Go to Post Great. Just what we need. DHS showing up at all the regional competitions. . - dlavery [more]
Unread 10-01-2006, 19:41
PuiChi PuiChi is offline
Confound it!
AKA: Bernice Yau
#0840 (ART)
PuiChi is an unknown quantity at this point
Large CIM Motors - Removing the sprocket
is there a way to use the large CIM motors without the belt system? We removed the belt tensioner and are unable to remove the belted gear from the drive shaft.
—PCBY
aragonrobotics.org
Unread 10-01-2006, 19:49
jonathan lall's Avatar
jonathan lall jonathan lall is offline
FRC #2505 (The Electric Sheep; FRC #0188 alumnus)
jonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond repute
Send a message via MSN to jonathan lall
Re: Large CIM Motors
You could probably pull it off with a press of some sort, though it seems like the gear is also bonded to the shaft a little too (hold a lighter to it and you'll see). I did notice Andy has an item for sale that should do the trick, although your team might already have access to a similar gear pulling tool.
Unread 10-01-2006, 23:05
Scott358 Scott358 is offline
Engineer/Mentor
AKA: Scott5736
FRC #5736 (Kingsmen)
Scott358 is just really niceScott358 is just really niceScott358 is just really niceScott358 is just really niceScott358 is just really nice
The sprocket on the "large" CIM does have an adhesive, and does comes off with a press.
- Scott358
Unread 13-01-2006, 15:40
Springman Springman is offline
FRC #0085 (BOB)
Springman is an unknown quantity at this point
Wink Re: Large CIM Motors - Removing the sprocket
We managed to split the pulley off with a chisel. I know this sounds harsh, but the pulley was very brittle, and split with very little force.
Unread 13-01-2006, 15:59
Many times the old ways are best, grasshopper.
Unread 13-01-2006, 16:01
emusteve's Avatar
emusteve emusteve is offline
AKA: Steve Martin
#0470 (Alpha Omega)
emusteve is just really niceemusteve is just really niceemusteve is just really niceemusteve is just really nice
Here's a twist...
Does any one know of a (hopefully not too expensive) source for the other pully and belt to go with it?
Also, how do you mount the sucker? There are no unocupied bolt holes in the frame of our motors! I was going to try t track down one of the Fisher Price scooters to look at their intended mounting, but no luck yet.
Steve
CIM Motors UlTiMaTeP Motors 13 10-01-2006 14:48
6 CIM Motors? psquared89 Kit & Additional Hardware 16 09-01-2006 08:47
Allowed to use CIM motors from last year? lphan Motors 7 26-02-2005 16:49
