Go to Post Let me live in my delusional world where minibots never happened and the Tetrix kit doesn't exist. - Andrew Schreiber [more]
Unread 13-01-2006, 00:49
Workaphobia Workaphobia is offline
AKA: Jon
FRC #1546 (Chaos Inc.)
Workaphobia will become famous soon enough
Re: Speed Sensor
Originally Posted by Kevin Watson
Actually, I've got updated encoder code that can use any of the interrupts. The first two are just like last year's (optimized for velocity control) plus the upper four are optimized for position control, but can also be used for velocity control. I'll have it up after I finish some documentation.
-Kevin
Will that work with any encoder, or only quadrature encoders?
Unread 13-01-2006, 01:34
Kevin Watson's Avatar
La Caņada High School
FRC #2429
Re: Speed Sensor
Quadrature only.
-Kevin
Kevin Watson
http://kevin.org
Unread 13-01-2006, 05:44
AKA: Brad
#0190 ( Gompei and the Herd)
Re: Speed Sensor
The code will probably work with any single input encoder provided that you tell it that the B Channel is an input that is always high or low (disconnected or jumpered). The code will read what it thinks is the B channel and it will see the same value, making it always count in the same direction.
For example, in the interrupt service routine for EasyC you connect the A channel to pins 1-6. When the interrupt on the A channel happens, the code reads the B channel to decide whether to count up or down. It doesn't matter if the B channel is actually connected to an encoder - it only sets the count direction.
If you decide to use EasyC it has built-in encoders that only look at a single input.
Brad
Unread 13-01-2006, 11:56
FRC #2429
Re: Speed Sensor
Brad
Actually, the new software I described, and Jon had a question about, does require a quadrature input.
-Kevin
Kevin Watson
http://kevin.org
Unread 13-01-2006, 13:51
AKA: Jon
Re: Speed Sensor
That's what I thought initially, but then I figured that if the phase B input is constant, then every change in the phase A input will be interpretted as the encoder moving back and forth repeatedly, instead of always forward.
That's good to hear. I graduated last year and had no chance to check out the new tools for this year, so I still think of these problems in terms of hand-typed code.
Unread 13-01-2006, 21:07
6600gt's Avatar
6600gt 6600gt is offline
AKA: Lohit
FRC #0226 (Hammerhead)
6600gt is a jewel in the rough6600gt is a jewel in the rough6600gt is a jewel in the rough
Re: Speed Sensor
This maybe a little of topic but can a PIC output a analog value directly?
It would make life a lot simpler.
Unread 13-01-2006, 22:24
Matt Krass's Avatar
AKA: Dark Ages
FRC #0263 (Sachem Aftershock)
Re: Speed Sensor
You can use onboard PWMs or software/timer generated PWMs to create a make shift ADC. Simply feed the output to a small capacitor connected to an analog input with a resister between the capacitor and the analog input that leads to ground.
Take a look at this: http://www.piclist.com/techref/sceni...pwm/pwm_vp.htm
Matt Krass
Unread 14-01-2006, 03:05
Tatsu Tatsu is offline
Audiophile and Physicist.
AKA: Tatsu Hashimoto
FRC #1072 (Harker Robotics Team)
Tatsu will become famous soon enough
Send a message via AIM to Tatsu
Re: Speed Sensor
Just use a DAC. big deal.
DACs arnt very hard to make, you could even just take a reference esign from TI or AD
air speed sensor for rc plane Greg Needel Technical Discussion 19 07-10-2005 23:43
Speed of banner sensor Kashi Chan Electrical 7 06-03-2005 20:00
PID control loops - closed loop feedback KenWittlief Technical Discussion 56 26-04-2004 21:27
Quick Optical Sensor Question zorro Technical Discussion 10 21-01-2003 06:39
What else do we want? archiver 2000 63 23-06-2002 23:19
