Go to Post The scent of a smoking Globe motor is familiar to many. - Alan Anderson [more]
Unread 09-01-2006, 09:34
Schmitty!'s Avatar
Schmitty! Schmitty! is offline
Ever issue is an opportunity to...
AKA: Mike Schmitt
FRC #0093 (N.E.W. Apple Corps)
Schmitty! is a splendid one to beholdSchmitty! is a splendid one to beholdSchmitty! is a splendid one to beholdSchmitty! is a splendid one to beholdSchmitty! is a splendid one to beholdSchmitty! is a splendid one to behold
Re: 2006 Motor Specs
I measured the no-load speed and current of several of the motors we received in the 2006 KOP with an optical tachometer and Fluke DMM. I got the following results:
Small CIM #1 +12.00V: 5370 RPM 2.06Amps
Small CIM #1 -12.00V: 5412 RPM 2.00Amps
Small CIM #2 +12.00V: 5209 RPM 2.00Amps
Small CIM #2 -12.00V: 5374 RPM 2.13Amps
Large CIM #1 +12.00V: 2665 RPM 0.700Amps
Large CIM #1 -12.00V: 2738 RPM 0.790Amps
Large CIM #2 +12.00V: 2752 RPM 0.802Amps
Large CIM #2 -12.00V: 2686 RPM 0.690Amps
Fisher-Price #1 (without gearbox) +12.00V: 16224 RPM 1.06Amps
Fisher-Price #1 (without gearbox) -12.00V: 16579 RPM 1.03Amps
I am planning on grabbing the remaining no-load measurements tonight. So far the measurements I've taken fall in line with what I expected based on the datasheet values. I'm very happy to see that the Fisher-Price motor is a 12V motor!
Does anybody have a dynomometer test stand that can be used to capture the torque data? I can set up a test at stall to capture the stalled torque constant, but from previous experience it is more accurate to capture the torque constant while the motor is spinning under a known load. I don't have access to a dyno at my current job.
Unread 09-01-2006, 10:19
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Originally Posted by Joe Johnson
P.S. By the way, I have just found a table in this document that I believe is in error. It has the peak power of the FP motor over 300 Watts. This does not match the specs in the spec sheets or even the specs in the rest of the table in the same document. I believe my numbers are correct. Also, the Bosch and the Globe are listed as non-12V specs you have to scale the power ratings accordingly to get apples to apples comparisons.
Joe,
I just saw this error as well. Frustrating, as I was making a spreadsheet to figure out the windup time for a firing wheel and the FP + a shifting Dewalt was taking longer than I thought a 300W motor should. Looking at the spec sheets and the Tips doc, the erroneous Tips doc is using the Power Input figure of 300+W at Peak Power for the FPs. As opposed to the Power Output of 170W. And now back to the drawing board I go.....
Kevin
Unread 09-01-2006, 12:04
Richard Wallace's Avatar
I live for the details.
FRC #3620 (Average Joes)
I have a Magtrol HD-715 dynamometer and Sorenson DCS 20-150 switchmode power supply in my day-job lab. I did a quick 12V test of the large CIM motor this morning. With the motor coupled to the dyno and no load (apart from dyno friction) applied the speed was 2710 RPM and the current was 1.5 Ampere. Peak efficiency was about 85% at 43 oz-in, 2470 RPM drawing 7.7 Ampere. Peak shaft power was about 218 Watts at 193 oz-in, 1530 RPM drawing 33.5 Ampere. The maximum steady load that I applied was 283 oz-in, 750 RPM drawing 51 Ampere. I did take the loading up to about 350 oz-in momentarily without stalling the motor, but did not leave it there long enough to record steady data.
Richard Wallace
since 2003
Unread 09-01-2006, 17:51
starbot starbot is offline
FRC #1712
starbot has a spectacular aura aboutstarbot has a spectacular aura about
What size timing belt pulley is on the larger CIM in the kit?
Unread 10-01-2006, 22:35
President, VEX Robotics, Inc.
I will shortly post my annual Fisher-Price motor thread. I will discuss three motors in particular: small CIM, big CIM, and Fisher-Price. I can tell you this right now: FIRST has done their homework this year.
I have the information regarding the big CIM and it's interfaces, but I have to scan it in. It discusses what size and type of pulley is on the motor shaft (among other things).
-Paul
Unread 11-01-2006, 00:42
Here are the specifics of the pulley on the output pinion of the large CIM motor:
Gates Rubber Co., 16 groove, 3mm pitch Powergrip GT, 15mm wide.
This is from the same Fisher-Price spec sheet that the motor curve FIRST provided came from. I do not know why they did not provide both sheets. If IFI tells me it is O.K., then I will just supply the sheet (there is nothing else in the data sheet of any importance that the motor curve does not provide).
Also, I verified the other fisher-Price motor specifications (the ones with the plastic gearboxes):
Both motor graphs that FIRST has provided are the EXACT motor curves provided by Johnson Electric. I am very impressed that they provided the correct sheets this year. I am using the Fisher-Price motors and using the curves FIRST provided as they are correct.
The small CIM motor is identical to the ones provided in the kit last year. There are no changes at all. The same specifications apply and the kit gearbox works the exact same way it did last year. If you want to run it with 4 motors, you must purchase two this year.
-Paul
Unread 12-01-2006, 02:35
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
Paul,
Browsing through McMaster-Carr, it seems that they're listing 'Power Grip GT' belts as having a 5mm pitch. They do not carry any 3 mm pitch belting at all.
Is this simply because McMaster-Carr doesn't have it, or because you made a typo?
--Madison--
...down at the Ozdust!
Unread 12-01-2006, 09:54
M.,
I am positive it is 3mm pitch. The spec from Fisher-Price says 3mm and I measured it to be 3mm. Go to www.gates.com to look up all types of belts.
Powergrip GT2 is the belting and it comes in 2, 3 and 5mm pitches (among others). The 15 mm wide belt seems to be pretty standard.
-Paul
Unread 12-01-2006, 14:14
Madison's Avatar
FRC #0488 (Xbot)
M.,
-Paul
Thanks, Paul. I expected that it was simply that McMaster didn't carry it. Gates, even, has many local distributors for their product, so I'm better off with that than McMaster anyway.
--Madison--
Unread 12-01-2006, 18:32
Spencer295 Spencer295 is offline
FRC #0295
Spencer295 is an unknown quantity at this point
Richard because your test results vary so drastically from the specs on previous posts on motor wattage, would you mind testing the old cim motors on your dyno so I can make an accurate comparison.
Unread 14-01-2006, 12:16
Hutch Hutch is offline
NOTAG
Hutch will become famous soon enoughHutch will become famous soon enough
Uhm, so I guess this begs the question, where are those 36 teams? It's been a week now and I haven't seen any specs posted by anyone except other people who decided to do it with the tools they have at work or whatever...
Unread 14-01-2006, 20:37
Goldeye Goldeye is offline
AKA: Josh Hecht
FRC #0694 (Stuypulse)
Goldeye has a spectacular aura aboutGoldeye has a spectacular aura aboutGoldeye has a spectacular aura about
Send a message via AIM to Goldeye
Are the specs for the Bosch Van Door available anywhere? I read that these are different from earlier years and can't find any info for new ones.
Team 694
2005 Championship - Galileo Semifinalist
2005 New York - Regional Chairmans Award
2005 New York - Semifinalist (Thanks 1257,1340)
Unread 14-01-2006, 21:38
petek's Avatar
petek petek is offline
What would Dave do?
AKA: Peter Kieselbach
FRC #3654 (Tech Tigers)
petek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond repute
Send a message via AIM to petek
Basic specs on all the motors are in
FIRST Guidelines, Tips & Good Practices. Glad I went looking for this because FIRST posted a new revision.
Pete Kieselbach
Unread 14-01-2006, 22:01
Nathan B. Nathan B. is offline
Build Team Captain
None #1084
Nathan B. is an unknown quantity at this point
We used last years manual, becasue basicly there the same thing.
Unread 14-01-2006, 22:22
I don't have an old CIM motor available to test right now. Will try to get one later this week.
Richard Wallace
since 2003
PIC18F8722 - New 2006 RC MPU, 4x more program memory! kmcclary Programming 16 08-01-2006 14:22
[Official 2006 Game Design] OK, so YOU design the 2006 game... dlavery FRC Game Design 29 08-01-2006 00:21
**FIRST EMAIL**/Welcome to the 2006 FIRST Robotics Competition Season! Rich Wong FIRST E-Mail Blast Archive 0 06-09-2005 19:19
New Regional in Europe in 2006 unapiedra Regional Competitions 49 26-05-2005 00:07
Teaching "C" to 2006 students?? cbolin Programming 28 18-05-2005 12:10
