Go to Post I love how your suggestion for MCC is one of the most elite robots of the year, and one of the World Champions. I also love that I really can't argue with you. - JVN [more]
Unread 12-01-2006, 20:56
railerobotics's Avatar
railerobotics railerobotics is offline
FRC #0935
railerobotics will become famous soon enough
Can't find CMUCam2 demo.llb
We cannot find CMUCam2 demo.llb like mentioned in the camara workbook. Do we download it or is it somewhere else? Please help us.
Unread 12-01-2006, 21:23
Re: Can't find CMUCam2 demo.llb
I think http://www.chiefdelphi.com/forums/fo...play.php?f=149 might help you find what you're looking for.
Unread 13-01-2006, 13:51
FRC #0935
No, we have already looked there. Where do we download the CMUCam2 demo.llb application used in Lab View 8.0 like mentioned in the camara workbook? We have searched and searched on the web but have failed miserably. Did this application come in the kit?
Unread 13-01-2006, 13:56
pbrules15 pbrules15 is offline
AKA: Ronny
pbrules15 is an unknown quantity at this point
WHERE IS IT?????????????????????????
Unread 13-01-2006, 14:25
fowlerm's Avatar
fowlerm fowlerm is offline
Bringing .NET to Robots
AKA: Matthew Fowler
FRC #0312 (Heatwave); FRC #1369 (Minotaur)
fowlerm has a spectacular aura aboutfowlerm has a spectacular aura aboutfowlerm has a spectacular aura about
You can get it here. The password to extract the contents of the zip file is "LVFRC2006!" case sensitive and without the quotes.
Kingofl337's Avatar
You didn't see anything....
AKA: Adam
FRC #0501 (Power Knights)
If you use easyC for FRC the camera values for the target are preloaded in the software. If you upload Tutorial #7 to your robot it should folow the target.
Unread 13-01-2006, 14:56
Danny Diaz's Avatar
Danny Diaz Danny Diaz is offline
Smooth Operator
AKA: FrankenMentor
None #0418
Danny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond repute
Send a message via AIM to Danny Diaz
Be careful about posting exact links to this file, the filename and/or location can change, it is best to look here:
http://www.chiefdelphi.com/forums/f...splay.php?f=149
The sticky post will always point to the correct link. Also note that now the files are not password-protected.
-Danny
Danny Diaz
Former Lead Technical Mentor, FRC 418
Unread 13-01-2006, 16:41
FRC #0935
Thanks
Unread 13-01-2006, 16:56
FRC #0935
Now that we have the application and have it on the computer in lab view, we cannot get it to run. I click the little arrow and a little error window pops up and says something like that we need to check our serial port or see if the camara has power. The serial port is fine, we spent hours checking it. And the camara has power. WHATS WRONG??? Please help us.
Unread 13-01-2006, 17:43
Danny Diaz's Avatar
Smooth Operator
AKA: FrankenMentor
None #0418
Originally Posted by railerobotics
WHATS WRONG???
Could be a number of things.
1. Make sure the backup battery is FULLY CHARGED.
2. Make sure you've installed the latest version of the NI-VISA software in your computer.
3. Make sure you've configured your serial port to the correct speed via Measurement and Automation Explorer.
4. Make sure the serial port specified in the application is the correct serial port the serial cable is plugged into.
5. Make sure the backup battery is FULLY CHARGED.
6. Make sure you've read the documentation provided with the Camera App.
7. Make sure your serial cable is good.
8. Make sure the camera is correctly set up and everything is plugged in snugly (especially the lens daughterboard).
And above all, make sure your backup battery is fully charged.
-Danny
Danny Diaz
Unread 13-01-2006, 18:12
FRC #0935
thanks, it now works. The file we were missing mi-visa was in the documention of the frc camara.
Unread 13-01-2006, 18:17
FRC #0935
You said, "If you use easyC for FRC the camera values for the target are preloaded in the software. If you upload Tutorial #7 to your robot it should folow the target." Where is "Tutorial #7"?
Unread 13-01-2006, 20:07
FRC #0935
We have another porblem. We can now get CMUCam2 demo.llb to run, but when we try to capture a frame we get an error. But our serial cabel is connected and the camara has power. So why do we get this!? help
Unread 14-01-2006, 04:23
Joe Hershberger Joe Hershberger is offline
National Instruments
AKA: jhersh
FRC #2468 (Appreciate)
Joe Hershberger is a name known to allJoe Hershberger is a name known to allJoe Hershberger is a name known to allJoe Hershberger is a name known to allJoe Hershberger is a name known to allJoe Hershberger is a name known to all
There was a bug in the get picture.vi that caused problems grabbing frames, especially if you are using a USB to Serial converter. There is an update posted here.
Good luck!
-Joe
Unread 14-01-2006, 10:19
FRC #0935
That has been already downloaded. But now, we can start the program without any errors then when clicking the "grab frame" button it downloads all the way and no picture appears on the screen, and it restarts itself over and over. What's wrong?
Example LabVIEW Apps - Dashboard, CMUcam2 and Motors Russ Beavis National Instruments LabVIEW and Data Acquisition 9 21-01-2007 17:19
CMUcam2 disclaimer Cody Carey General Forum 4 12-01-2006 01:19
CMUcam2 interfacing Kram Programming 2 27-05-2005 07:17
CMUCam2 Camera Code - Are important parts commented out? Mr. Lim Programming 4 14-01-2005 12:11
3dmax - setting a display option that I can't find DanL 3D Animation and Competition 5 05-01-2003 12:42
