Re: 10 Balls per second?
hmmmmm well even though the video is 2 seconds long you can get a bunch of info from it
1. The video there showing is from a head on shot not a side shot so this auto mode will take more then 1 sec. 2. you can hear the balls but nothing shooting them 3. the ball are falling down not shooting up nice try guys i hope you can pull it off but this is not a robot shooting balls shaun ps there a ton more evedence in the video of why this is not a robot cannon you will see in a comp look carfully. shaun |
Mind tricks on CD?
*Hand wave*
There is no robot. Wetzel |
On my PC I definately hear some type of machinery running before the balls hit the goal.
If the balls have been fired from ground level they will arc up in flight, then they will be 'falling downward' on the tail of there flight - so I dont see any evidence that proves this video is contrived. very impressive! being able to launch ten balls at once means you have more time for everything else and for dramatic effect you can use the first 3 second of auton mode to get into position, wait 6 more seconds, then fire them all off. The most dramatic shot in basketball is the one that just goes in as the buzzer sounds in your case, it will be ten going in. excellent demo. This will definately get some people thinking out of the box! Engineering is like magic sometimes. Once you see someone do something impressive or new, you know there is system behind it, so the challenge then is to figure out how they did it. BTW: Nobody would take the time to setup an elaborate shooter hoax/con and post it on CD, when they are so busy working on their robot. "Hey instead of working on our robot this morning, lets make a fake launcher video and post it on CD to freak everyone out!" I dont think so! Last edited by KenWittlief : 14-01-2006 at 12:29. |
You cannot "Drop" balls into a goal like that per-se. They must be shot somehow. It doesn't mean that they have to shoot them UP, but they must be given some forward motion. Also, it looks like one of the balls reaches it's apex slightly after it enters the frame, offering evidence that they were shot. I'm going to say this is not a hoax, and to be VERY VERY affraid!
#7
You have just got to love the rumor mill... ![]() |
#8
I see alot of shooters early but none of them on robots. Ours on the other hand can shoot 1 evey .5 seconds at any of the starting points for a total of 10 ball in 5 seconds. tough to stop that. then it will go out and find other robots
yes find other robots. the camera is great for other things then the green light. ![]() |
#10
The advantage to shooting that fast?
1-you can ideally unload all your balls before opposing robots have time to move to try and either block them or dislodge you from your shooting spot 2-can funnel them into the goal far far faster than a HP can take the out and return them to play, therefore giving a HUGE advantage in the last few seconds of the match 3-makes it so even the slightest mistake of the opposing defense can cost them massively 4-allows you to "get in and get out" reducing the chances your opponents have to trapping you into their zone and even possibly pinning you onto their ramp area 5-allows for longer set up and positioning time (if needed, some robots may be fully capable of "sinking shots" from the starting position) during autonomous 6-is really freaking sweet and here is arguably the most important of all: 7-allows for more reload time. Even if you discharge your load quicker, you can still hold the same amount of balls (in theory, the reality may differ on how you load the mechanism, and this creates a debate in itself of whether quick shooting/loading vs larger quantities of "ammunition" is the better way to go). Therefore, the faster you can unload your balls, the more time it will allow you to refill and shoot again (or do other various tasks around the field, such as defense or going for the platform at the end). |
#11
I'm pretty sure thats not 12 m/s. And the angle that its coming in at is pretty high too.
#12
hey
we were checking this out and messing with the video. we dont believe this for one second!!! the video is reversed and u shot the balls through the other side of the hole. better luck next time! ![]() |
#14
Actually, I can verify for a fact that this video wasn't tampered with at all. I saw the mechanism last night along with some other videos, and this really is 10 balls in pretty much one second.
#15
how can they all go in in one second... i mean i can see them all firing in 1 second but in the center goal they would all just pile up and not actually score. how did you make them all go down the tube at once? i think that although the firing mechanism is good in order to make it realistic you would need a back to that goal
cool idea however. if you can make it work tell me because my team could use help trying to fire 1 ball per 10 seconds is it true that also using tracks can help fire more accurately? this is definitely a rumor. Last edited by gondorf : 14-01-2006 at 17:54. |
| POLL: have small balls been abandoned? | Solace | General Forum | 44 | 04-09-2004 17:53 |
| New Jersey Regional Status | Aignam | Regional Competitions | 144 | 21-07-2004 17:04 |
| Thoughts on the competiton balls | Petey | Regional Competitions | 26 | 14-03-2004 09:31 |
| Team 188 Pictures - four big balls anyone? | archiver | 2001 | 6 | 24-06-2002 01:03 |
| Will ANYONE mess with the black balls? | archiver | 2001 | 0 | 23-06-2002 22:35 |
