Go to Post they just build excellence and silently wait to deploy their creation on the unsuspecting masses - Koko Ed [more]
Unread 04-01-2006, 18:40
thomas thomas is offline
thomas is an unknown quantity at this point
looking for two 6D sensor
I'm a software guy and thus the quest below might seem trivial to you.
Looking for two 6D(pitch, yaw, roll, x, y, z) sensors.
The desired properties of each of the two sensors are:
range: ±2g; 400°/s
stability: 1mm/h, 0.5mm/°C; 0.5°/h, 0.25°/°C
resolution: 0.1mm; 0.01°
sampling sequence: 100 Hz
shock: 5g for 10ms
temperature: -20°C ... +50°C
max dimensions: sphere with radius 4cm; 80g
output/power supply: USB or wireless with
The physical dimensions and power/data connection aren't yet set in stone.
Any idea who is producing/selling this kind of sensors and what their price range is?
Thanks for any suggestions,
Thomas
Unread 04-01-2006, 19:32
sburro's Avatar
sburro sburro is offline
AKA: Joe
FRC #0663 (crusaders)
sburro will become famous soon enoughsburro will become famous soon enough
Send a message via AIM to sburro
Re: looking for two 6D sensor
you can try www.globalspec.com. This is a good engineering search engine for all things to do with engineering.
K.I.S.S
Keeping It Simple Stupid
Unread 04-01-2006, 19:40
Andrew Blair's Avatar
FRC #0306 (CRT)
Well, sparkfun does have some stuff that is relatively reasonable and close to your specifications, though the wireless and 400 degrees per second will be difficult to get I think. But contact them, they may be able to work with you.
http://www.sparkfun.com/shop/index.p...=528311&cat=71&
-Sir Francis Bacon
-Albert Einstein
Unread 06-01-2006, 01:00
Justin Stiltner's Avatar
Justin Stiltner Justin Stiltner is offline
The big guy
Justin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud of
Send a message via ICQ to Justin Stiltner Send a message via AIM to Justin Stiltner Send a message via MSN to Justin Stiltner Send a message via Yahoo to Justin Stiltner
Actually spark fun is producing an wireless IMU (inertial measurement unit) that is 6DOF like you want, it uses bluetooth or you can get the serial data out of it with the debug header, i am trying to use one now with an robotics project at school. Here is the link to itIMU/Gyros
http://www.sparkfun.com/commerce/cat...520ba7a8289ca8
powered by 6v and outputs TTL I do belive
We got the V2 FYI
On your specs you listed the drift or lack of it that you wanted, I think this is mostly a facotr of your software and the integration, you may be able to find an absolute gyro / accelerometer but the vast majority of affordable ones simply output acceleration in whatever axis, not position, you may want to check out how kevin watson does it with his gyro code Kevins site in his first robotics section there is some really well commented code and readme's in the files
Justin Stiltner
Lead Robot Inspector, VCU Regional
Unmanned Systems Lab, Virginia Tech
KI4URQ
Unread 13-01-2006, 08:51
Electrical Engineer
Rookie Year: 1995
I also like the Sparkfun product line. But remember: Although a lot of fun to play with, any wireless devices are not allowed on the robot.
Mike Betts
As easy as 355/113...
Unread 13-01-2006, 11:09
emusteve's Avatar
emusteve emusteve is offline
AKA: Steve Martin
#0470 (Alpha Omega)
emusteve is just really niceemusteve is just really niceemusteve is just really niceemusteve is just really nice
Have you looked into hacking a Gyropoint mouse? It's wireless, and the data comes out in a well documented useable format.
Steve
Making a Sensor Board SpaceOsc Technical Discussion 11 15-05-2004 12:46
A quick IR sensor question PBoss Programming 7 28-03-2004 21:02
Banner Sensor Programming Problem 2Crisis Programming 4 24-02-2004 13:40
Quick Optical Sensor Question zorro Technical Discussion 10 21-01-2003 06:39
