Go to Post I don't see why this is an issue. Robots are immune to the N1H1 virus. - JesseK [more]
Unread 13-01-2006, 12:24
falconmaster's Avatar
falconmaster falconmaster is offline
AKA: Ledge
FRC #0842 (Falcon Robotics)
falconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond repute
Send a message via MSN to falconmaster
Spring return or loaded Cylinders
Is it legal to use spring loaded or return cylinders, if they match every other specifications of the cylinders allowed? Bimba makes them in the sizes allowed.
Faridodin "Fredi" Lajvardi KD7WKD
Unread 13-01-2006, 13:02
Re: Spring return or loaded Cylinders
I have not looked up the specific rules in the manual, but there are restrictions on which types of cylinders you can use.n (check the pnuematic section of the manual).
If you cant use a spring return cylinder, you can make on by only driving one end, and use surgical tubing or some other spring material to pull the piston back.
Unread 13-01-2006, 17:05
Peter Matteson's Avatar
Ambitious but rubbish!
FRC #0177 (Bobcat Robotics)
I just looked at the pnuematics rules and flow chart and can't find anything that prohibits a spring return this year.
However this is misleading because per <R99> the cylinder must be identical to those on the ordering sheet in the pneumatics manual. On said order sheet there is no spring return option, ergo you may not use spring return cylinders.
Pete
Unread 13-01-2006, 17:12
if thats the case you can still use a spring return mechanism that you fabricate as part of your assembly, instead of having the spring inside the cylinder itself.
and then it has to meet all the safety requirements for springs.
Unread 13-01-2006, 17:16
Agreed Ken with one caveat. You have to make sure you don't violate the modification of the cylinders rule (<R94> I believe). This should be obvious to many participants but...
Spring Return Pistons' Legality Yan Wang Pneumatics 3 19-01-2005 20:25
Spring Compression in Inventor 6? psychoCHIPMUNKK Inventor 1 23-05-2004 13:44
Legality of Spring Loaded Pistons Yan Wang Pneumatics 13 19-02-2004 17:20
Custom pneumatic cylinders duckshepherd Pneumatics 7 24-01-2004 20:39
Grey Hindge spring loaded archiver 2000 0 23-06-2002 23:10
