Go to Post It's a process of elimination led by inspiration. - JaneYoung [more]
Unread 13-01-2006, 01:26
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Where to get 13T 20P 14.5 degree PA spur gear stock
I've checked the usual places (Small Parts, McMaster, Stock Drive) and they don't have it. I haven't checked Berg or Boston yet. Would Motion Industries or Applied industrial have it. Does anyone know? Thanks.
Unread 13-01-2006, 03:29
Justin Stiltner's Avatar
Justin Stiltner Justin Stiltner is offline
The big guy
Justin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud of
Send a message via ICQ to Justin Stiltner Send a message via AIM to Justin Stiltner Send a message via MSN to Justin Stiltner Send a message via Yahoo to Justin Stiltner
Re: Where to get 13T 20P 14.5 degree PA spur gear stock
Seems like when we tryed to make the 116 tranny a few years ago applied dident have any gear stock. Your best bet might be to see if you can change the mating gear and use the 20degree that mcmaster has, they are ultra quick shipping too. FWIW Stock drive products could probally make you some, but it will be expensive and will probally take 2 weeks or better. Or if you could find someone with a CNC 4 axis mill and a gear cutter... (I say cnc to make it quicker it can be done with a manual mill)
Justin Stiltner
Lead Robot Inspector, VCU Regional
Unmanned Systems Lab, Virginia Tech
KI4URQ
Unread 13-01-2006, 10:47
team222badbrad's Avatar
3D Printing Specialist
AKA: Bradley Rigdon
FRC #0222 (The Tigertrons)
I think Browning has them!
Browning NSS2013
14.5 Pressure Angle, 20 Diametral Pitch, 13 Teeth/Threads, MPBSPUR Gear
Style: SPUR
Pressure Angle: 14 1/2
Diametral Pitch: 20
Number of Teeth/Threads: 13
Type of Bore: MPB
Material: Steel
Minimum Bore: 0.3125
Images may not be an exact
representation of the product
Part No Description OD F H L PD
1210525 NSS2013 0.750 0.375 0.500 3/4 0.650
P
3/8
Tigertrons are on Facebook!
http://www.printo3d.com
16th FIRST season for me.
Unread 13-01-2006, 11:11
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Sadly, sanddrag needs spur gear stock, not precut gears. If you're still looking, Grob, Inc. says they stock some stuff. You might want to give them a call.
pic: GEAR BOX with two speed ericwittlich Extra Discussion 6 19-07-2005 22:01
Gear pitch preference Andy Baker Technical Discussion 15 04-10-2004 09:51
