Go to Post I'm down with banning the Chicken Dance (and take the Macerena with you when you go)! - Koko Ed [more]
Unread 08-01-2006, 17:22
want2modmygt's Avatar
want2modmygt want2modmygt is offline
AKA: Will
#0494 (Team RUSH 27 (2 years) -----> Goodrich Martians)
Team Role: Electrical
want2modmygt is on a distinguished road
Super flexible Wire
I did a search, and got nothing, so here's my question. I'm looking at purchasing wire from Terminal Supply. I want red and black in all the awg's necessary to build this year's robot, and I want to get the really flexible stuff, that is like rope. I'm looking at GPT and GXL wire. I'm also looking at ones with high strands. like part number 18 GPT or 16 GPT. Those are the correct sizes for flexible wire right? and if so, is it better to get the GPT stuff insulated in PVC, or the GXL stuff insulated in SAE polyethelene?
heres a link to the terminal supply wire catalog
http://www.terminalsupplyco.com/prod...atalog_pdf.asp
Austin D--- if you happen to know what the specs on the wire that mr. henderson brought us a couple years ago, let me know that stuff was amazing!
thanks for all your help.
www.cardomain.com/id/redbeauty2006
my 1997 GAGT
Unread 08-01-2006, 17:43
mechanicalbrain's Avatar
mechanicalbrain mechanicalbrain is offline
The red haired Dremel gnome!
FRC #0623 (Ohm robotics)
mechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond repute
Send a message via AIM to mechanicalbrain Send a message via Yahoo to mechanicalbrain
Re: Super flexible Wire
http://www.robotmarketplace.com/marketplace_wire.html <-- The best their is. If you don't mind going with 12 gauge, Deans wire is described as wet noodle (1660 strands). Ive used it before. It's pretty amazing stuff.
"Oh my God! There's an axe in my head."
623's 2006 home page
random mechanicalbrain slogans
Unread 08-01-2006, 17:47
AKA: Will
Originally Posted by mechanicalbrain
http://www.robotmarketplace.com/marketplace_wire.html <-- The best their is. If you don't mind going with 12 gauge, Deans wire is described as wet noodle. Ive used it before. It's pretty amazing stuff.
thanks although i know terminal supply has the stuff i want. i just want to know what stuff it is. if i can't figure it out, ill probably go with the dean's wire stuff.
my 1997 GAGT
Unread 13-01-2006, 11:11
emusteve's Avatar
emusteve emusteve is offline
AKA: Steve Martin
#0470 (Alpha Omega)
emusteve is just really niceemusteve is just really niceemusteve is just really niceemusteve is just really nice
Try looking for test lead wire. High strand count, flexible and durable.
Steve
Unread 13-01-2006, 11:32
Steve,
You might not find test lead wire in #10 or # 6. I suggest you all look at the MCMINONE website. They have excellent zip cord in guages all the way up to # 6 which is fairly flexible. It will not have the flex of "rope lay" cables but is not expensive of heavy. The super flex cables should be available anywhere auto stereo accesories are sold in your area.
Unread 13-01-2006, 11:33
MikeDubreuil's Avatar
Carpe diem
FRC #0125 (Nu-Trons)
Last year my team used car speaker wire and we plan on doing the same this year. We usually use Street Wires 12-gauge and 14-gauge "Ultra Wire" for our motors and solenoids. It's a great wire to use because the positive and negative are enclosed in a plastic tube making it easier to route the wires. It's also multi-stranded making it very flexible.
We buy the wire from Crutchfield.com for $0.50 to $0.80 per foot.
Unread 13-01-2006, 12:53
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Deans wire is pretty expensive if my memory serves me correctly.
If you are looking for 6ga, I would recommend welding cable from http://www.delcity.net/. If you are looking for 10 ga, I would recommend the wire on this page http://www.partsexpress.com/webpage....ctGroup_ID=478 They also have some nice 12ga zip cord we have used
Unread 15-01-2006, 21:35
Rick Thornbro Rick Thornbro is offline
#0217 (ThunderChickens)
Rick Thornbro will become famous soon enoughRick Thornbro will become famous soon enough
Be careful with the insulation of the wire you use. Black "clear" wire when installed is brown in color, a violation of rules. We had some problems with inspectors last year.
Unread 18-01-2006, 16:38
AKA: Will
thanks for the advice. ill remember that. i don't wnat to make any inspectors mad, but i also want only solid red, and solid black wires on the robot. (other than PWM's).
my 1997 GAGT
Unread 18-01-2006, 17:33
So that there is no confusion, solid wire (no strands) will break due to the extreme motion of these robots. Murphy's law dictates that it will happen at the worst possible time.
If however, you are speaking of color, solid colors are best. Following the color code not only helps inspections it helps out someone who is trying to help you find a problem.
Unread 18-01-2006, 18:39
occra 23.
AKA: ryo
None #1481
i highly reccomend deans wet noodle. local hobbyshops will have them too. i htink. ones around here do. only wire i use on my rc cars. hopefully we'll have the resources to use them for our robot this year. yes they arent as cheap as others tho
Cutting wire on backup battery MikeDubreuil Electrical 4 23-02-2004 18:55
Wire Gauge Question Neghman Electrical 1 14-02-2004 19:56
Reliable Connections to the fuse blocks. Al Skierkiewicz Electrical 0 09-02-2004 12:01
Telephone wiring Lisa Rodriguez Chit-Chat 4 18-06-2003 00:22
Motor wire sizes Tim Skloss Motors 5 13-02-2002 07:44
