Go to Post They knew that the number of gracious, professional, make-your-grandmother-so-proud-she-will-puke moments of exemplary behavior by the teams would far outshine any minor mistakes or incidents of less-than-perfect decorum. - dlavery [more]
  #46   Spotlight this post!
Unread 13-01-2006, 12:12
Eria4044 Eria4044 is offline
None #0935 (Railerobotics)
Team Role: Webmaster
Eria4044 is on a distinguished road
Send a message via Yahoo to Eria4044
Re: Best Way to Shoot the Balls??
One of my teammates had the idea to have two spinners (like in old Hot Wheels tracks) in the barrel to accelerate the ball and prevent spin from killing accuracy.
Team 935 web team captain.
The team website: http://www.railerobotics.com/
  #47   Spotlight this post!
Unread 13-01-2006, 12:27
Stu Bloom's Avatar
Stu Bloom Stu Bloom is offline
I REALLY want to be Andy Baker
FRC #1018 (RoboDevils)
Stu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond repute
Send a message via AIM to Stu Bloom Send a message via Yahoo to Stu Bloom
Actually a spin on the ball will improve accuracy, probably backspin or spiral would be the best. In baseball the erratic behavior of a knuckleball pitch is due to the fact that it has little or no spin. It has to do with turbulence of the air around the ball, but since I don't use that stuff at work (and its been a LONG time since I was in school) I am unable to regurgitate any specific details.
Stuart Bloom
Mechanical Engineer
Rolls-Royce Corporation
FIRST Team 1018 - Pike HS RoboDevils
My activity for 2012:
  • Boilermaker planning committee
  • Israel Head Ref - DONE (and it was FANTASTIC!)
  • Boilermaker Regional (with 1018) - DONE
  • Midwest Head Ref - DONE
  • WORLD Championships (with 1018) - DONE
  • IRI Head Ref - DONE
  • CAGE Match Head Ref
  #48   Spotlight this post!
Unread 14-01-2006, 09:59
Really? I assumed that, if you spun the ball one way, it would veer off to one side once out of the barrel. Or you could make a long barrel, which would have problems of its own. Maybe it was my analogy at one meeting that the balls were like musket balls. Maybe I just need more sleep.
  #49   Spotlight this post!
Unread 14-01-2006, 10:44
BrianR BrianR is offline
AKA: Brian Roehl
FRC #1525 (Warbots)
Team Role: Electrical
BrianR has a spectacular aura aboutBrianR has a spectacular aura about
Send a message via AIM to BrianR
I agree with Eria, because when you think of spin on something like a football, that helps to prevent different faces from being on the front, and thus pose different amounts of drag, causing the ball to tumble even worse. In the case of one of these balls, it is unclear if it will act like a baseball, because these have far less mass per unit of volume, and thus when accelerated have less momentum keeping them going forward. As the physics aren't totally clear, I asked my physics teacher about it, and he said to stay away from spin on this kind of ball. He didn't see the exact ball though, and I think the most definitive way to know how the ball will react to spin is to mock up a shooter and try it, which is what my team hopes to accomplish this weekend, among a million other things.
  #50   Spotlight this post!
Unread 14-01-2006, 12:22
Mark Pettit's Avatar
Mark Pettit Mark Pettit is offline
Addict
FRC #0991 (The Dukes)
Mark Pettit is a name known to allMark Pettit is a name known to allMark Pettit is a name known to allMark Pettit is a name known to allMark Pettit is a name known to allMark Pettit is a name known to all
More video footage of Poof Balls being launched through a flywheel.
Our team borrowed the volleyball serving machine from our athletic department and you can see the footage HERE.
Mark Pettit
Team #991 - The Dukes
Brophy College Preparatory
Phoenix, Arizona, USA
THE DUKES: Humans Competing In The Unlimited Class
Last edited by Mark Pettit : 14-01-2006 at 19:15. Reason: 'Cannot spell correctly. . .
  #51   Spotlight this post!
Unread 14-01-2006, 13:30
Squirrelrock's Avatar
Squirrelrock Squirrelrock is offline
I may be teh programmer?
AKA: Keegan
FRC #0414
Squirrelrock will become famous soon enoughSquirrelrock will become famous soon enough
Send a message via AIM to Squirrelrock
617 has so far made a prototype with AC drills driving the top and bottom wheels on the softball-style shooter, with the top one smaller than the bottom wheel. The bottom wheel was the 12ish inch pneumatic wheel from two years ago, and the top "wheel" was two 5 inch diameter wheels duct taped together on a shaft so that there was a depression between them. The speeds that we shot at were right around max depending on the speeds of the wheels. We got some major backspin and can hit the goal's center consistantly from midfield.
Good luck to all.
<edit>
we have a 4-inch wide channel to feed the ball through the shooter also. that probably helps with the straightness of the shot.
</edit>
Look what I did to Dave:
Aaacckkk! Guurrkkk! Sssnorrrrkkkkk! Brain ... explode ... will. AAAArrrrggghhh!! Must ... not ... think ... about ... 2007 ... yet. Uuurrgghh!!! Still ... have .... to ... resolve ... how ... to ... pack ... parachutes ... for ... 2006 ... Ooorrrkkggnn!!
Sweet!
The scientists of today think deeply instead of clearly. One must be sane to think clearly, but one can think deeply and be quite insane.
- Nikola Tesla
Genius might be described as a supreme capacity for getting its possessors into trouble of all kinds.
- Samuel Butler
  #52   Spotlight this post!
Unread 14-01-2006, 14:13
stinger's Avatar
stinger stinger is offline
The laziest animator ever!!!!
AKA: wouldn't you like to know;)
Team Role: Animator
stinger is an unknown quantity at this point
Originally Posted by |20807 61|2|_
im thinking of a hot wheels sort of thing where u pick the balls up they go down into a basket or some sort of holding device and then shoot up between 2 wheels kinda the same thing but w/e
ditto
There is a method to my madness..I just don't know what it is...then again if I did know then I wouldn't be mad now would I?!?!
Avatar by VG Cats
  #53   Spotlight this post!
Unread 14-01-2006, 16:51
Mr. A's Avatar
Mr. A Mr. A is offline
Long Live the Fridge
AKA: Mark R Andrews
FRC #3637 (Daleks)
Mr. A has a spectacular aura aboutMr. A has a spectacular aura aboutMr. A has a spectacular aura about
Originally Posted by Lil' Lavery
a trebuchet would totally win the cool award
Im trying to think of an effective way to rifle the ball in a mechanism similar to the softball laucher.
there are also many hybrid ideas to the softball laucher, including tubes with belts in them, multi-ball lauchers, "gatling guns" etc etc etc
We thought about rifling which could be introduced by a series of small, slightly angled, opposing wheels, but realized there is a problem. These balls are not equally balanced. They always roll to their heavier side where the injection point is. Spinning the ball will most likely produce an unpredictable wobble depending on where that heavier side is when it goes through the shooter.
The Trebuchet would definitely be cool, but difficult to load! The counter weight is a problem too. Maybe a dangling compressor.
Go teams 3637 & 869[/url]
  #54   Spotlight this post!
Unread 16-01-2006, 06:13
Nimmy Nimmy is offline
also Head of Strategy\Translation
AKA: Nimrod Amir
FRC #1577 (SteamPunk)
Team Role: Animator
Nimmy is a jewel in the roughNimmy is a jewel in the roughNimmy is a jewel in the roughNimmy is a jewel in the rough
Send a message via ICQ to Nimmy Send a message via AIM to Nimmy Send a message via MSN to Nimmy
whilst we are not using the catapult it would be pretty cool if someone did
and it wont be that bad of mechanism
it will be VERY percise, but will only shoot I guess 2-4 balls in 10 seconds
the thing is we wanted to do it like a gear in a car, it shoots, but the motor leaves the catapult when it hits the angle, so it falls back down (after it hits a bumper or whatever also)
we didn't go that way eventually
but it would be cool to se someone do it =)
  #55   Spotlight this post!
Unread 16-01-2006, 09:57
Faith's Avatar
Faith Faith is offline
AKA: Plooshiska
FRC #1100 (The T'Hawks)
Team Role: Scout
Faith will become famous soon enoughFaith will become famous soon enough
We have some major backspin as well, but without a wheel moving on top... In our case the backspin also causes a very accurate shooting mechanism. There was no need for extra barrel.
POLL: have small balls been abandoned? Solace General Forum 44 04-09-2004 17:53
New Jersey Regional Status Aignam Regional Competitions 144 21-07-2004 17:04
Thoughts on the competiton balls Petey Regional Competitions 26 14-03-2004 09:31
Will ANYONE mess with the black balls? archiver 2001 0 23-06-2002 22:35
Just curious, how many robots could shoot or toss balls into the goal? Alan Ing General Forum 7 13-05-2002 19:09
