Go to Post You should never, EVER bully, manipulate, or slander another team for the sake of winning. - Libby K [more]
Unread 13-01-2006, 12:17
Biff Biff is offline
AKA: Tom Cooper
#1227 (Techno Gremlins)
Biff is a jewel in the roughBiff is a jewel in the roughBiff is a jewel in the roughBiff is a jewel in the rough
Re: pic: cathode light assembly
Originally Posted by ApexZ3
What type of PSU did you hook the box up to. How many volts too, we finished the box, but our leader is a bit scared that we might fry it. Whom ever tells us the PSU and the Voltage thanks, its greatly apreciated.
I tested one of the assemblies and it draws 650ma when cold and as I recall got to 800ma after about 5 minutes running, I also tried both 14v (typical 12 volt supply) and a 12v gel cell, Not a big difference in current. So to sum up 4 times 800ma gets you 3.2 amps at 12 to 14 volts So a 3.5 amp or greater 12v (14v) supply should be fine don't forget a in-line fuse unless you supply is auto sensing of a short or over load.
Unread 13-01-2006, 21:42
skimoose's Avatar
skimoose skimoose is offline
Parent/Mentor/Engineer
AKA: Arthur Dutra
FRC #0228 (GUS)
Team Role: Electrical
skimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond repute
we just ignored the entire chassis mod/creating a box, and just stuck ours directly to the back of the HDPE sheet.
A quick solution to get your camera calibrated, but how's it going to stand up to constant shelling from poof balls?
2009 CT Regional Motorola Quality Award
2010 VRC Connecticut Championship Winners & Amaze Award
2010 VRC Championship Divisional Energy Award
2010 WPI Regional Winner
2010 WPI Regional Engineering Inspiration Award
2011 WPI Regional Chairman's Award
2012 WPI Regional Finalists
Unread 14-01-2006, 00:33
KTorak's Avatar
KTorak KTorak is offline
Fire Rescue 47
AKA: Kyle Dersch
FRC #1023 (Bedford Express)
Team Role: Driver
KTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond repute
Send a message via AIM to KTorak
My team actually built a really nice box from some 2x4s and plywood. I'll bring my camera and take pictures tomorrow if I remeber to...
Kyle D- Myspace - Facebook
2008 Bedford Express Driver & Build & Design (Team) Co-Leader
2007 Bedford Express Driver & Build & Design (Team) Leader
2006 Bedford Express Driver, Build Team Member, & Board of Directors
2005 Bedford Express Rookie, Build Team Member & Robot Operator
2008 - GLR Quarter Finalist
2007 - GLR Finalist & Boilermaker Finalist & MARC Off Season Event Winner
2006 - GLR Johnson & Johnson Sportsmanship Award & Archimedes 7th Seed Quarter Finalist
2005 - GLR Finalist & Judges Award.
2004 - GLR Semi Finalist.
2003 - GLR/DTR Quarter Finalist & GLR/NAT'L Rookie All Star.
Unread 14-01-2006, 09:35
Doug G's Avatar
Doug G Doug G is offline
Coach / Teacher
FRC #0701 (Robovikes)
We built ours much the same way, a 2x4 frame, some sheet aluminum on the back, but it just doesn't seem bright enough. We may try lining the inside with foil next.
Unread 14-01-2006, 23:08
elknise's Avatar
elknise elknise is offline
AKA: Erik Knise
FRC #1318 (Issaquah Robotics)
elknise will become famous soon enoughelknise will become famous soon enough
At first outs was extremely dim, after about 3 minutes it got brighter, then I walked down to the wood shop to get some tools, and when i got back about 10-15 minutes later, it was very bright. I believe that the lights just need to worm up..
Our box took about an hour to make and about 30 minutes to wire. I wired it up to one of our 12v batteries and used a breaker panel from 2 years ago and a 20amp fuse to power it.
I was just wondering if anyone else used the correct offset for the lights from the diffuser panel?
Also, ours was plenty bright with just wood, has anyone compared a wood box to the official boxes to see how the light compares?
Elknise
Issaquah Robotics
Unread 15-01-2006, 09:27
AV_guy007's Avatar
AV_guy007 AV_guy007 is offline
AKA: Sam
FRC #0177 (bobcats)
AV_guy007 has much to be proud ofAV_guy007 has much to be proud ofAV_guy007 has much to be proud ofAV_guy007 has much to be proud ofAV_guy007 has much to be proud ofAV_guy007 has much to be proud ofAV_guy007 has much to be proud ofAV_guy007 has much to be proud ofAV_guy007 has much to be proud of
we used aluminum and a 12v battery and it was bright almost instantly . i dont think they have to warm up.
Team 177
bobcat robotics
BLUE ALLIANCE CREW MEMBER
Next event attending: Kickoff 08- Manchester NH With TBA
Unread 15-01-2006, 12:13
skimoose's Avatar
AKA: Arthur Dutra
FRC #0228 (GUS)
cold cathodes do need to warm up for maximum light output.
Unread 29-01-2006, 19:27
coldabert's Avatar
coldabert coldabert is offline
The Dude
FRC #0888 (Robotiators)
coldabert is a glorious beacon of lightcoldabert is a glorious beacon of lightcoldabert is a glorious beacon of lightcoldabert is a glorious beacon of lightcoldabert is a glorious beacon of light
Send a message via AIM to coldabert
4 hours of work? i can understand taking your time, but you had nothing better to do?
ProE Assembly Editing daramana Inventor 5 31-01-2005 13:21
pic: Swerve Assembly CD47-Bot Extra Discussion 3 23-01-2004 20:02
TCP/IP on a PIC Venkatesh Electrical 1 18-11-2003 21:00
About the light that need to be seen from four side archiver 2000 3 23-06-2002 23:01
How many posters does it take to change a lightbulb? Brandon Martus Chit-Chat 7 22-02-2002 19:48
