Go to Post words of advice: never tease your dad about his receding hair line. it will come back to haunt you. trust me. - Brandon Martus [more]
Unread 13-01-2006, 17:06
Andrew Schuetze's Avatar
Andrew Schuetze Andrew Schuetze is offline
499 Founder / Alamo FTC & FLL AP
Andrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond repute
Exclamation Window Motor electrical connection
Am I missing something or did FIRST not include the pig tail connector for the window motors
I went through every bag and did not see one. If you haven't looked at these yet, they have a plastic housing with just two thin spades deep inside. The housing is integrated with the motor housing so you can't cut it off and expose wires.
After an hour, I found that the window motor from 2002 or 2001 had the exact same clip and I still had the matching pig tails. So I am set but would like to know what the official story is on these motors. Especially if I am missing something
APS
Founder FRC 499
Parent alumni FRC 2745 & 4219
Co-Coach FTC 4549 & 6407
Alamo FTC Affiliate Partner
Alamo FLL Affiliate Partner
Unread 13-01-2006, 17:14
Billfred's Avatar
Billfred Billfred is offline
Re: Window Motor electrical connection
According to the Good Practices manual (page 8), they didn't include the quick-connect Packard connector (part number 12129486). A search for a supply of them is underway.
Meanwhile, they suggest the 14-16 ga. slip-on crimps from Terminal Supply, part BB-8185, or Stakon's RB14-110F.
Unread 30-01-2006, 23:36
JoshuaFreier JoshuaFreier is offline
FRC #0467 (Duct Tape Bandits)
JoshuaFreier will become famous soon enough
Send a message via Yahoo to JoshuaFreier
FIRST has also said it is legal to solder leads onto the pins.
See:
http://forums.usfirst.org/showthread.php?t=458
or
http://forums.usfirst.org/showthread.php?t=410
Joshua
Hope is a good thing, maybe the best of things...
...and a good thing never dies.
Unread 31-01-2006, 09:39
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
I have my contacts at Delphi looking for a source for the terminals & connector for the window motor.
So far, I have the attached print. The print shows that the connector part number listed is good (12129486). It lists the terminal part number as (12110847). We have to confirm that the part numbers for the terminal is good and find a source...
...still working...
Joe J.
Team #88, TJ2
Unread 31-01-2006, 11:00
Stu Bloom's Avatar
Stu Bloom Stu Bloom is offline
I REALLY want to be Andy Baker
FRC #1018 (RoboDevils)
Stu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond repute
Send a message via AIM to Stu Bloom Send a message via Yahoo to Stu Bloom
Thanks Joe,
I suppose if/when you find a source you will let them know they are likely to be SLAMMED with orders when you make their contact info public ...
BTW ... what would it take for me to get a little "pre-publication" email notice of availability?
Stuart Bloom
Mechanical Engineer
Rolls-Royce Corporation
FIRST Team 1018 - Pike HS RoboDevils
My activity for 2012:
  • Boilermaker planning committee
  • Israel Head Ref - DONE (and it was FANTASTIC!)
  • Boilermaker Regional (with 1018) - DONE
  • Midwest Head Ref - DONE
  • WORLD Championships (with 1018) - DONE
  • IRI Head Ref - DONE
  • CAGE Match Head Ref
Unread 31-01-2006, 12:25
AKA: Dr. Joe
FRC #0088 (TJ2)
More digging, haven't found a pony yet...
There is good data on Delphi Packard connectors here: http://www.powerandsignal.com/
The print for the 12129486 is there for example (in pdf format even).
It also lists these terminals as "related parts" to the connector 12129486
12176855
15383341
12110846
12110847 < this one is on the print for the connector
12129409
12110845
12110853
These terminals are basic variations for combinations of wire gauge, insultation thickness & with/without rubber seal.
I am still working to find out if any of these are available via a source that sells to the public.
Stay tuned...
Joe J.
Team #88, TJ2
Unread 14-02-2006, 00:12
dez250 dez250 is offline
54... What a good number!
dez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond repute
Send a message via AIM to dez250
Joe did you ever find an available source for these connectors?
-Michael Dessingue
Unread 14-02-2006, 08:13
AKA: Dr. Joe
FRC #0088 (TJ2)
All my sources ran dry. I just got an e-mail late last night saying telling me they struck out.
The only way I know to get these parts is to buy them in 1000's
Sorry.
Joe J.
Team #88, TJ2
Unread 14-02-2006, 09:58
acaball4@cpcus acaball4@cpcus is offline
NYC/NJ FIRST
AKA: Andrew
FRC #0075 (Robo Raiders)
acaball4@cpcus is on a distinguished road
Send a message via AIM to acaball4@cpcus Send a message via MSN to acaball4@cpcus Send a message via Yahoo to acaball4@cpcus
guys, the part number for the window motors quick connect from terminal supply co. part number 8135 not 8185.
Good luck in your endeavours
Andrew Caballero
NYC/NJ REGIONAL DIRECTOR'S ASSISTANT
NJIT'S VP IIE CHAPTER
Johnson & Johnson FIRST Robotics Engineer
Team 75
NEW York City/New Jersey FIRST!
New Jersey Institute of Technology
GITC Building, Room 1209
University Heights, Newark, NJ 07102
Johnson & Johnson
Skillman,NJ
Afc5@njit.edu
Cell: (908) 472-5032
Office: (908) 874-2065
'Fix It Window' and Programming.... JMac Programming 19 25-01-2005 18:57
Parallel Motor Connection Don Wright Electrical 12 30-03-2004 21:23
window motor connection albertgates General Forum 1 12-02-2003 17:18
window motor solid model Redhead Jokes Inventor 0 04-02-2003 14:23
Looking for window kit parts archiver 2000 2 23-06-2002 22:50
