Go to Post We'll defintely be working on both the balancing 2 wheel robot, the 6 legged robot, and the wood chassis 8 wheel drive robot ideas this fall. - MrForbes [more]
Unread 13-01-2006, 22:50
skimoose's Avatar
skimoose skimoose is offline
Parent/Mentor/Engineer
AKA: Arthur Dutra
FRC #0228 (GUS)
Team Role: Electrical
skimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond repute
EasyC v2.0 is mandatory for FVC!
Reports coming back from FVC regionals have indicated that all teams are not using EasyC v2.0 on their robots.
FVC teams are also not taking advantage of Intelitek's discounted upgrade to EasyC v2.0.
FVC teams please note that the FVC competition template is only available in EasyC v2.0 and is not backwards compatible.
Teams make upgrading to EasyC v2.0 part of your pre-competition check list now, or you'll be scrambling to rewrite your code at the competition.
2009 CT Regional Motorola Quality Award
2010 VRC Connecticut Championship Winners & Amaze Award
2010 VRC Championship Divisional Energy Award
2010 WPI Regional Winner
2010 WPI Regional Engineering Inspiration Award
2011 WPI Regional Chairman's Award
2012 WPI Regional Finalists
Unread 14-01-2006, 01:57
Electrical Engineer
Rookie Year: 1995
Re: EasyC v2.0 is mandatory for FVC!
Arthur,
I would refer you to this thread. I would be interested in seeing where in the rules or posted questions we are limited to easyC as a programming language.
I'm not saying that the rule does not exist... I am unable to find it.
Regards,
Mike
Mike Betts
As easy as 355/113...
Unread 14-01-2006, 08:11
skimoose's Avatar
AKA: Arthur Dutra
FRC #0228 (GUS)
Mike,
EasyC is not the only option as you've noted. If your team is experienced enough to use MPLab, then use it. Your code must still comply with competition template.
The problem is that inexperienced teams are not using the competition template. and their robots will not work with the field control correctly. Several teams had to rewrite code the morning of the event. Not a fun way to pass inspection and start your competition day.
A more accurate statement would be - If using EasyC for FVC version 2.0 is mandatory.
Sorry for any confusion.
Unread 14-01-2006, 08:19
Electrical Engineer
Rookie Year: 1995
Arthur,
Thank you for the clarification.
I'm struggling to keep my hands off the VEX and let the students run with the design. I've left it up to them as to which programming language to use. However, I have made it clear that I consider C to be the superior path (for a number of reasons).
Once again, Thanks.
Mike
Mike Betts
Unread 14-01-2006, 09:13
Bill Moore's Avatar
Bill Moore Bill Moore is offline
Iv2gr8sons
AKA: Be More
FRC #0365 (Miracle Workerz)
Team Role: Team Spirit / Cheering
Bill Moore has a reputation beyond reputeBill Moore has a reputation beyond reputeBill Moore has a reputation beyond reputeBill Moore has a reputation beyond reputeBill Moore has a reputation beyond reputeBill Moore has a reputation beyond reputeBill Moore has a reputation beyond reputeBill Moore has a reputation beyond reputeBill Moore has a reputation beyond reputeBill Moore has a reputation beyond reputeBill Moore has a reputation beyond repute
Send a message via AIM to Bill Moore
Originally Posted by Mike Betts
Arthur,
Regards,
Mike
Mike,
There is no rule in the manual. Easy C is included with the Vex Robot, hence the references toward it. FIRST has put this note on the FVC Resources page in the EasyC V2 Upgrade Offer.
"In order to successfully compete in the autonomous portion of the FIRST Vex Challenge game, "Half-Pipe Hustle" you MUST upgrade to easyC version 2."
If the team is using Easy C, they must upgrade from version 1.1 to version 2, or their robot will not run at the competition. This happened at the St. Louis tournament.
MPLab can also be used to program the robot, and is discussed in the FIRST Vex Forums:
http://forums.usfirst.org/showpost.php?p=184
http://forums.usfirst.org/showpost.php?p=185
http://forums.usfirst.org/showpost.php?p=226
MPLab Downloads and instructions for installing it are located here:
http://www.vexlabs.com/vex-robotics-downloads.shtml
Hope this helps, Mike!
Three Signs You Are Getting Old: 1) You forget things, 2) You begin repeating yourself, 3) You forget things.
Unread 14-01-2006, 10:09
skimoose's Avatar
AKA: Arthur Dutra
FRC #0228 (GUS)
If you're an experienced programmer this may be true, but after working with version 2.0 it's a big improvement over version 1.1.
We're working on some other new projects that we'll post when we can. You might be surprised what can be done with EasyC.
Unread 14-01-2006, 11:04
jamesgecko's Avatar
jamesgecko jamesgecko is offline
Linux Guy.
AKA: James D
FTC #0040 (Grep Lurch Grab)
jamesgecko is an unknown quantity at this point
Send a message via AIM to jamesgecko Send a message via Yahoo to jamesgecko
Question Re: EasyC v2.0 is mandatory for FVC!
Slightly unrelated:
My team does not have the programming module yet. Does this mplab stuff come with it? Is the way you code for the Vex stuff the same as with the "normal" first robots? Are there online manuals about the robot funtions someplace?
Unread 14-01-2006, 18:37
skimoose's Avatar
AKA: Arthur Dutra
FRC #0228 (GUS)
Originally Posted by jamesgecko
Slightly unrelated:
You can purchase mplab, cbot compiler, and ifi loader, along with a prototype programming cable from www.vexlabs.com for $99. You need to email them as it's not a listed item on their website. This is just like programming the "normal" FIRST robots. If you go this route, please note that the programming module is a pc board, you'll need to mount it in a plastic hobby box to keep the magic smoke in the module. It's the same price as the Radio Shack programming module, but then you also need to add $25 for your upgrade to EasyC v2.0 through Intelitek. If you use EasyC v2.0 there is a manual here. I'm not sure of any manuals for FVC using mplabs.
Vex Easyc vs Mplab Joohoo Programming 17 27-01-2006 08:22
Kickoff easyC workshop integrated into EasyC help file Dan Larochelle Programming 0 11-01-2006 06:12
EasyC v. 2.0 - New features, custom user functions, and more! artdutra04 FIRST Tech Challenge 1 02-11-2005 13:36
