Go to Post Sleep?! How am I supposed to do that with the build season done?! There are still practice bots to make! - [more]
Unread 12-01-2006, 15:02
MikeDubreuil's Avatar
Carpe diem
FRC #0125 (Nu-Trons)
Re: Charging 7.2V Backup Battery
Originally Posted by Al Skierkiewicz
3. Many of you seem to be fully on board with a 12 volt charging circuit operated from the main battery. I am not, as it adds weight to your robot and steals power from the main battery. Simple buy two backup batteries and charge one while you use the other on the robot. If you find that you require higher current (due to multiple servos in your design) Digikey or other vendors can assemble battery packs in any current or package size you might desire.
I guess I'm on board with the idea for a couple reasons.
  • I think adding the charging circuit will more fit the notion that the 7.2V battery is a true backup. I think it was a great mistake for IFI to power external devices through the 7.2V battery. I do like how the backup keeps the RC alive during brownouts. By adding the power charging circuit it makes the RC more the way I wished it was.
  • I think the added weight will be negligible.
  • The backup battery does not have to be easily accessible with a sturdier mounting system.
Either way you look at it there are engineering trade offs. I just feel the benefits of never having to manually charge the backup are worth the added weight.
Unread 12-01-2006, 22:14
in between teams
AKA: Luke Van Oort
Originally Posted by sanddrag
I own at least 8 NiCd batteries and I've never had a single one cause harm to me or the environment. Are you talking about when they are disposed of? If so, what can 1100 little batterypacks, that are each at a minimum of a few miles apart, do to a whole world of an environment? If we are talking about ALL NiCd batteries (not just in FIRST), then you may have a point if there are studies to back it up.
I am talking about all NiCds and cadmium in general. FIRST may not be affecting the environment on it's own, but neither does a car. However, if you use cars for lots of things you get tons of pollution. For cadmium's toxicity:
http://en.wikipedia.org/wiki/Cadmium
http://risk.lsd.ornl.gov/tox/profiles/cadmium.shtml
http://www.epa.gov/ttn/atw/hlthef/cadmium.html
Team 1219: 2009 - Mentor
Unread 12-01-2006, 22:50
DonRotolo's Avatar
Back to humble
FRC #0832
<snip>If you find that you require higher current (due to multiple servos in your design) Digikey or other vendors can assemble battery packs in any current or package size you might desire.
I don't see anywhere in the rules where it states you can use an alternative 7.2 volt backup battery. As I interpret the rules this year, you must use the one supplied. EDIT: My interpretation is indeed wrong, <R68> is clear that any 7.2 volt battery can be used. Sorry for the bad info (and thanks, Alan A.)
Originally Posted by roboticsguy1988
Well it would actually be simple to come up with a circuit that charges it anyway. As long as it went along with all the rules.
I agree, but teams designing such a charging circuit MUST consider the safety aspects of such a device, specifically that it really must be a charger and not just a voltage source. A simple voltage source runs the risk of overcharging the battery.
A good choice for such a charger circuit would be the MAX 713 which is available from almost everyone, and also comes in a 16-pin DIP package (so you don't have to mess with surface mount stuff).
Don
Unread 12-01-2006, 22:57
You'll find it in the Control System Rules.
<R68>The 7.2V Robot Control backup battery must be connected to the Controller as described in the Controller’s manual. The 7.2v battery should be charged to at least 7.0v before entering a match. As a replacement for the FIRST supplied battery, any other 7.2V NiCad battery pack may be used.
Unread 12-01-2006, 23:02
roboticsguy1988's Avatar
roboticsguy1988 roboticsguy1988 is offline
Larry Johnston
AKA: Larry Boy
FRC #1501 (Team THRUST)
Team Role: Electrical
roboticsguy1988 has much to be proud ofroboticsguy1988 has much to be proud ofroboticsguy1988 has much to be proud ofroboticsguy1988 has much to be proud ofroboticsguy1988 has much to be proud ofroboticsguy1988 has much to be proud ofroboticsguy1988 has much to be proud ofroboticsguy1988 has much to be proud ofroboticsguy1988 has much to be proud of
Send a message via ICQ to roboticsguy1988 Send a message via AIM to roboticsguy1988 Send a message via MSN to roboticsguy1988 Send a message via Yahoo to roboticsguy1988
After reading through the rules i don't really see anything that would violate them as far as creating a custom charger circuit for the 7.2V battery.
As far as weight goes.... we are talking about a circuit board with some components on it. It shouldn't weigh that much.
I just mainly wish i could get the IFI design. That way there would be no worry at all of the inspectors saying "you can't have that".
Larry Johnston, Team THRUST, Team #1501, Team THRUST webpage
2005 IRI - Imagery and Design Award
2005 - 2006 BMR - Professional Grade Award
2006 BMR - Delphi Driving Tomorrow's Technology Award
"That can't be their 'bot. not nearly enough (if any) rivets to be a 1501 machine." ~ RogerR
~Da team that uses all tha rivets, Team #1501~
The FIRST Software Repository ~ Chief Admin
openFIRST ~ Project Supporter (Former editor)
DMOZ.org - FIRST - US Teams Section ~ Chief Editor
Unread 12-01-2006, 23:22
DonRotolo's Avatar
Back to humble
FRC #0832
Yes, I stand corrected. R68 is quite clear. Next time I'll read further along...
Don
Unread 13-01-2006, 11:58
fowlerm's Avatar
fowlerm fowlerm is offline
Bringing .NET to Robots
AKA: Matthew Fowler
FRC #0312 (Heatwave); FRC #1369 (Minotaur)
fowlerm has a spectacular aura aboutfowlerm has a spectacular aura aboutfowlerm has a spectacular aura about
IFI charger schematic is online here.
Unread 13-01-2006, 13:49
Larry Johnston
AKA: Larry Boy
Yeah i know i found it today. There was link at the bottom of the homepage. I wonder if it as there the whole time.... If so, that was my bad :-p
Unread 13-01-2006, 14:13
fowlerm's Avatar
AKA: Matthew Fowler
It wasn't there the whole time, they added it yesterday evening.
Unread 13-01-2006, 14:23
Larry Johnston
AKA: Larry Boy
Yeah i realized that after i printed it out. It got added yesterday on 01/12/06. So it wasn't there in the beginning but it got here in time.
Unread 13-01-2006, 14:25
That's a very odd looking circuit. I don't understand the point of the regulator, and I see nothing to prevent the backup battery from powering anything else that's connected to the main battery input.
Unread 13-01-2006, 14:47
Alan,
I agree, the only limiting factor is the big resistor between the main and backup battery. According to my calculations, the regulator is set for 8.26 volts output which at full charge will still attempt to pump about 45 ma into the battery with the controller turned off. With everything up and running, the zener will be turned on at 8.7 volts.
Unread 13-01-2006, 16:13
Makubesu's Avatar
Makubesu Makubesu is offline
None #1768
Makubesu is an unknown quantity at this point
Send a message via AIM to Makubesu
Charging the 7.2 Volt Batteries
We're trying to charge the 7.2 volt backup batteries you use for the control system, and we can't figure out how to do that. We looked through the kit of parts, and it seems that there is a charger for them, but closest thing we could find was a 9v charger. Is that alright to use? Or should we look through the parts again?
Unread 13-01-2006, 16:16
BrianBSL BrianBSL is offline
FRC #0190
BrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud of
I also see some weirdness in this circuit, but for anyone that wants to build it, I already put together the list of parts from Mouser. Sorry for the horrid formatting (this is a paste straight from their cart). The Tantalum cap's can probably be substituted for ceramics if you have them laying around or for cost reasons. Here are the part #'s that I chose:
610-CZ5345B   	 CZ5345B  	 Central Semi Diodes - Zener
DO-201 8.7V 5.0W
	$ 0.520
511-LM317T 	LM317T 	ST Voltage Regulators
TO-220AB 1.2-37V Adj Positive - RoHS COMPLIANT per producer documentation
	$ 0.460
625-1N5820 	1N5820 	Vishay Semiconductor Schottky Rectifiers
DO-204AL Vr/20V Io/3A BULK
	$ 0.290
271-221-RC 	271-221-RC 	Xicon 1/4W 1% Metal Film Resistors
221ohms 1% 50PPM - RoHS/Pb-FREE per producer documentation
	$ 0.090
271-1.24K-RC 	271-1.24K-RC 	Xicon 1/4W 1% Metal Film Resistors
1.24Kohms 1% 50PPM - RoHS/Pb-FREE per producer documentation
	$ 0.090
294-43-RC 	294-43-RC 	Xicon 1W 5% Carbon Film Resistors
43ohms 5% - RoHS/Pb-FREE per producer documentation
	$ 0.140
294-22-RC 	294-22-RC 	Xicon 1W 5% Carbon Film Resistors
22ohms 5% - RoHS/Pb-FREE per producer documentation
	$ 0.140
80-T350A104K035 	T350A104K035AS 	Kemet Dipped Radial Tantalum Capacitors
35V 0.1uF 10% - RoHS non-compliant/CONTAINS Pb
	$ 0.300
My posts represent my personal views only, and do not represent the views of either my team, Team 190, nor its primary sponsor, Worcester Polytechnic Institute.
Unread 13-01-2006, 16:17
Carpe diem
Re: Charging the 7.2 Volt Batteries
If you look in the box from Innovation First you should see a 7.2V battery charger.
Batteries and hard impacts ConKbot of Doom Electrical 1 19-02-2005 13:39
7.2 Volt Battery Justin_302 Electrical 4 28-01-2005 23:25
Batteries Exide 2005 Quanity Mike Martus Electrical 6 13-01-2005 19:44
Charging Batteries like_a_fox Electrical 10 15-03-2004 17:57
HELP - We have no batteries!! Rick Gibbs Championship Event 3 24-04-2002 19:07
