Go to Post Kit wheel? Someone probably has them. N-tooth IFI sprocket? You might get lucky. Part Made By A Local Company When You're Competing 800 Miles Away? Bring three. - Billfred [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
Unread 13-01-2006, 15:32
cbolin's Avatar
cbolin cbolin is offline
Programming & Electrical
FRC #0342 (Burning Magnetos)
cbolin is a splendid one to beholdcbolin is a splendid one to beholdcbolin is a splendid one to beholdcbolin is a splendid one to beholdcbolin is a splendid one to beholdcbolin is a splendid one to beholdcbolin is a splendid one to behold
Ball Damage
Hi,
After test firing for an hour (about 150 test shots) we stripped off about 10 - 15% of the surface of the ball. The ball is still useable but sure is ugly. Any idea if there are limits to ball damage by a bot? Shooting a ball one time causes no noticeable damage...but 150 it becomes obvious to everyone.
Regards,
ChuckB
Team 342 Programming & Control Systems
Good luck and have fun!
Unread 13-01-2006, 15:36
generalbrando's Avatar
generalbrando generalbrando is offline
Build, Break, Repeat
AKA: Brandon Mensing
FRC #0246 (Overclocked)
generalbrando is a splendid one to beholdgeneralbrando is a splendid one to beholdgeneralbrando is a splendid one to beholdgeneralbrando is a splendid one to beholdgeneralbrando is a splendid one to beholdgeneralbrando is a splendid one to beholdgeneralbrando is a splendid one to beholdgeneralbrando is a splendid one to behold
Send a message via AIM to generalbrando
Re: Ball Damage
Generally in the past: Unless your robot rips a couple of new balls to pieces, the Ref usually won't even question it. They expect wear and tear. So if you mess up an old ball, no worries.
They'll replace balls as necessary to make sure they are reasonably consistent, but you have to take some variance into account in your design.
Lead Mentor of Team #246, Boston University Academy and Boston University, Overclocked
www.burobotics.org
Unread 13-01-2006, 15:41
Unglued Unglued is offline
AKA: Andrea Valenzuela
None #0865 (Warp7)
Team Role: Animator
Unglued is on a distinguished road
Send a message via AIM to Unglued Send a message via MSN to Unglued
Re: Ball Damage
i noticed that the part where the 2 colours meet seperates very easily, and once there's a rip it only gets worse.
however this dosn't take out any chunks of the balls, the foam stays intact.
by limit i guess you mean when a ball would be taken out of the game?
i think as long as the ball keeps it's original shape it'll be kept in play.. since balls can be scored on either net i doubt some colour wear would get them replaced.
unless they are worn down creamy coloured balls of foam?
anyways i apart from them being ugly i don't think you should worry.
Unread 13-01-2006, 15:58
Taylor's Avatar
Taylor Taylor is offline
Professor of Thinkology, ThD
AKA: @taylorstem
FRC #3487 (EarthQuakers)
Re: Ball Damage
Ball wear is a definite concern, especially for shooter bots. Any non-sphericalness (yeah, I just called up Noah Webster and had that put in the dictionary) will distort the ball's path. I've seen quite a few pics and movies around with people using belt sanders etc. to move balls - while I realize these are only mockups, similar methods will be used. So be advised - don't design a robot that is based on perfectly round balls.
Hi!
Unread 13-01-2006, 16:01
REVving up for a new season
FRC #2848 (All-sparks)
Re: Ball Damage
In 2001 the black balls which were inflatable became eggs. First just left them on the field as long at they were inflated. I suspect that balls will remain on the field as long as they can roll.
also just out of curiosity what kind of thrower are you using when you are messing up the balls, might it have something to do with the material the ball touches?
Greg Needel│www.robogreg.com
Co-founder REV Robotics LLC www.REVrobotics.com
2014 FRC World Champions with 254, 469, & 74
Unread 13-01-2006, 16:12
Billfred's Avatar
Billfred Billfred is online now
Re: Ball Damage
For reference, I put a question in at FIRST Q&A to see if they've set a criteria to determine when a ball is Too Pooped To Play. We shall see what we're going to have to deal with.
Unread 13-01-2006, 20:17
Nitroxextreme's Avatar
Nitroxextreme Nitroxextreme is offline
Relation to Mrs. Steve
AKA: Jon
FRC #1626 (Falcon Robotics ; 190 (Gompei and The Herd))
Nitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to behold
Send a message via AIM to Nitroxextreme
Re: Ball Damage
Also teams need to consider how much the ball will be broken in...
a new ball when compacted will shoot further than a used ball that isn't as tough and squishes easier
"He needed a chuck norris lesson in FIRST"...."I will give him a round house kick to the face...with gracious professionalism"
Unread 14-01-2006, 21:39
teh_masterer's Avatar
teh_masterer teh_masterer is offline
ub3r 1337 R0b0 d00d
AKA: Chewy Hollaway
FRC #1529 (Cyber Cardinals)
teh_masterer is an unknown quantity at this point
Re: Ball Damage
we played with the ball (in dodgeball fashion) around the shop and saw how much the ball was damaged after a few hours. Besides a few gashes and holes in the ball we seemed to make the ball alot less rounder than it was. Good thing we ordered an extra 24 we will have plenty more to use. When does first think the ball has expired?
Pwning n00bs since 2004
my hands are shakin'
my hearts a beatin'
im still shootin'
and im still gettin headshots!!!
BOOM, HEADSHOT!!
BOOM, HEADSHOT!!
Unread 14-01-2006, 21:44
Jeff Rodriguez Jeff Rodriguez is offline
Too young to be an 'old guy'
FRC #0155 (Technonuts)
Jeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond repute
Send a message via AIM to Jeff Rodriguez Send a message via Yahoo to Jeff Rodriguez
Re: Ball Damage
Originally Posted by Official FIRST Q&A by GDC
An official point of a ball not being useful has not yet been determined.
FIRST will attempt to get the maximum use of all playing objects, while still ensuring the objects are useful to teams.
Teams should not expect that all scoring objects will remain in an "as new" condition for the entire event.
http://forums.usfirst.org/showthread.php?p=473
173, student: 1999-2002
173, mentor: 2005-2010
155, teacher: 2011-
Unread 14-01-2006, 21:49
Leo 1529's Avatar
Leo 1529 Leo 1529 is offline
uber fabricata, webmasta, president
AKA: Tzu-san
FRC #1529 (Cyber-Cards)
Team Role: Webmaster
Leo 1529 has a spectacular aura aboutLeo 1529 has a spectacular aura aboutLeo 1529 has a spectacular aura about
Re: Ball Damage
What if a ball has split in half during a match. Like if it splits in half from being run over or just over use or shot too many times. How would FIRST score the two halves of the ball?
Unread 14-01-2006, 21:59
Andrew Blair's Avatar
FRC #0306 (CRT)
Re: Ball Damage
Well, if they were destroyed during firing, they probably wouldn't roll down to the camera for scoring. If they were run over, they probably wouldn't ever make it into a scoring area. Regardless, we will see a half of a ball score eventually.
-Sir Francis Bacon
-Albert Einstein
Unread 14-01-2006, 22:09
Leo 1529's Avatar
AKA: Tzu-san
Re: Ball Damage
I hope im there to get it on video so i can put it in this years robotics movie.
What about balls that get gashes or holes that might be still be playable. would anyone think that the balls should be allowed to still be used with some chunks taken out or gashes in them?
Unread 15-01-2006, 02:33
Rombus's Avatar
Rombus Rombus is offline
AKA: Rick Kosbab
FRC #4188 (Columbus Space Program)
Rombus is a jewel in the roughRombus is a jewel in the roughRombus is a jewel in the rough
Send a message via AIM to Rombus
Re: Ball Damage
im wondering if there going to keep vacuming the field after every 10 or so matches. All the junk comming off these balls might make some interesting field conditions!
Unread 15-01-2006, 20:04
Leo 1529's Avatar
AKA: Tzu-san
Re: Ball Damage
thats a good point the floor could get slippery in spots. Every match will differ because of the dust or parts of the ball getting ground into the carpet.
Unread 15-01-2006, 21:08
occra 23.
AKA: ryo
None #1481
Re: Ball Damage
also time to cover up those gears. im gonna hope theres no big enough chunks to jam roller chain tho..
Ball Recirculation Question Nuts4FIRST Rules/Strategy 23 15-01-2006 15:35
Experimental Ball Drive Sepsis900 Technical Discussion 16 31-10-2005 16:59
Low quality 2X ball? Rob General Forum 16 22-04-2004 22:36
Lip at ball chute opening Doug Traster Rules/Strategy 1 19-01-2004 01:33
Curie Division Robots information... (not complete) archiver 2001 3 24-06-2002 03:13
