Go to Post Let's Just say i am the one that gives Firefighters, paramedics, and law enforcement a job - Tytus Gerrish [more]
Unread 13-01-2006, 20:10
Nitroxextreme's Avatar
Nitroxextreme Nitroxextreme is offline
Relation to Mrs. Steve
AKA: Jon
FRC #1626 (Falcon Robotics ; 190 (Gompei and The Herd))
Nitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to behold
Send a message via AIM to Nitroxextreme
Relationship between wheel type and power
While doing some testing with a prototype ball shooter we have come onto the important question of wheel size/width/type.
I believe that the bigger diameter of the wheel (6, 8 in) the faster it will be moving with more power at the edge.
Could someone please explain why this is so?
On another note...
What kind of influence does the surface area of the wheel have with the shooting?
Also how would the amount of grip the wheel provides influence the shot?
"He needed a chuck norris lesson in FIRST"...."I will give him a round house kick to the face...with gracious professionalism"
Unread 13-01-2006, 20:40
Re: Relationship between wheel type and power
with the same rpm (same drive motor/gears) the edge of a large wheel has a faster surface velocity than a smaller wheel.
Power is not as straightforward. A larger wheel has higher speed but less torque. Technically the power is the same - the power is the amount of power your motor is putting into the wheel. If you connect a 1 HP motor, then you have one HP available.
energy is what you really need to look at. At the same RPM a heavier or larger diameter wheel will have more rotational intertia (energy) than a smaller one. When a ball comes in contact with the wheel, a larger one will have more stored energy to transfer.
Unread 13-01-2006, 20:49
Andrew Blair's Avatar
FRC #0306 (CRT)
Right, but the tradeoff is spoolup time. You need to realize that a wheel with a greater power storage capability will also have a greater inertial moment, and therefore require more time to get it up to speed than a smaller flywheel. That makes sense. Now, Ken's right, the reason why a bigger wheel throws the ball harder is about it's linear speed. That means the amount of wheel that passes past a reference point on the wheel in a given amount of time.
Linear velocity (to get more, increase the RPM or the diameter of the wheel) means a greater exit velocity of the ball. Greater flywheel kinetic energy ( increase the diameter, or increase the mass), assuming an adequate power (enough that the ball doesn't really realize the flywheel slowing down during launch) will mean you can fire faster. If less KE is taken from the flywheel, you need less time to get it back up to speed for the next shot.
-Sir Francis Bacon
-Albert Einstein
Unread 13-01-2006, 21:30
warcommander200's Avatar
warcommander200 warcommander200 is offline
FRC end-effecter group
AKA: David
FRC #0116 (Epsilon Delta)
Team Role: Student
warcommander200 will become famous soon enough
Send a message via MSN to warcommander200
Thumbs up Re: Relationship between wheel type and power
My dad has a lot of experience with Ball pitchers and the heaver the wheel the more accurate, and farther the ball will go.
the best power regulator John Gutmann Electrical 37 04-08-2005 08:52
Cheap Torque Measurement? ChuckDickerson Motors 15 13-06-2005 13:57
Alternative Power Sources? plutonium83 Electrical 18 30-05-2005 15:09
power transmission NOT using gears/chains? Frank(Aflak) Technical Discussion 37 21-05-2003 12:50
Can your team use the machines? archiver 2001 10 24-06-2002 00:47
