Go to Post I say we all stop flaming and pointing out what went wrong or what bad calls were made and start pointing out how much fun we all have at the regionals and what FIRST actually has done for us. - burkechrs1 [more]
Unread 13-01-2006, 16:13
chadbarbe chadbarbe is offline
FRC #1450
chadbarbe is an unknown quantity at this point
Limit switch in easy c?
I've only messed around with easy c a couple of times and i was able to get a 2 motor tank drive system up and running in no time... i love it! however, I'd like to get my limit switches working to prevent an arm motor from going too far (either up or down)... I know how to do this by handing coding in MP lab but I am not sure how to do it within the constraints of Easy C. Any suggestions?
CHAD
Unread 13-01-2006, 16:19
Michael Leicht's Avatar
Michael Leicht Michael Leicht is offline
Drive Coach
FRC #1403 (Cougar Robotics)
Michael Leicht has a reputation beyond reputeMichael Leicht has a reputation beyond reputeMichael Leicht has a reputation beyond reputeMichael Leicht has a reputation beyond reputeMichael Leicht has a reputation beyond reputeMichael Leicht has a reputation beyond reputeMichael Leicht has a reputation beyond reputeMichael Leicht has a reputation beyond reputeMichael Leicht has a reputation beyond reputeMichael Leicht has a reputation beyond reputeMichael Leicht has a reputation beyond repute
Re: Limit switch in easy c?
well i don't know how different the easy c from vex is to FRC but i did make a code for two limit switches on one motor.
if you want the code email me at michaelleicht@gmail.com and i will get you that code for the limit switch.
Team 303 (2003-2007)-Student-Won FIRST Scholarship to Daniel Webster College
Team 42 (2007-2008)-College Mentor
Team 2342(2008-2011)-College Mentor
Team 1403 (2011- )- Mentor
Unread 13-01-2006, 16:57
Kingofl337's Avatar
You didn't see anything....
AKA: Adam
FRC #0501 (Power Knights)
Thumbs up Re: Limit switch in easy c?
1. Map Analog to OI Input to a variable
2. Map PWM Control to a variable
3. Make a few "IF" statements
4. Make a few Assignments
Thats pretty much the gist of it. We will be releasing
samples in the future on how to perform these activities.
Also, EasyC for FRC and VEX work pretty much the
same way for driver control.
Unread 13-01-2006, 17:00
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
CHAD
All you need to do is to be able to tell when the limit switch was depressed at the same time that the motor is trying to run in that direction. That way, you will only limit the direction of the motor in that direction, while still allowing for it to go in the other direction.
Here is how this sample arm/elevator is set up. There is an upper and a lower limit switch. The PWM signal for moving the arm up must be between 127 and 255. The PWM signal for moving the arm down will be between 0 and 127. Here is a diagram of this setup:
And here is the code: (from EasyC 2.0)
#include "Main.h"
void main ( void )
      char upperlimit;
      char lowerlimit;
      unsigned char arm;
      while ( 1 )
            upperlimit = GetDigitalInput ( 1 ) ; //Upper limit Switch is plugged into I/O Port 1
            lowerlimit = GetDigitalInput ( 2 ) ; //Lower limit Switch is plugged into I/O Port 2
            arm = GetRxInput ( 1 , 1 ) ; //Arm control is coming from RX port 1, Channel 1
            if ( upperlimit == 0 && arm > 127 )
                  arm  = 127 ;
            if ( lowerlimit == 0 && arm < 127 )
                  arm  = 127 ;
            SetPWM ( 1 , arm ) ; //Set PWM port 1 to 'arm' variable
Art Dutra IV
世上无难事,只怕有心人.
Unread 13-01-2006, 17:05
Kingofl337's Avatar
AKA: Adam
In FRC you would substitute "GetRXInput" with "GetOIAInput".
Thanks artdutra04 for the example.
Unread 13-01-2006, 18:27
FRC #1450
Thanks everybody! This information was very helpful. I had forgotten that I can use the joystick value as a representation of what my PWM output will be. I was stuck because I couldn't find a way to look up what the PWM value was and didn't realize that I didn't even need it!
Unread 02-02-2006, 09:51
scottmso scottmso is offline
FRC #1561 (RoboDucks)
scottmso is an unknown quantity at this point
Send a message via AIM to scottmso
Be careful not to use a while loop for this, I did that and the limit switch essentially acted as a "kill switch" for the robot
limit switches stephenthe1 Programming 28 11-05-2005 16:37
How do you wire a limit switch? JMH Electrical 1 16-02-2005 17:44
LEDs in switch box. ZZII 527 Electrical 5 06-03-2004 19:39
sample limit switch code??? tml240 Programming 5 17-02-2004 17:13
Need help with 255 Variable Joseph F Programming 18 26-02-2002 14:49
