Re: pic: cathode light assembly
...Its a brown box.
indeed, very brown may it be, green like a lightsaber, glow it does.......
we just ignored the entire chassis mod/creating a box, and just stuck ours directly to the back of the HDPE sheet.
Took about 15 minutes instead of 2-3 hours ![]() |
What type of PSU did you hook the box up to. How many volts too, we finished the box, but our leader is a bit scared that we might fry it. Whom ever tells us the PSU and the Voltage thanks, its greatly apreciated.
My team actually built a really nice box from some 2x4s and plywood. I'll bring my camera and take pictures tomorrow if I remeber to...
#9
We built ours much the same way, a 2x4 frame, some sheet aluminum on the back, but it just doesn't seem bright enough. We may try lining the inside with foil next.
#10
At first outs was extremely dim, after about 3 minutes it got brighter, then I walked down to the wood shop to get some tools, and when i got back about 10-15 minutes later, it was very bright. I believe that the lights just need to worm up..
Our box took about an hour to make and about 30 minutes to wire. I wired it up to one of our 12v batteries and used a breaker panel from 2 years ago and a 20amp fuse to power it. I was just wondering if anyone else used the correct offset for the lights from the diffuser panel? Also, ours was plenty bright with just wood, has anyone compared a wood box to the official boxes to see how the light compares? |
#11
we used aluminum and a 12v battery and it was bright almost instantly
. i dont think they have to warm up. |
#12
cold cathodes do need to warm up for maximum light output.
#13
4 hours of work? i can understand taking your time, but you had nothing better to do?
| ProE Assembly Editing | daramana | Inventor | 5 | 31-01-2005 13:21 |
| pic: Swerve Assembly | CD47-Bot | Extra Discussion | 3 | 23-01-2004 20:02 |
| TCP/IP on a PIC | Venkatesh | Electrical | 1 | 18-11-2003 21:00 |
| About the light that need to be seen from four side | archiver | 2000 | 3 | 23-06-2002 23:01 |
| How many posters does it take to change a lightbulb? | Brandon Martus | Chit-Chat | 7 | 22-02-2002 19:48 |
