Go to Post The first law of programming is that there are always ways of doing things quicker and in less space than you already are. - jgannon [more]
Unread 12-01-2006, 21:06
robotaddict's Avatar
robotaddict robotaddict is offline
FRC #1294 (Screws Loose (hopefully going to be changed soon))
robotaddict is on a distinguished road
Holonomic drive and ramp
Okay, someone tell me when I go crazy. Here goes.
I was thinking that a holonomic drive bot could make it up the ramp with some attention to design and ground clearance, but my team disagrees. EVERYONE, including the people who support holonomic drive, thinks that it lacks traction enough to haul itself up the ramp. I also think that the major disadvantage for a holonomic bot attempting this is the contact surfaces distance from the ends of the 'bot, but on closer inspection I noticed a way to overcome this: tilting the wheels.
Because of the perpendicular rollers on omniwheels, the contact surface of a tilted wheel, say 10 degrees from horizontal, is the same as an upright wheel. All that's required is some fancy-pants mounting of motors and what-not. If the wheels were tilted in to 80 degrees from vertical, the contact patches would be closer to the corners of the robot that almost any other design.
With these tilted wheels, you could lower them from beneath the frame by enough to start climbing the ramp and get to the crest. However, once at the crest it is not necessary to get your entire robot up onto the platform if you can get your front wheels over the egde to sort of "hook" you on. Not on the platform, but more importantly not on the carpet. 5 pts.
If you could tell me what you think of this I could stop doubting the species of the mushrooms on that pizza I had. It would be most helpful!
Our team is a third-year team with, at the moment, limited funds, no machine shop, and some people who seem fine with two-wheel drive. If anyone more knowledgeable than me (head programmer w/virtually no experience but a good head for math & spacial relations) would put their two-cents in it would help our team do something interesting this year. I also think it would just be really freaking cool.
Anywho, I'm rambling, so I'm just going to cut myself off.
P.S., one of the few things my team has agreed on is the ability to climb the ramp, but seems to be putting this over our agreed upon chief priority of a freakishly maneuverable shooter, hence the holonomic drive idea. Ok, bye for real this time.
"Say, what rhymes with 'run for your lives'?" -Flavor text on one of my favorite MTG cards
"THAT SHOULDN'T BE PHYSICALLY POSSIBLE!!!" -Response to the combo I based on that card
"You might as well put a sign on it that says 'I'm a gigantic nerd'." -My dad
John, head programmer of team 1294 and gigantic nerd.
Unread 12-01-2006, 21:12
mechanicalbrain's Avatar
mechanicalbrain mechanicalbrain is offline
The red haired Dremel gnome!
FRC #0623 (Ohm robotics)
Team Role: Electrical
mechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond repute
Send a message via AIM to mechanicalbrain Send a message via Yahoo to mechanicalbrain
Re: Holonomic drive and ramp
Is this robot going to be the standard square framed omni system. If so I'm thinking your issue won't be traction but center of balance. Remember if your center of gravity is past the line of your point of contact it will tip.
"Oh my God! There's an axe in my head."
623's 2006 home page
random mechanicalbrain slogans
Unread 12-01-2006, 21:27
Ianworld's Avatar
Ianworld Ianworld is offline
AKA Ian Ferguson
AKA: Ian Ferguson
FRC #0694 (StuyPulse)
Ianworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud of
Send a message via AIM to Ianworld
The only issue with this sort of design, besides the obvious dificulty of tilting your wheel mountings is that you won't know for sure until you build the robot. Its very, very, risky to go into such a complex task thinking that it will maybe, just possibly get up if we just hook the top. I'm not saying that it wouldn't work, just that I don't know and that nobody will for sure until you build it.
So think about the game and decide how necessary getting up that ramp is for your strategy. If its not that important than maybe this is something you could try.
Of course the actual construction once again would be really, really hard.
Team Website
Unread 12-01-2006, 21:36
Not2B's Avatar
Not2B Not2B is offline
AKA: Brian Graham
You'll want to work up a list of robot priorites.
Sounds like you don't have alot of machining and money... maybe keeping it simple is a top priority. Maybe simple is more important than freakishly manuverable. After all, a cool drive that doesn't work isn't as fun as a simple drive that runs every match.
There are lots of different ways to work up a decission process. Best bet would be to find one and use it - and stick with the answer even if it's not what YOU (or any one person) wants.
Example:
For our drive, we ranked it based on the following items, in order of importance (in other words, 1 is more important than 5)
1) SIMPLE
2) RELIABLE
3) Controlablity
4) Torque
5) Stablity
Speed, manuverable, ground clearance didn't make the top 5, but they were also important.
Crab, Holonomic, 2wd, 4wd, 6wd, tracked, halftrack, etc... were all ranked in each of the top 5... we had a tie between 4wd and 6wd... we voted, tied again, decussed, used facts and numbers, and selected our 4wd, mainly because we KNOW it's simple and reliable because we have done it before. And even though we want to upgrade to a 6wd, we think we should practice in the summer, something our budget hasn't allowed yet. (I wanted 6wd, but I lost, and I'm OK with that.)
Good luck!!!
Brian Graham
Unread 12-01-2006, 21:48
Originally Posted by robotaddict
...tilting the wheels.
No, you're not crazy. I saw that idea used last year on Team 116's robot.
Unread 12-01-2006, 21:54
Alekat's Avatar
Alekat Alekat is offline
AKA: Alex
None #0701 (RoboVikes)
Alekat has a spectacular aura aboutAlekat has a spectacular aura about
Send a message via AIM to Alekat
I just have to say that sounds so wild. And especially seeing that picture of 116's bot i get what you mean. Simply an awesome idea.
Unread 12-01-2006, 22:12
Back after 4 years off
FRC #5279
the only problem I see is slippage, if the rollers have a decent abmount of grip with the diamond plate you should be fine.
I'm Back
5279 (2015-Present)
3594 (2011)
3280 (2010)
1665 (2009)
1350 (2008-2009)
1493 (2007-2008)
1568 (2005-2007)
Unread 12-01-2006, 22:50
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
116 basically had the design you are talking about last year. Thing is, it definately cannot climb. It's not because of slippage, but rather that the drive wheels will lose contact with the floor once your robot becomes inclined.
http://invisiblerobot.com/robotics/r.../p1060294.html
For example:
Pretend your driving your "north corner" (or face depending on where you mount the wheels, it doesnt matter for the purposes of this occurance) first. Once it hits the ramp, it will be pushed upwards, but the south corner, not having hit the ramp yet, will still be on the ground. The robot as a whole now has a few degree tilt on it. Because of the tilt, the east and west corners are slightly lifted off the ground, and after you drive a bit more, will completly lose any contact with it. Unless your robot is perfectly balanced, the robot will now tip twoards either the east or west corner, returning that corner to contact with the floor, but removing the other corner further from it. With the absense of this corner, you cannot drive straight forwards anymore.
Our holonomic drive even expierienced the beginnings of this problem with the mere climbing of the triangular loading zones last year.
Unread 12-01-2006, 23:56
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
I'd say it will definitely have trouble with the ramp for the abovementioned reasons. However, you could always add a pneumatically actuated drop down assistance mechanism (wheel, wheels, or roller) to aid in the climbing. You could even power it with something like globe or window motors or fisher price motor(s) and gearbox.
If I had my way, this is what our robot would be like this year. I think omni drive is perfect for this game (crab might be better but it is more complex) But it is not my robot, it is the students' robot, so we will be having a skid steer (tank) drive system.
Unread 13-01-2006, 00:34
kaszeta's Avatar
kaszeta kaszeta is offline
FRC #0095 (Grasshoppers)
kaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of light
I agree with sanddrag, there's no particular reason your bot can't be both holonomic and handle ramps. There are fairly easy ways to accomplish this, either by tweaking some of the details of the holonomic drive itself, or have some sort of mechanism
I think holonomic drives are going to be popular this year, since it's an attractive approach to the problem. Heck, I think the students on my team have thought about it, even.
Test early, however. Holonomic drives can do some weird things.
Unread 13-01-2006, 15:44
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
well, you could build various options to assisst with the ramp climbing, such as an active suspension etc etc etc
But by doing that you make the whole drive system about 2-5x as complex, costly, heavier, and most power absorbing. It may be worth it, just depends on the rest of your robot.
Unread 13-01-2006, 16:57
jerry w's Avatar
jerry w jerry w is offline
Free Agent Mentor
no team (Team Krunch)
jerry w has much to be proud ofjerry w has much to be proud ofjerry w has much to be proud ofjerry w has much to be proud ofjerry w has much to be proud ofjerry w has much to be proud ofjerry w has much to be proud ofjerry w has much to be proud ofjerry w has much to be proud of
i think that you are looking at the problem with the wrong perspective. here is how you gain the platform.
1. accelerate the robot to full speed.
2. at the moment that you reach the ramp, reverse motor power.
3. most robots will, at this point, topple forward onto the platform.
4. if robot momentum was not enough to remove everything from the carpet, then an alliance partner can scoot you up the ramp.
when i first heard this proposed, i laughed. but with a shock absorbing material on the front of the robot, it cushions the fall and helps to stick the robot to the ramp.
jerry w
Happiest when people tell the truth... However, I am blessed with many friends.
Drive Mobility System Kam-AL Motors 7 11-01-2006 19:17
Ramp Riot 2005 :The Official Thread OZ_341 Off-Season Events 39 09-11-2005 12:09
Image Discuss: Team 356: Drive base ramp testing CD47-Bot Robot Showcase 5 14-02-2003 19:44
Extra ramp and platform outside the field at each event to test and practice? Digo General Forum 4 19-01-2003 21:39
How much force to push the ramp? archiver 2001 1 23-06-2002 22:44
