Can we use the new (bigger) CIM motors in the kit-supplied transmission in place of the old (small) ones?
Re: New CIMs in kit transmission
Please search before you post. The answer is "NO"
www.Andymark.biz sells conversion kits for the transmissions to work with the bigger motors (as seen here). The transmission designer Paul Copioli suggests, however, that you buy two more CIM motors and use 4 small ones. (As he says here) Last edited by Swan217 : 14-01-2006 at 17:07. |
Sorry (I'm kind of new here), and thanks for the info. For future reference, what would I search for to find that?
they say don't use the new big mini-bike large CIMs for the provided kit transmission for a number of reasons. The RPM and torque are different, they draw different amounts of current, the size of the output shaft is different...
Yes, you can compensate for all of these things, but why would you? There's a conversion kit made my AndyMark. Trying to use the mini-bike CIMs with the kit transmission is a bad idea; it's not designed to work that way. If you want to use the mini-bike CIMs, it's better to use their conversion kit because a professional has already done the work for you. |
#7
I'm not sure if this will answer your question, but here is a link to the discussion about the picture of the Transmission Conversion.
http://www.chiefdelphi.com/forums/sh...threadid=41603 Hope this was of some help to you. |
| pic: Kit Transmission Upgrade kit | Andy Baker | Extra Discussion | 17 | 29-01-2006 01:27 |
| Kit Transmission | KillerCows456 | Motors | 17 | 28-01-2006 17:10 |
| Tapping Into Kit Transmission Casing | Madison | Technical Discussion | 6 | 13-12-2005 14:29 |
| Kit of Parts - Sprocket Spacers? and Transmission Lubrication? | wmurphy | Kit & Additional Hardware | 10 | 13-01-2005 01:09 |
