Go to Post Too often we like to forget that it takes an insane amount of hard work to even have a chance to overcome raw talent. - Paul Copioli [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
Unread 13-01-2006, 21:00
Andrew Blair's Avatar
FRC #0306 (CRT)
Re: Tips for KitBot
The gearboxes can be very good, but be sure to assemble them with plenty of LockTite. If you don't, they will comeaprt, and they will jam. We had this happen a couple of times, and total, from three gearbox jams, we found five pieces of loose hardware inside. For some reason, the stuff in there is attracted to the gears.
Also run the gearboxes in for about ten minutes straight. They'll run a lot better for it.
-Sir Francis Bacon
-Albert Einstein
Fantasy FIRST drafting tips for newbies (and veterans) Koko Ed Fantasy FIRST 18 20-04-2006 17:06
Building tips Liz C Technical Discussion 6 16-10-2005 14:48
Travel Tips KathieK General Forum 5 13-12-2004 12:47
Mechanical tips for rookies Anne Shade Technical Discussion 10 28-10-2004 13:44
Any Tips on Fundraising? Zzyzx Chit-Chat 3 06-10-2004 15:31
