Go to Post To put it simply: An adult coach impacts a team for two minutes. An adult mentor impacts a team for a lifetime. - dlavery [more]
Unread 09-01-2006, 15:12
kcy88's Avatar
kcy88 kcy88 is offline
Animator
AKA: Kevin
FRC #0075 (Roboraiders)
kcy88 is a jewel in the roughkcy88 is a jewel in the roughkcy88 is a jewel in the rough
Send a message via ICQ to kcy88 Send a message via AIM to kcy88
Re: Hair and Fur in MAX 8
Originally Posted by Ryan Dognaux
Is there some way you can net render with multiple computers involved? If you have that capability, it would allow multiple machines to work on your render job and speed up the process.
Also, any less detail will mean lower render times. High quality stuff takes a long time unfortunately.
Indeed there is! If you enable Bucket Rendering with the Mental Ray renderer instead of using backburner, you can use up to 8 cpus on ONE frame not including the computer that is hosting the scene. It's a thrill to watch more than 1 bucket render, and even more exciting to watch 8. However, from my experience from working on the safety animation, bucket rendering is ideal for test renders and Backburner is ideal for rendering animation.
The most effective way to use bucket rendering is to have a fast network and computers that are equal in performance. It doesn't help you if you have one really slow cpu and one fast cpu.
If you need a guide on how to setup bucket rendering, let me know, I'd be glad to help.
Team 75 - Roboraiders
Hillsborough High School Robotics
2006 Boston Regional Autodesk Visualization Award
2006 Boston Regional Engineering Inspiration Award
2006 New Jersey Regional Engineering Inspiration Award
2005 New Jersey Regional Autodesk Visualization Award
2005 Duel on the Delware champions
2005 Brunswick Eruption 4 champions
Unread 14-01-2006, 08:50
Capt.ArD Capt.ArD is offline
Animator
FRC #0116 (Epsilon Delta)
Team Role: Animator
Capt.ArD will become famous soon enoughCapt.ArD will become famous soon enough
Hey Nuttyman, Did you ever get it to work with wind?
link removed, see Mr. Fraggs' post
this is the video I made while messing around w/ hair. the first half is just the dude's head moving, the second half is movement due to wind. It really wasn't that hard, there are a few weird things that you have to tweak in the dynamics panel of the hair and fur modifier. It looks kinda unrealistic right now, but there are many things that i just cut corners on to save render time. It can be a LOT better.
SHout if ya'll still want help on figuring it out.
Unread 14-01-2006, 09:11
Ryan Dognaux's Avatar
Ryan Dognaux Ryan Dognaux is offline
Back Home in Indiana
FRC #4329 (Lutheran Roboteers)
Ryan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond repute
Send a message via AIM to Ryan Dognaux
I knew there was a way to do it, I was just wondering if their situation allowed them to do this. But excellent response nonetheless, I haven't set on up before so if I ever have to I'm definitley coming back to this thread.
Ryan Dognaux :: Last Name Pronounced 'Doane Yo'
Team 234 Alum: 2002 - 2005 :: Purdue FIRST Member: 2006 - 2009
Team 1646 Mentor: 2007 - 2009 :: Team 357 Mentor: 2009 - 2012
Team 4329 Mentor: Current
STL Off-Season Event: www.gatewayroboticschallenge.com
Unread 14-01-2006, 09:50
Mr.Fraggs's Avatar
Mr.Fraggs Mr.Fraggs is offline
Script0r
Mr.Fraggs will become famous soon enough
Send a message via AIM to Mr.Fraggs Send a message via MSN to Mr.Fraggs
hair test reaction video
tada
Unread 14-01-2006, 14:32
Nuttyman54's Avatar
Nuttyman54 Nuttyman54 is offline
Mentor, Tactician
AKA: Evan "Numbers" Morrison
FRC #5803 (Apex Robotics) and FRC #0971 (Spartan Robotics)
Nuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond repute
Send a message via AIM to Nuttyman54
I got it working, after tweaking the dynamics. I'm actually doing grass, so the reacton is a bit different, but it think it'll look great! How did you get the hair to not go through the head? everytime i select a collision object (including growth object) it doesn't collide...
Unread 14-01-2006, 14:38
Animator
Team Role: Animator
actually, i never assigned any collision object. It just happened that way.
To be honest, i was trying to make a funny-looking character and was messing around with funny hairstyles, and stumbled on this stuff. Then i thought "hey, sum1 on CD wanted to know how to do this" and i posted the vid.
So my guess is that you probably are making it harder than it needs to be. That happens alot, esp. in max, where there is a lot of stuff going on. try just redoing the hair and making sure you don't change anything that doesn't need to be.
BTW, im just doing grass, too. the head is just when im messin at home.
