed and load, and they will not get hot.
Every team should take a motor apart (one you dont need anymore) and see whats inside. The heat that is generated in a stalled motor comes from the armature, the part that spins. This does not touch the case of the motor at all, except at the bearings. You will also discover the drill motors and FP motors have blowers built into them, by the commutator. This blower does an excellent job of pulling air through the motor where you need it: across the windings (as long as you dont block the openings where the air comes out).
If your motor gets so hot that you cant touch it, and it smells like burnt varnish, the armature windings inside must be almost glowing! Blowing air across the case will only cool the magnets that are in contact with the case. The windings on the armature will continue to cook.
Unread 12-01-2006, 19:20
KathieK's Avatar Unsung FIRST Hero
KathieK KathieK is offline
Sometimes FIRST makes my head hurt!
KathieK has a reputation beyond reputeKathieK has a reputation beyond reputeKathieK has a reputation beyond reputeKathieK has a reputation beyond reputeKathieK has a reputation beyond reputeKathieK has a reputation beyond reputeKathieK has a reputation beyond reputeKathieK has a reputation beyond reputeKathieK has a reputation beyond reputeKathieK has a reputation beyond reputeKathieK has a reputation beyond repute
Send a message via AIM to KathieK
V8GTORacer - welcome to FIRST and to ChiefDelphi! We hope you have a great rookie season this year and don't hesitate to ask questions in these forums - just a hint, though, you might want to look through all the different forums that are available to see if there is one that is more specific to your question. For example, this topic might be better addressed in the Technical > Motors section (click on the link to ChiefDelphi forums at the top of each page and it should bring up the screen with all the topics listed on it) rather than in the General section. Also, CD encourages all users to use the search feature before starting a new thread just to be sure that someone else hasn't already started a thread on the very same topic!
Good luck to your team!
Check out my 2016 Conference presentation, Dumpster Diving: How to Get Stuff for Your Team for Free or at Little Cost
www.usfirst.org | www.nefirst.org | www.firstnemo.org
Helping mentors since 2004
Unread 12-01-2006, 19:30
AKA: Eric
Of course you should try to design things so they don't get hot, but this was using the kit gearboxes to the kit 12" wheels, and the motors certainly did get hot, as did the blocks surrounding them and to a lesser extent the parts of the frame they were attached to.
On a FIRST robot, you're likely to be using parts outside of their intended specifications even if you think it should be totally safe.
Unread 12-01-2006, 19:42
sciencenerd's Avatar
sciencenerd sciencenerd is offline
ooh, what does this button do?
AKA: Kyle
FRC #1318 (the IRS (Issaquah Robotics Society))
sciencenerd has much to be proud ofsciencenerd has much to be proud ofsciencenerd has much to be proud ofsciencenerd has much to be proud ofsciencenerd has much to be proud ofsciencenerd has much to be proud ofsciencenerd has much to be proud ofsciencenerd has much to be proud of
Wouldn't the computer fans include motors that weren't from the KOP? So wouldn't that be illigal? I could be wrong, but if I am, someone please explain to me why.
Oh, maybe I shouldn't have pushed that...
Unread 12-01-2006, 20:00
Andrew Blair's Avatar
FRC #0306 (CRT)
I;m not entirely sure, but if the fans serve no purpse other than to cool something, not provide actual physical force, than they are presenting an advantage great enough that a team couldn't simply, if they felt they were at a disadvantage, go out, buy some fans, and zip-tie 'em on. But I'm sure theres a rule confirming it somwhere. Hi ho Q&A!
-Sir Francis Bacon
-Albert Einstein
Unread 12-01-2006, 20:49
mechanicalbrain's Avatar
mechanicalbrain mechanicalbrain is offline
The red haired Dremel gnome!
FRC #0623 (Ohm robotics)
Team Role: Electrical
mechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond repute
Send a message via AIM to mechanicalbrain Send a message via Yahoo to mechanicalbrain
Im not so sure about this.
Originally Posted by Section-5 The Robot
<R44> Specific items NOT allowed include:
• Electric motors different from or in addition to those in the Kit, with the exception of those specifically
permitted by Rule <R43>.
<R43> Specific items allowed include:
• Additional HITEC HS-322S servos.
• Additional Victor 884 Speed Controllers and Spike Relays, as needed.
• Additional solenoid valves, air cylinders, and connecting fittings.
• Teams may purchase either one additional 4-slot Maxi-block circuit breaker panel OR one 2005 FRC
circuit breaker panel, and utilize it on their 2006 robot in addition to the circuit breaker panels provided in
the kit of parts.
• Teams may utilize one or two additional small CIM motors (part #FR801-001) in addition to those
provided in the kit of parts. This means that you may use up to four, and no more, small CIM motors on
the robot.
The fans use motors right? Unless it's a KOP fan it's not going to be legal. This rule in particular made it hard for me to add lighted fans to our robot, I looked at removing the motors and putting them in the lighted fans but it was just a hassle. Of coarse if you are refering to a KOP fan then yeah perfectly legal.
"Oh my God! There's an axe in my head."
623's 2006 home page
random mechanicalbrain slogans
Unread 12-01-2006, 22:33
ok, thats a good starting point. So what could you do differently this year?
smaller wheels?
not use skid steering?
limit the amount of power the driver can command to the motors if they are stalled?
Use the kit gearbox but add one more stage of gear reduction before the wheels?
this is the time to make those decisions.
Unread 13-01-2006, 02:53
AKA: Eric
smaller wheels?
That year, our team had neither the expertise nor the time to go back and do things right, so we did what we could when we realized that there was a problem.
I and my team members understand that it was not ideal. The next year, which was last year (I have mentioned that the crazy heat sinks were from 2004 and on drill motors) we did not have the same problems.
A big element of FIRST competition is thinking on the fly. At this point, you should be trying to design a system that doesn't have motor stalling and overheating problems, but it's good to know some techniques that have worked in the past, even if they're not ideal. You might need to use them.
BTW, I'm also thinking that normal, non-kit, electric fans would not be legal.
Two quick questions... mechanicalbrain Electrical 15 08-10-2005 09:23
a quick function question Kashi Chan Programming 3 06-03-2005 20:44
Quick Survey David V Chairman's Award 0 13-01-2005 22:14
A quick IR sensor question PBoss Programming 7 28-03-2004 21:02
Q&A Discuss: Quick C Programming Q CD47-Bot Extra Discussion 6 16-11-2003 11:16
