Go to Post Frankly, I love CD and everything it stands for. I've made more friends from this forum alone than I ever expected to meet in FIRST. I'd give just about anything to keep this system up, upgraded and going on long into the future. It's not even enough to show my thanks and gratitude. - BandChick [more]
Unread 12-01-2006, 20:32
steven114 steven114 is offline
Programming Wizard and Team Captain
AKA: Steven Schlansker
FRC #0114 (Eaglestrike)
steven114 is a jewel in the roughsteven114 is a jewel in the roughsteven114 is a jewel in the rough
Send a message via AIM to steven114
Does the Vision Target seem rather dim?
We hooked up our Vision Target to a nice battery (fully charged, yes) and hooked it up - does it seem rather dim to anyone else? It's nice and bright when you're close or if it's dark, but if you take it outside or even in a well-lit room it quickly becomes hard to see. I went over the rules and they didn't seem to mention anything - are they going to keep the lights dim, or do we have some other problem, or is it just dim? This seems like it could reduce the camera system's effectiveness by a lot...
Shift to the left, shift to the right!
Pop up, push down, byte, byte, byte!
Unread 12-01-2006, 20:46
Umm Errr...
Re: Does the Vision Target seem rather dim?
Did you put it in a wooden box? Try painting it white inside or adding some aluminum foil. Alot of light gets absorbed.
1139 Alumni
Unread 12-01-2006, 20:59
jskene jskene is offline
None #0612
jskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to behold
I would suggest using the same box as the competition lamp will use. That way you know what you will be dealing with on the playing field.
Jerry Skene, mentor OOO OOO 2010 - Chairman's Award- DC OOOOOOOOOOOOOOOOOOOOOOOOOOO
Chantilly Academy, Team 612 - 2009 - Engineering Inspiration Award; Finalist - New Jersey
-----------------------------------2008 - Chairman's Award; Kleiner Perkins Award -Buckeye ---| ---Team Spirit Award - NASA/VCU
-----------------------------------2007 - Chairman's Award - NASA/VCU ---| ---Finalist; Kleiner Perkins Award - Chesapeake
-----------------------------------2006 - Chairman's Award - Chesapeake ---| --- Engineering Inspiration Award - NASA/VCU --
Unread 12-01-2006, 21:19
Andrew Blair's Avatar
FRC #0306 (CRT)
If you hook it up with the correct setup, you will be almost blinded looking at it the first time. This is just a way to tell if you've got it right or not.
-Sir Francis Bacon
-Albert Einstein
Question concerning vision target Otrobotics General Forum 17 15-01-2006 15:59
vision target Dakota Snow Kit & Additional Hardware 1 08-01-2006 23:00
Vision Target Chassis Mod? AnkurG Kit & Additional Hardware 1 08-01-2006 21:12
Error - symbol 'e' has multiple definitions. HELLPPPPP BookerT Programming 2 24-01-2005 21:50
