Re: Tips for KitBot
Definitely go for a grade 8 axle bolt. We bent a low grade bolt in testing last year.
Re: Tips for KitBot
We assembled the Kit Bot for early program module development, but are having troubles with traction with the stock wheelchair wheels. I suppose this is from a combination of low robot weight (bare minimum for bot to run mounted), and running the bot on a slick tile floor.
Does anyone have suggestions on how to get more traction from the stock wheels? We are planning on adding more weight over the driven wheels tomorrow, and possible putting zip ties around the wheels. |
Re: Tips for KitBot
Also, do you have any pneumatic tires you could switch in for the wheelchair ones? They tend to be much better at gripping. |
Re: Tips for KitBot
Re: Tips for KitBot
Re: Tips for KitBot
Re: Tips for KitBot
http://www.usfirst.org/robotics/2004.../champwork.htm check out the drive line ppt's The second is conveyor belting. The gum rubber variety is a First staple. You can get more info from the IFI site they make the controller and also some new bolt together wheels which you pop rivet the belting to other wise teams get the wheel chair wheels lathed flat and glue the belting to the outside. Also try a search of the forums here, Hope this is helpful. |
#8
Re: Tips for KitBot
This year... 6x6. Jason P.S. Skyway has some nice pneumatic wheel/tire combinations. |
| Fantasy FIRST drafting tips for newbies (and veterans) | Koko Ed | Fantasy FIRST | 18 | 20-04-2006 17:06 |
| Building tips | Liz C | Technical Discussion | 6 | 16-10-2005 14:48 |
| Travel Tips | KathieK | General Forum | 5 | 13-12-2004 12:47 |
| Mechanical tips for rookies | Anne Shade | Technical Discussion | 10 | 28-10-2004 13:44 |
| Any Tips on Fundraising? | Zzyzx | Chit-Chat | 3 | 06-10-2004 15:31 |
