| View Poll Results: How important is it to collect loose balls from the playing surface? | |||
| Not important -- clearly irrelevant |
5 | 4.20% |
| Somewhat important |
25 | 21.01% |
| Very important |
46 | 38.66% |
| Critical factor -- you have to be able to collect loose balls |
36 | 30.25% |
| What? I thought this was about tetras? |
7 | 5.88% |
| Voters: 119. You may not vote on this poll | |||
#14
Re: Loose Balls
The way I see it is that if your entire alliance depends on balls from the human players, then you've pretty much resigned yourself to playing catch up. Every ball you have in your player station is a point the other team has scored on you, after all. If the other alliance exclusively shoots three pointers, then the best you can do is match their points. Hrm. I should make a note of this if we're against an alliance than can't scoop. Should just concentrate on hitting every 3 we fire and starving them....
| POLL: have small balls been abandoned? | Solace | General Forum | 44 | 04-09-2004 17:53 |
| New Jersey Regional Status | Aignam | Regional Competitions | 144 | 21-07-2004 17:04 |
| Thoughts on the competiton balls | Petey | Regional Competitions | 26 | 14-03-2004 09:31 |
| Team 188 Pictures - four big balls anyone? | archiver | 2001 | 6 | 24-06-2002 01:03 |
| Will ANYONE mess with the black balls? | archiver | 2001 | 0 | 23-06-2002 22:35 |
