Go to Post so this is going to sound really dumb but remember that i am a mechanical guy. - Greg Needel [more]
Unread 13-01-2006, 20:13
Nitroxextreme's Avatar
Nitroxextreme Nitroxextreme is offline
Relation to Mrs. Steve
AKA: Jon
FRC #1626 (Falcon Robotics ; 190 (Gompei and The Herd))
Nitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to behold
Send a message via AIM to Nitroxextreme
One or Two Wheel Shooter
I'm sure that alot of people have varying opinions on to which type of wheeled shooter is the most accurate/ most powerful.
I was just wondering as to which design you believe is the best and why
"He needed a chuck norris lesson in FIRST"...."I will give him a round house kick to the face...with gracious professionalism"
Unread 13-01-2006, 20:20
agndoggieboi's Avatar
agndoggieboi agndoggieboi is offline
CpT. cOMmANdo
AKA: Snoogie
FRC #0368 (Kika Mana (Tiger Power))
Team Role: Mascot
agndoggieboi is an unknown quantity at this point
Send a message via AIM to agndoggieboi Send a message via Yahoo to agndoggieboi
Re: One or Two Wheel Shooter
it depend on whether u have enough room. a one wheel shooter takes less room den a two wheel shooter. it really depends on ur design of everything else. so hope i helped
Unread 13-01-2006, 20:26
A one wheel shooter has a couple advantages:
1. only one motor/drive to control, instead of two wheels that must be synchronized
2. two wheels grab a ball and accelerate it 'instantaniously'. We know from the laws of physics that is impossible, so either the wheels must slow down as it grabs the ball, or the ball must be ripped or skidded to some degree. With a single wheel you can feed the ball into the capture zone so it rolls into it at an accelerating rate. This eliminates the need for instantaniously going from 0 to 12M/s.
3. one wheel puts a repeatable spin on the ball. Depending on how the ball hits the target this can be usefull, so the ball will spin itself into the goal.
Unread 13-01-2006, 20:31
Andrew Blair's Avatar
FRC #0306 (CRT)
Ah, this is is the biggest discussion our team is having this year. Lets see if I can show both sides of the argument:
1 Wheel-
Simpler
Gives a nice backspin on the ball
Can take up less room
Probably a slightly slower throw
Favorite of commercial ball throwers
2 Wheel-
Possibly some more velocity on the ball
With the proper setup, a side-spin or axial spin can be introduced
More complex, needs two motors or a gear/belt/chain linkage
Favorite of Physics students (Inside joke)
Now, it really comes down to which one is more accurate. You need a prototype to do this. If they're equally accurate, it depends on how much space/resources/engineering prowess you feel that you can put into it. We'll have throwers tommorrow, so we'll know then. Hopefully.
-Sir Francis Bacon
-Albert Einstein
Unread 13-01-2006, 23:56
Sgraff_SRHS06's Avatar
Sgraff_SRHS06 Sgraff_SRHS06 is offline
Kappa != 1/(4Pi-Epsilon-Naut)
AKA: Steve Graff
FRC #1111 (The Power Hawks)
Sgraff_SRHS06 is a jewel in the roughSgraff_SRHS06 is a jewel in the roughSgraff_SRHS06 is a jewel in the roughSgraff_SRHS06 is a jewel in the rough
Send a message via AIM to Sgraff_SRHS06 Send a message via Yahoo to Sgraff_SRHS06
We're also using a one-wheeled launcher. For us, it was mostly a question of how robust and simple the design was going to be rather than a versatile complex one. The mechanism, tenatively is that single wheel, but we hope to use it not just for hurling balls into the center goal, but also harvest balls and shoot [balls] into the corner goals.
I don't know how that's going to work yet, completely. But I am pleased to know that it does NOT involve pneumatics.
Unread 14-01-2006, 00:51
sciencenerd's Avatar
sciencenerd sciencenerd is offline
ooh, what does this button do?
AKA: Kyle
FRC #1318 (the IRS (Issaquah Robotics Society))
sciencenerd has much to be proud ofsciencenerd has much to be proud ofsciencenerd has much to be proud ofsciencenerd has much to be proud ofsciencenerd has much to be proud ofsciencenerd has much to be proud ofsciencenerd has much to be proud ofsciencenerd has much to be proud of
You have to remember, with a single wheel the RPMs must be twice as high as a double-wheel design to get the same ball end velocity. Not to say that it takes twice as much power, just that you will have a faster-spinning object on your robot, which is potentially a safety hazard. Something to think about.
Oh, maybe I shouldn't have pushed that...
Unread 14-01-2006, 01:10
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Let's just wait until we see the video from one SoCal team I have in mind.
Relationship between wheel type and power Nitroxextreme Technical Discussion 3 13-01-2006 21:30
How did you control your Robot? 1? 2? Wheel? How? ChrisCook Control System 9 17-05-2005 21:41
Four wheel drive question haverfordfords General Forum 25 25-01-2005 23:24
Clamping wheel hubs sanddrag Technical Discussion 7 29-02-2004 00:20
how can you use a gyro in autonomous mode magical hands Programming 3 02-01-2004 13:31
