Go to Post Doctor the drill, or doctor your hand. Easy choice. Let's all make the right one. - Molten [more]
Unread 10-01-2006, 12:34
jjbarrow jjbarrow is offline
FRC #0441 (Reagan Devil Dogs)
jjbarrow is an unknown quantity at this point
Question How to Start Autonomous mode?
How does our team activate autonomuos mode to see if the programming we put in it works?
Thank you
Unread 10-01-2006, 12:39
REVving up for a new season
FRC #2848 (All-sparks)
Re: How to Start Autonomous mode?
you need to jumper from pins 5 to 8 on your operator interface competition port
a schematic for building an autonomous switch is here
http://ifirobotics.com/docs/competit...guide-reva.pdf
you can also buy one from http://andymark.biz
Greg Needel│www.robogreg.com
Co-founder REV Robotics LLC www.REVrobotics.com
2014 FRC World Champions with 254, 469, & 74
Unread 10-01-2006, 12:56
Smile Re: How to Start Autonomous mode?
THANK YOU
Unread 13-01-2006, 22:45
kevlarman kevlarman is offline
"why cant i install Linux?" guy
AKA: Roman Tetelman
None #0100
kevlarman is an unknown quantity at this point
this is something that they really should put in the kit. the autonomous switch is very useful, but the disable switch is the most useful piece of hardware ever (and that includes the pic to run code on, and the laptop used to write said code)
Unread 14-01-2006, 00:20
Tsom467 Tsom467 is offline
FRC #0467 (Shrewsbury Colonials)
Tsom467 will become famous soon enoughTsom467 will become famous soon enough
We were discussing this the other day. Since, if you don't wire up the disable/auton switch correctly, you will fry your operator interface. Yes, we did, twice... $200 to repair each time....
Instead of leaving it up to the teams to do this, it would be easy for them to include a correctly wired one and help to limit the number of controllers they have to fix!
Unread 14-01-2006, 00:47
You can also have a button on one of your joysticks to toggle the Auto mode function.
int automode=0;
if(p1_trig==1)autmode=1;
while(automode==1)
     if(p1_trig==1)autmode=0;
     User_Autonomous_Code();
Unread 14-01-2006, 07:14
Billfred's Avatar
Billfred Billfred is offline
Well, if you're paranoid about soldering up a good switch, there is an alternative.
Unread 15-01-2006, 14:03
Oumonkey's Avatar
Oumonkey Oumonkey is offline
Master of the If statement
AKA: Josh Tyus
FRC #1555 (Pulse)
Oumonkey has a spectacular aura aboutOumonkey has a spectacular aura about
int automode=0;
while(automode==1)
Where would I put that piece of code?
I don't know much about C, so I wanted to ask before I mess something up. don't hurt me...
Unread 15-01-2006, 14:35
You could put it right in Default_Routine() or Process_Data_From_Master_uP()
Just make sure you initialize the trigger variable outside the function.
int automode=0;
void Default_Routine(void)
what I had before....
Unread 15-01-2006, 20:35
Oumonkey's Avatar
AKA: Josh Tyus
FRC #1555 (Pulse)
int automode=0;
Great,, I think I know what do to know, I'll have to try it know. Thanks.
Unread 15-01-2006, 23:18
amateurrobotguy's Avatar
amateurrobotguy amateurrobotguy is offline
Lead Programmer/Senior Engineer
amateurrobotguy is infamous around these partsamateurrobotguy is infamous around these partsamateurrobotguy is infamous around these partsamateurrobotguy is infamous around these partsamateurrobotguy is infamous around these partsamateurrobotguy is infamous around these parts
<-- Totally my reaction! We gotta buying one of those switches!...not that we couldn't make it ourselves , but the fact that it has nice toggle switches and a giant stop the robot button so we won't have to chase down the robot, tackle it, and hit the e-stop
I quit FRC over 2 years ago (more if you're reading this past 2010).
Unread 16-01-2006, 17:02
devicenull devicenull is offline
Robot? We need a robot?
Rookie Year: 1234
devicenull is just really nicedevicenull is just really nicedevicenull is just really nicedevicenull is just really nicedevicenull is just really nice
Make your disable button very, very big. And always have it plugged into the OI. Earlier today I had a robot start running away because the joystick was out of calibration... I was literally holding onto the transmission mount panel, and hoping that someone would come hit the circut breaker.
Last year I had the robot come full speed in reverse at me. That wasn't too fun.
I think I may want to put a large EStop button on the robot itself this year..just tell it in code to zero all pwm's when its pressed
Unread 16-01-2006, 17:08
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
For the uninitiated: When Robots Attack. (Watch Phrontist get dragged around by a robot, laptop and all. )
Unread 16-01-2006, 20:12
That has got to be the funniest thing I have ever seen.
Unread 16-01-2006, 20:34
Greg Marra Greg Marra is offline
[automate(a) for a in tasks_to_do]
FRC #5507 (Robotic Eagles)
Greg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond repute
Haha.
Yea, this is why kill switches are good ideas.
a simple autonomous mode question chippermonky Programming 3 18-02-2005 01:54
How do I enter the Autonomous mode? CompMaster Programming 5 17-02-2005 19:12
What do you do during autonomous mode? Salik Syed Programming 46 21-03-2004 21:05
Autonomous mode Tyler Olds General Forum 30 22-02-2004 14:31
Initializing autonomous mode Mr. Lim Programming 7 02-02-2004 07:26
