Re: Defensive Strategies
The best defence has gotta be just continuous ramming another robot so they don't get an opportunity to shoot. Since this isn't basketball where a defence-man can't touch someone who's in the process of shooting, this strategy would be equal to just hugging the player with the ball all the time so they can't shoot or pass (which isn't allowed is b-ball). So I really don't think many robots will have to specially equipped for defence.
Whats more important is defence strategy; choosing which robots to stick on, or choosing whether to play defence at all. You could just sit back and load up on all the balls your opponents score and when the period ends, got back and score all those points back. The most interesting defence period will most likely be the last period where both teams can score and there are no backbots. There are so many strategies for that depending on bot's weakness and strengthes and the score situation. So all in all, just ram the robot trying to shoot. <edit>replace all instances of "ram" with "impact from short distance"</edit> Last edited by Shu Song : 13-01-2006 at 00:21. Reason: change the wording |
Might I just note rule G 22 on page 7 of Section 4 The Game, where it specifically says no ramming... Granted this strategy works well when just simply stated as pushing, but just remember everyone RAMMING IS NOT ALLOWED. |
We had the idea of attaching a large CIM to a fan blade and trying to blow the ball away from their trajectory. Yeah, like thats gonna happen. We also had the "idea" of attaching all 15 available motors ( i think there are 15 ) to a fan, and just floating around the field.
you know....anything is possible ![]() |
#7
BTW, if you could have a floating robot, load it up and slam dunk! =D |
#8
Ramming like that is what i call sniper ramming.
But anyways... Use your defensive robots, all of them to plot/prepare for offensive period. It's surprisingly simple. |
#11
you need to think out of the box.
First everybody is worry about the 3rd robot scoring. what would happen if a defence robot can push 2 robots at the same time around leaving the other robot 1 on 1.If you where to block a side goal while waiting there you could be filling it with balls no one have said anything about the ramp. this is going to be big. it is worth 25pts if you get three robots up there. I like that because if you push your opponent up on to the ramp you can hold them there until the end. (by the way the ramp I think will flip robots over if being push to it) that will make it easy to move a turtle on its back up the ramp. go to where the points are and you will win. |
#12
the way the rules are stated it looks like they are looking for teams to do this. because they will let you pin forever on the platform.
It will be up to the other team to make sure their robot will not be tip over Look at this video. that year almost every match there was a robot on there back. this was at the nationals. and not once where we ever warn. because if your robot is defending and trying to stop someone from scoring and they flip over it would not be your fault. But you had to make sure you did not have anything on your robot to help the other robot to flip. ( like a wedge ) like our robots they always had a flat surface only 1/2 - 7 inches off the floor. this alone help robots over if they turn and you pushed them on there side. some form the front so if the other teams robot is worth points to your team they become a scoring object. yes |
#14
is the pinning rule the only rule that does not apply on the ramp/platform?
#15
| Defensive Strategy | Alex Minot | Rules/Strategy | 5 | 09-01-2006 14:12 |
| Winning Defensive Allaince? | George A. | Rules/Strategy | 36 | 07-04-2005 10:00 |
| YMTC: Defensive Strategies | Matt Reiland | You Make The Call | 28 | 15-03-2005 15:11 |
| Extent on Defensive Game | Jeff K. | Rules/Strategy | 1 | 18-02-2005 00:21 |
| Has anyone come up with any actual GAMEPLAY strategies? | Skanker | Rules/Strategy | 4 | 30-01-2002 01:19 |
