Go to Post I am proud whenever I turn to a team during inspections and say "OK I just need two signatures here and I will go get your sticker, you passed!" - Al Skierkiewicz [more]
View Poll Results: How important is it to collect loose balls from the playing surface?
Not important -- clearly irrelevant 5 4.20%
Somewhat important 25 21.01%
Very important 46 38.66%
Critical factor -- you have to be able to collect loose balls 36 30.25%
What? I thought this was about tetras? 7 5.88%
Voters: 119. You may not vote on this poll
Unread 13-01-2006, 12:24
dhitchco's Avatar
dhitchco dhitchco is offline
Awards/Photo/Video "wizard"
AKA: Doug Hitchcock
FRC #1511 (Rolling Thunder)
dhitchco has a brilliant futuredhitchco has a brilliant futuredhitchco has a brilliant futuredhitchco has a brilliant futuredhitchco has a brilliant futuredhitchco has a brilliant futuredhitchco has a brilliant futuredhitchco has a brilliant futuredhitchco has a brilliant futuredhitchco has a brilliant futuredhitchco has a brilliant future
Re: Loose Balls
How important will it be to design a bot to pick-up loose balls? Ask yourself, how many loose balls will there be in a match? Loose balls come from the following:
1) They fall out of robots that have been pre-stored with (up to) 10 balls at the beginning of the match. This is not a likely source of loose balls even if a robot gets jostled.
2) They fall onto the field from failed shots at the upper 3-point goal. This is likely to be the biggest source of loose balls to be gobbled up
3) The fall onto the field in the process of your bot trying to push/dump them into the side goals. This also is a high-probability source for loose balls
4) The fall onto the field after being put into play by the three human players (either missing a side-goal shot or missing their own 'bot refill). Also a pretty high probability of happening.
5) They are put onto the field by the field judges after they have bounced/flown out of the field. This could be caused by any number of random events. My best guess is that at least 10 balls per match will get re-introduced to the field of play by the judges....
So, overall, I'll guess that any design which does NOT take into account the need to pick-up loose balls on the field will always have to make a LONG trip home to be refilled and/or will simply be missing out on the need to bve a "hunter/gatherer".....
The THUNDER just keeps getting LOUDER in 2008....
Team 1511 now supports over 15 FLL teams
RollingThunder....Winner of the 2007 Chairman's Award at Finger Lakes Regional and Spirit Award at Boston.....Winner of 2006 Finger Lakes Regional Engineering Inspriation and Boston Imagery awards.......Winner of 2005 World Championship Rookie All-Star (plus FLR Rookie All-Star, Buckeye Top-Seeded Rookie, GTR Champion, Spirit, and Inspiration)
"Gracious Professionalism is a WAY of life".....
POLL: have small balls been abandoned? Solace General Forum 44 04-09-2004 17:53
New Jersey Regional Status Aignam Regional Competitions 144 21-07-2004 17:04
Thoughts on the competiton balls Petey Regional Competitions 26 14-03-2004 09:31
Team 188 Pictures - four big balls anyone? archiver 2001 6 24-06-2002 01:03
Will ANYONE mess with the black balls? archiver 2001 0 23-06-2002 22:35
