Go to Post You can't expect a situation to get better if you don't make an attempt to confront it. - AndyB [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
Unread 13-01-2006, 20:38
Nine9cracker's Avatar
Nine9cracker Nine9cracker is offline
Newbie in training
AKA: Felix hong
FRC #0368 (kika mana)
Nine9cracker is an unknown quantity at this point
Ball hard spot
Anyone notice that there a hard spot on the ball? When we tested our luncher it work very well until the luncher hit the hard spot when went way over the targer Any thoughes about the spot on the ball?
Leela: They say Zapp Brannigan single-handedly saved the Octillion system from a horde of rampaging Killbots!
Fry: Wow.
Bender: A grim day for robotkind. Eh, but we can always build more Killbots.
Zapp: "Killbots? A trifle. It was simply a matter of outsmarting them."
Fry: "Wow, I never would've thought of that."
Zapp: "You see, killbots have a preset kill limit. Knowing their weakness, I sent wave after wave of my own men at them until they reached their limit and shut down."
Unread 13-01-2006, 20:42
Re: Ball hard spot
belly button? Its where the plastic is injected into the mold when the ball is made.
Unread 13-01-2006, 20:55
wilshire's Avatar
wilshire wilshire is offline
OSNAP. a gear flew out of the robot
wilshire is just really nicewilshire is just really nicewilshire is just really nicewilshire is just really nice
Send a message via AIM to wilshire
Re: Ball hard spot
yeah about that hard spot...i guess just another variable in the game as far as what your robot is designed to do with the ball and how that hard spot may come into consideration to your method.
AIM: wilshire461
Purdue FIRST Teams
Team 461 -http://www.boilerinvasion.org/
Team 1646 - http://www.precisionguessworks.org/
Team 1747 - www.harrisonboilerrobotics.org
Unread 13-01-2006, 22:37
PARhodes's Avatar
PARhodes PARhodes is offline
FRC #1559 (Devil Tech)
PARhodes has a little shameless behaviour in the past
Re: Ball hard spot
Will it be that much of an issue you think?
Unread 13-01-2006, 23:34
wilshire's Avatar
Re: Ball hard spot
well we played around with how much it might affect the "play" of the ball. it seems that the hard spot tends to allow for the ball to want to have that hard spot always closest to the ground, or in other words could cause some nasty spin. The other thing we looked at was if we were to use a roller system how the compression on that hard spot versus anywhere else on the ball and how much of a impact that would make in being able to grab the ball using that roller system which would basicly compress the ball by a total of about 1" to get a good grip on the ball. However it is all up to you and your team to consider these kinds of factors along with possible compression of balls throughout the matches.
AIM: wilshire461
Purdue FIRST Teams
Unread 13-01-2006, 23:39
PARhodes's Avatar
Re: Ball hard spot
I know that the compression of dual wheels will have some affect on the grip. I dont think that the tiny knob (belly button) will give it enough spin to calculate marginal error.
Unread 14-01-2006, 00:30
atomikitten's Avatar
atomikitten atomikitten is offline
blowing things up, making things go
AKA: Megan
FRC #0888 (Robotiators (Glenelg Gladiators))
atomikitten will become famous soon enough
Send a message via AIM to atomikitten
Re: Ball hard spot
A belly button is a good thing to call it. Our teammates kept poking it. If it affects the launching of the ball, that's just another one of those extraneous variables that make things interesting.
Unread 14-01-2006, 00:32
Shu Song's Avatar
Shu Song Shu Song is offline
Melodious Footware
AKA: *Crash!* Shuuuuuuuuuuuu
FRC #0639 (Code Red Robotics)
Shu Song has much to be proud ofShu Song has much to be proud ofShu Song has much to be proud ofShu Song has much to be proud ofShu Song has much to be proud ofShu Song has much to be proud ofShu Song has much to be proud ofShu Song has much to be proud of
Send a message via AIM to Shu Song
Re: Ball hard spot
The heavy spot does throw off the center of gravity(COG). So if you are thinking of the "rifling" the barrel of the shooter to give the ball spin so it would stablize, be aware that with COG not exactly the center of the ball, the spin might actually cause it to swirve all over the place instead of going straight.
Code Red Robotics - Team 639
Ithaca High School| Ithaca | New York | USA | Earth | Sol System | Milky Way | Universe | Some Alien's Locker
WINNER of the 2005 Finger Lakes Regional, thanks to teams 191 and 494.
WINNER of the 2004 Canadian Regional, thanks to teams 33 and 1112
WINNER of Delphi: Driving Tomorrow's Technology Award at the 2007 Finger Lakes Regional.
Unread 14-01-2006, 03:27
Rombus's Avatar
Rombus Rombus is offline
AKA: Rick Kosbab
FRC #4188 (Columbus Space Program)
Rombus is a jewel in the roughRombus is a jewel in the roughRombus is a jewel in the rough
Send a message via AIM to Rombus
Re: Ball hard spot
If its any help, our ball is getting pretty well worn and I don’t think the belly button as its being called is noticeably different any more. It might go away with wear.
Unread 14-01-2006, 03:32
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: Ball hard spot
With hours of testing today, it has been determined that the hard spot is the cause of nearly all inaccuracy in shooting. With all other conditions well controlled, I estimate the hard spot will cause approximately 1 in 12 balls to miss.
Unread 14-01-2006, 11:16
rjbarra rjbarra is offline
GameTime
AKA: Joe Barra
FRC #0020 (Rocketeers)
rjbarra is just really nicerjbarra is just really nicerjbarra is just really nicerjbarra is just really nice
Re: Ball hard spot
What kind of launcher do you have? Are using fly wheels(like a baseball machind)
Unread 14-01-2006, 11:22
Eric Scheuing's Avatar
Eric Scheuing Eric Scheuing is offline
FRC #0999 (MechaRAMS)
Eric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud of
Re: Ball hard spot
What are the odds that it will hit that in the acutal competition?
2005-2007: Bobcat Robotics 177
2015-20XX: MechaRAMS 999
Unread 14-01-2006, 11:25
Re: Ball hard spot
Well, I don't think the odds are any different from in testing. During testing, if we control all the conditions, roughly 1 out of every 12 times the ball will end up in a significantly different location (like missing the hole all together) and we have colcluded this is due to the hard spot contacting the pitching wheel. We arrived at this conclusion by controlling all the other conditions to the best of our ability.
Unread 14-01-2006, 12:06
Re: Ball hard spot
Which way the navel ends up in your shooter depends on how the balls are loaded, and how you pick them up.
Since the navel is probabally a dense spot of plastic in the foam ball, its should be heavier. therefore a ball on the floor would tend to roll till the navel is down, like an out of balance wheel will center itself with the heavy side down.
So depending on how you load your shooter for auton mode, and how the balls move through your machine, the navel my end up in random positions, or it may tend to gravitate towards one orientation in your shooter mechanism.
Ball Recirculation Question Nuts4FIRST Rules/Strategy 23 15-01-2006 15:35
Nerf ball starting at 12m/s 45 degree angle ending at 8ft 6in w/ air resistance Ethulin Technical Discussion 39 14-01-2006 19:04
Second FIRST Ball Launcher generalbrando Technical Discussion 14 13-01-2006 09:08
10 pt. ball into/out of play Lil' Lavery Rules/Strategy 23 28-01-2004 14:17
How hard is it to pull a goal? Ken Leung General Forum 19 17-01-2002 20:09
