Go to Post I don't know how you can blame a robot getting stuck in the goal on the GDC. The field drawings showed all of the dimensions of the goals. If a team doesn't want to risk getting stuck then they need to plan around it. - JamesBrown [more]
Unread 13-01-2006, 15:29
Windwarrior Windwarrior is offline
AKA: Scott Davis
FRC #1777 (Viking Robotics Club)
Windwarrior is an unknown quantity at this point
Question Alternate Joystick Controllers
I have read on this site that the joysticks supplied with the KOP are not the best. How are they deficient?
Can anyone give me an alternative suggest? The manufacturer and/or site where they can be purchased?
Thanks in advance.
Unread 13-01-2006, 16:31
Greg Marra Greg Marra is offline
[automate(a) for a in tasks_to_do]
FRC #5507 (Robotic Eagles)
Greg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond repute
Re: Alternate Joystick Controllers
The joysticks provided in the Kit are rather "bouncy" and don't quickly center themselves when released.
Many teams prefer the feel of the old CH Flightsticks that used to be provided by FIRST, but are regretably no longer in production. There happen to be two on eBay right now. The key is that the replacement joystick must connect via the "Gameport" connector, and not USB, as most joysticks do these days.
Good luck!
Unread 13-01-2006, 16:38
generalbrando's Avatar
generalbrando generalbrando is offline
Build, Break, Repeat
AKA: Brandon Mensing
FRC #0246 (Overclocked)
generalbrando is a splendid one to beholdgeneralbrando is a splendid one to beholdgeneralbrando is a splendid one to beholdgeneralbrando is a splendid one to beholdgeneralbrando is a splendid one to beholdgeneralbrando is a splendid one to beholdgeneralbrando is a splendid one to beholdgeneralbrando is a splendid one to behold
Send a message via AIM to generalbrando
And if the bouncing doesn't bother you, there's also the matter of both joysticks being right handed. That's not good if you want to use them for tank style driving.
Lead Mentor of Team #246, Boston University Academy and Boston University, Overclocked
www.burobotics.org
Unread 13-01-2006, 16:49
tribotec_ca88's Avatar
tribotec_ca88 tribotec_ca88 is offline
FIRST-a-holic
AKA: Camila Fitzgibbon
FRC #1382 (Tribotec Team)
Team Role: Student
tribotec_ca88 is just really nicetribotec_ca88 is just really nicetribotec_ca88 is just really nicetribotec_ca88 is just really nicetribotec_ca88 is just really nice
Send a message via ICQ to tribotec_ca88 Send a message via MSN to tribotec_ca88 Send a message via Yahoo to tribotec_ca88
Another option to purchasing a new joystick is to enhance the performance of the ones provided in the kit. The joysticks provided by FIRST proportionalize poor handling, but there is a current solution to that... there are several teams that use programming to convert the linear curve of a joystick into an exponential one, which supposedly "smoothens out" the joystick. Works like a charm....
Check out a white paper our team wrote on this:
http://www.chiefdelphi.com/forums/pa...le&paperid=280
1382 Tribotec Team - Brazil
2005 NJ Regional GM Industrial Design Award
2005 NJ Regional Website Excellence Award
2004 NJ Regional Semifinalists
Unread 13-01-2006, 17:46
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
Thanks in advance.
Why not just customize the handles of the Kit of Parts joysticks? Last year, our team made custom HDPE handles for the CH Flightsticks using our lathe. After unscrewing the handle on the stock joysticks, you can take it off. Then fabricate a custom (preferably ambidextrous) handle of your own, and put than onto the stub of the old joystick handle. Viola, a new ambidextrous joystick!
As I documented in one of my earliar posts about joysticks, many of the KOP joysticks problems can be solved mechanically. The right-handed handle issue, and the "touchiness" of them (as in going past center) can be solved by taking off the stock handle, and putting on a newer, shorter handle. The new and custom shorter handles enable the KOP joysticks to become stiffer, not go past center, and now they are ambidextrous!
Custom handles on the CH Flightstick joysticks:
Handle-less KOP Joystick awaiting new handles:
Art Dutra IV
世上无难事,只怕有心人.
Unread 13-01-2006, 18:45
AKA: Scott Davis
[quote=artdutra04]Why not just customize the handles of the Kit of Parts joysticks? Last year, our team made custom HDPE handles for the CH Flightsticks using our lathe. After unscrewing the handle on the stock joysticks, you can take it off. Then fabricate a custom (preferably ambidextrous) handle of your own, and put than onto the stub of the old joystick handle. Viola, a new ambidextrous joystick!
Thanks so much!!!! Sounds like you guys have really got it together.
Loved the pictures, and how your whole control panel setup is handled. Very impressive.
My other car is a sailboat!!
Unread 13-01-2006, 18:49
in between teams
AKA: Luke Van Oort
How about adding a spring loaded contraption like these Saitek sticks have.
Here
Here
Here
Here
Here
Team 1219: 2009 - Mentor
Unread 13-01-2006, 18:57
AKA: Scott Davis
One additional question. How does your reconfigured handle make use of the firing button. The pics don't seem to show it.
Thanks again.
WW
Unread 13-01-2006, 20:47
artdutra04's Avatar
Thanks again.
WW
Sorry about that, those were pictures from the build season when it wasn't 100% completed. Here is one from when we had all the joysticks finished and the arcade buttons installed. Note the button on the lefthand joystick. This was our 'Turbo' button that enabled our robot to have a 40% speed increase.
And yes, those are single player and two player arcade buttons above the OI.
Art Dutra IV
世上无难事,只怕有心人.
Change joystick to pwm mapping Joe Lewis Programming 3 30-03-2005 19:27
Using non joystick controls with Operator Interface (Hacking Various Controllers) Astronouth7303 Control System 58 02-02-2005 15:56
Changing 1 joystick code to 2 (rookie team) Brawler006 Programming 5 20-02-2004 17:00
Joystick controllers archiver 2001 6 24-06-2002 00:57
Alternate Joystick question archiver 2001 5 24-06-2002 00:01
