Go to Post Have you been formally diagnosed as a masochist, or are you just a mentor? - GeeTwo [more]
Unread 11-01-2006, 17:57
Otrobotics Otrobotics is offline
FRC #1334
Otrobotics is on a distinguished road
Question concerning vision target
My team recently attempted to start building parts of the field. Unfortunately, we couldn't find the box for the vision target, as well as the majority of the miscellaneous parts. I was just wondering if other groups in this competition received the the frame, since our group only received the lights, transformers and lexan cover plate. Were they included in the kit or were groups expected to custom build or buy them? If so, where can they be bought?
Unread 11-01-2006, 18:01
Re: Question concerning vision target
If it wasn't on the list of kit parts, it shouldn't have been included. It wasn't on the list, was it? I believe there are plans out there (I would guess FIRST website). And, the target itself (sans box) was the only part of the field provided by FIRST; you have to build your own practice field (unless another team allows you to share theirs).
devicenull devicenull is offline
Robot? We need a robot?
Rookie Year: 1234
devicenull is just really nicedevicenull is just really nicedevicenull is just really nicedevicenull is just really nicedevicenull is just really nice
Thats all you get for the box, you have to build the rest yourself (It's not that hard, shouldnt take too long)
Unread 11-01-2006, 19:55
jskene jskene is offline
None #0612
jskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to behold
Aside from some double-sided tape, velcro and some wooden spacers, you only need the aluminum housing, which is Hammond part # 144-26. You can buy it here:
http://www.mouser.com/index.cfm?&han...d&N=0&crc=true
Unread 11-01-2006, 20:36
coastertux coastertux is offline
Penn State Class of 2010!
AKA: Steve
FRC #1640 (sab-BOT-age)
coastertux is just really nicecoastertux is just really nicecoastertux is just really nicecoastertux is just really nicecoastertux is just really nice
Send a message via AIM to coastertux
There is a scematic in the documentation on the FIRST website. Direct link below:
http://www2.usfirst.org/2006comp/Dra...ION_TARGET.pdf
"The important thing is not to stop questioning. Curiosity has its own reason for existing. One cannot help but be in awe when he contemplates the mysteries of eternity, of life, of the marvellous structure of reality." ~Albert Einstein
DHSE '06, PSU '10 (Eberly College of Science - Chemistry)
Unread 11-01-2006, 20:58
Greg Marra Greg Marra is offline
[automate(a) for a in tasks_to_do]
FRC #5507 (Robotic Eagles)
Greg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond repute
Why bother buying it and waiting for it to arrive when you can make it in an hour or two out of aluminum or wood?
Asides from that fact that buying it means you won't have the jankiest looking vision target ever...
Unread 12-01-2006, 07:35
None #0612
You can certainly make it out of wood, but you should line the back with brushed aluminum if you want to replicate the reflectance of the aluminum chassis that is used on the competition version.
A wooden box will not reflect as much light off the back, and the target will appear to be less bright than the target your robot will see at the competition.
Unread 14-01-2006, 14:17
skillinp's Avatar
skillinp skillinp is offline
FRC #1388 (Eagle Robotics)
skillinp is an unknown quantity at this point
How about covering the inside of a wooden box w/aluminum foil?
There's no honorable way to kill, no gentle way to destroy. There is nothing good in war. Except its ending.
Abraham Lincoln
"The Savage Curtain"
Unread 14-01-2006, 15:00
David55 David55 is offline
AKA: David Hillman
FRC #1577 (Steampunk) & FRC #125 (NUTRONS)
David55 is a splendid one to beholdDavid55 is a splendid one to beholdDavid55 is a splendid one to beholdDavid55 is a splendid one to beholdDavid55 is a splendid one to beholdDavid55 is a splendid one to behold
Building the box is not a big deal.
The entire construction of the vision target took us about two hours.
We used blocks of foamed PVC to build the box, and the rest (cathodes, transformers and cover) came in the kit.
Unread 14-01-2006, 17:57
Rookie Year: 1234
I think you need to be careful of heat on that.. metal would distribute it pretty nicely, but thats going to hold it all in..
Unread 14-01-2006, 18:30
jerry w's Avatar
jerry w jerry w is offline
Free Agent Mentor
no team (Team Krunch)
jerry w has much to be proud ofjerry w has much to be proud ofjerry w has much to be proud ofjerry w has much to be proud ofjerry w has much to be proud ofjerry w has much to be proud ofjerry w has much to be proud ofjerry w has much to be proud ofjerry w has much to be proud of
don't worry about the reflection inside the box. our wooden box was bright enough to see at any distance. and up close was so bright that it saturated the camera. of course, the plywood base was very light colored.
jerry w
Happiest when people tell the truth... However, I am blessed with many friends.
Unread 14-01-2006, 19:01
Jon K. Jon K. is offline
n.e.r.d #6
Jon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond repute
Has anyone else found that the camera seems to like lighting tubes as well as the green light? Our camera while being tested today sometimes locked on to our lighting in our facility.
Alumnus of FLL 2000 ~ Alumnus of FRC173 2002-2005 ~ Mentor of FRC173 2006-2007 ~ Mentor of FRC 3780 2014
FIRST Volunteer since 2003
Manufacturing Manager
AndyMark, Inc.
http://www.andymark.com
Unread 14-01-2006, 19:19
Windwarrior Windwarrior is offline
AKA: Scott Davis
FRC #1777 (Viking Robotics Club)
Windwarrior is an unknown quantity at this point
yeah, our cam also like to follow the flouresent tube lights in the ceiling. We finally decided to call it a day and trouble shoot it tommorow.
My other car is a sailboat!!
Unread 14-01-2006, 19:24
Billfred's Avatar
Billfred Billfred is offline
1293 also found that it seemed to like the ceiling as much as the vision target.
After a bit of fiddling, though, we got the target tracked quite nicely.
Unread 14-01-2006, 20:44
If you are worried about reflectivity, it might be easier to paint the inside of your plywood light box white than to line it with foil. Don't forget to drill cooling holes in your box.
I am not the camera guy on our team, so I am NOT an expert on the camera. As I posted elsewhere, I talked to a very experienced robotics engineer who said that the CMU camera is prone to oversaturation from ultraviolet, which most fluorescents produce in abundance. He used a UV filter on the robot that won the Robo-Magellan competition at the 2005 Seattle Robothon event. Unfortunately, I don't know what kind of filter he used.
vision target Dakota Snow Kit & Additional Hardware 1 08-01-2006 23:00
Vision Target Chassis Mod? AnkurG Kit & Additional Hardware 1 08-01-2006 21:12
Question about rule <R26> --> Colours Bryan D Rules/Strategy 6 02-02-2005 16:09
Error - symbol 'e' has multiple definitions. HELLPPPPP BookerT Programming 2 24-01-2005 21:50
