Go to Post My Worst Decision of the Week?? Reading this thread!! :) :) :cool: :cool: - BobC [more]
Unread 13-01-2006, 01:03
Arkorobotics's Avatar
Arkorobotics Arkorobotics is offline
Robots!
AKA: Ara Kourchians
FRC #0589 (FalkØn)
Arkorobotics is a splendid one to beholdArkorobotics is a splendid one to beholdArkorobotics is a splendid one to beholdArkorobotics is a splendid one to beholdArkorobotics is a splendid one to beholdArkorobotics is a splendid one to beholdArkorobotics is a splendid one to behold
Send a message via AIM to Arkorobotics
Talking Turbulence
I was thinking... What if you make a robot that has a HUGE fan pointing up, then when you start, you just drive over to the platform right above the center goal and turn the fan on. With all the turbulence the balls will never make it in. But... you can't do anything but this, but that is assuming that the other team does center goal only...
2007 Rockwell Automation Innovation in Control Award winners (Southern California Regional)
Crescenta Valley High School Team 589
http://www.arkorobotics.com My Blag
3.141592653589793238462643383275902884197 <- Current memorization of Pi
Callsign: N6ARA
Unread 13-01-2006, 01:38
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: Turbulence
Interesting, considering we have plenty of motors capable of powering an incredibly large fan to an incredibly high speed.
Unread 13-01-2006, 01:52
REVving up for a new season
FRC #2848 (All-sparks)
Re: Turbulence
shhhhhh.....don't tell anyone
Greg Needel│www.robogreg.com
Co-founder REV Robotics LLC www.REVrobotics.com
2014 FRC World Champions with 254, 469, & 74
Unread 13-01-2006, 10:11
Robots!
AKA: Ara Kourchians
FRC #0589 (FalkØn)
Re: Turbulence
Don't worry.. It's ok. This idea is really a creative idea, but it can't do anything but defend the center assuming that all robots are for the center..
Callsign: N6ARA
Unread 13-01-2006, 10:50
Eria4044 Eria4044 is offline
None #0935 (Railerobotics)
Team Role: Webmaster
Eria4044 is on a distinguished road
Send a message via Yahoo to Eria4044
Re: Turbulence
How powerful would the fan be? If the shooter just aimed a little lower, the fan might blow the ball into the goal (assuming that their targeting isn't slaved to the camera). Still, it's a good idea, and the only (legal, reasonable, reliable) one I've heard this far for blocking a shooter.
Team 935 web team captain.
The team website: http://www.railerobotics.com/
Unread 13-01-2006, 23:25
Tatsu Tatsu is offline
Audiophile and Physicist.
AKA: Tatsu Hashimoto
FRC #1072 (Harker Robotics Team)
Tatsu will become famous soon enough
Send a message via AIM to Tatsu
Re: Turbulence
We talked about this, the best way would be to get a commercial leaf-blower and gut out the insides, replacing the motor and creating a compatibility gearbox.. you'd get something like 220 mph winds upward..
buts its not graciously professional. so we're not doing it..
if anyone wants to try it, I'm definately willing to lend a hand ..
Unread 14-01-2006, 00:28
mechanicalbrain's Avatar
mechanicalbrain mechanicalbrain is offline
The red haired Dremel gnome!
FRC #0623 (Ohm robotics)
Team Role: Electrical
mechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond repute
Send a message via AIM to mechanicalbrain Send a message via Yahoo to mechanicalbrain
Re: Turbulence
I don't see why it's not gracious professionalism. I mean maybe it's just my interpretation but I don't think that just because you exhibit gracious professionalism why you can't be super competitive, or take advantage of a field element.
In 2004 team KillerBees had a brilliant autonomous mode idea. They did a drive by on the autonomous balls that did a early release of all those balls they stored over the player stations. Their robot continued to the end of the Field and then as soon as manual mode started they sucked up your balls and carried them off, leaving you at a distinct disadvantage. It wasn't ungracious and it wasn't unprofessional, It was smart. I say if you see a niche that can be filled and gives you an advantage without violating the rules or stopping others from enjoying FIRST then go for it! It's actually not too different then parking your robot in front of the lower goals to prevent people from scoring. Try telling teams they can't block balls because it's not fair, your going to see a lot of it anyway and why not? It's smart and makes sense.
On a more technical view, I'm not sure how well it would work. One thing to consider is that the air will dissipate pretty quickly. I mean I can't remember seeing a leaf blower with more then 10 ft of range (though we do have stronger motors). Also leafs are pretty light, will it have enough force to move a ball? how about move a ball traveling at a high velocity? I recomend using more like a cannon in that you aim it slightly at a angle to slow the ball and displace the balls trajectory. I'm going to take a look at the inside of my leaf blower to see if it's gears could handle our motor's.
"Oh my God! There's an axe in my head."
623's 2006 home page
random mechanicalbrain slogans
Unread 14-01-2006, 02:57
Re: Turbulence
Rephrase - whats what my team thinks. therefore we will not be doing that =p. I think it might be ever so slightly ungracious but eh, you're right, its not that big of an issue
I've already figgured out how to do this if you're interested.. you point it at a 75 degree angle, bot at the edge of the ramp. even if air dissapates, your barell should be exactly at 6 ft, you have only 2.5 ft to traverse... thats pretty $@#$@#$@#$@# easy with a 220 mph... now we'll assume ball is traveling at somewhere around 7 m/s towards the goal.
lets say you halve the flow-speed every meter.., (probably accurate) 98.34 m/s = 220 mph. now, we have a 2.5 ft gap or .762 meters..
so thats around 57 m/s air flow around the ball, this may or may not be significant.. now for the drag calculation...
we can use http://www.fluidmech.net/jscalc/cdre01.htm to calculate force
which is 6.24 newtons.. m =.18 kg , therefore a is 34m/s^2 !!!. This only increases as you go closer.... a 34 m/s^2 accleration is definatley nontrivial.
this makes a few assumptions ..
a). halving for every meter.. likely but could be optimistic
b). that you're only targeting the nozzle width, a wider nozzle would decrease v.
c). the key is how fast you can get the fluid (air) to go. If you can pump air at around 220 mph (commercial 7 amp leaf-blower) then you've blocked the goal for good.
a few problems
a). 220 mph is under small nozzle width, blocking a 1 m goal may not be best
b). motor may not be powerful enough compared to the beasts in leaf-blowers
c). 7 amps is alot.. you have 12 ampere-hours on that battery, yes you'll drain that sucker in less than an hour with nothing else running... that, is frightening.
Also I dont think you can even draw 7 amps (correct me if im wrong)
Unread 14-01-2006, 03:07
Sachiel7's Avatar
Sachiel7 Sachiel7 is offline
<Yes I managed to flip it
AKA: Shayne Helms
FRC #1132 (RAPTAR Robotics)
Sachiel7 is just really niceSachiel7 is just really niceSachiel7 is just really niceSachiel7 is just really niceSachiel7 is just really nice
Send a message via AIM to Sachiel7
Re: Turbulence
I don't think finding a way to defend the center goals is un-Gracious Professionalismistic (wow).
Our team is considering options other than air, but I expect to see quite a few teams out there with methods of blocking it...
edit:forgot to answer the last post. Uh, yeah you can draw through either 20, 30, or 40 amp breakers.
-=Sachiel7=-
There's no such thing as being too simple!
Look for Team #1132, RAPTAR Robotics at the VCU Regional this year!
Unread 15-01-2006, 13:53
I'mwithstupid^'s Avatar
I'mwithstupid^ I'mwithstupid^ is offline
I'mwithstupid^ is on a distinguished road
Re: Turbulence
ya dude 7 amps isn't alot chill
Unread 15-01-2006, 14:49
Max Lobovsky's Avatar
Fold em oval!
FRC #1257 (Parallel Universe)
Re: Turbulence
That's probably 7 amps at 120V or about 840 watts. You almost had me thinking this was a feasible idea...
Additionally, that may be a high acceleration, but a ball travelling at 10m/s passing through a .3m (1ft) blowing area will be in that region for 0.03 seconds.
Team 1257
Unread 15-01-2006, 17:35
Robots!
AKA: Ara Kourchians
FRC #0589 (FalkØn)
Re: Turbulence
It's possible, even a low amount of turbulence can turn the curve of the ball into the wrong direction.. as long as it doesn't hit an audence member I think it might be legal... hmmm ... if the fan is facing the audience and you curve the ball from another robot into the audience. Would they blam you or the other team? because you never touched the other ball (jk, btw you don't want to hit any audience members.. bad rep= not good)
Callsign: N6ARA
Unread 15-01-2006, 18:33
Gdeaver Gdeaver is offline
FRC #1640
Re: Turbulence
After some informal testing yesterday, I can say that a leaf blower is very effective at deflecting balls from the center goal. However, taking a commercial back pack blower and adapting the available motors to supply the rpm's and power needed is most likely not do able with the First motors and power supply. Oh well back to the hunter, seeker, whacker defensive strategy.
Unread 15-01-2006, 20:03
in between teams
AKA: Luke Van Oort
Re: Turbulence
Why not suck instead of blow? With some sort of motor running a fan (not that hard to make, weld a couple bits of sheet metal to a collar) you could suck them into a hopper. Sure the range might suck (well maybe not, last year's fisher price at 24000 rpm could probably pull a good amount of air) and you'd need mesh over everything to keep from chewing up stuff. Speaking of which, you'd need to watch wiring and tubing to make sure the suck/blow force of the fan doesn't unplug it. (not really an issue with tubing, but those pwms are screwed.)
Team 1219: 2009 - Mentor
Unread 15-01-2006, 20:11
phrontist's Avatar
phrontist phrontist is offline
Proto-Engineer
AKA: Bjorn Westergard
FRC #1418 (Vae Victus)
phrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond repute
Send a message via AIM to phrontist
Re: Turbulence
Errr... sucking would require much, much, more energy.
University of Kentucky - Radio Free Lexington
"I would rather have a really big success or a really spectacular crash and failure then live out the warm eventual death of mediocrity" - Dean Kamen
