Go to Post Adaptability is the key folks. Your job will not be the same 10 years from now (when I retire), or 20 years or 30 years from now. The tools and systems you use will change, and you must be able to adapt along with them. - Bill Moore [more]
Unread 13-01-2006, 22:05
65_Xero_Huskie's Avatar
65_Xero_Huskie 65_Xero_Huskie is offline
One T
AKA: Mat
65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute
bumpers, a problem?
problem with bumpers..
i saw that the center of the bumper is higher than the center of the ball, and that makes it possible that the bumpers will cuse the robot to roll over the ball and get it stuck underneath, if someone can explain this differently, i would appreciate it, cuz thats a big thing i see wrong
Min-Max to the Max!
Unread 13-01-2006, 22:14
JBotAlan's Avatar
JBotAlan JBotAlan is offline
Forever chasing the 'bot around
AKA: Jacob Rau
FRC #5263
JBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond repute
Send a message via AIM to JBotAlan Send a message via Yahoo to JBotAlan
Re: bumpers, a problem?
I don't really see this as a problem.
From R35, last bullet point at bottom:
Bumpers must be positioned on the robot so that they remain between 2-1/2 inches and 8-1/2 inches above the floor
Even though what you said was right, the overlap is big enough, I think.
The bottom of the bumper, covered with smooth material (required in the bumper rule) should not catch the balls. I think it'll be low enough to not cause problems.
Just my take on it.
JBotAlan
Aren't signatures a bit outdated?
Unread 13-01-2006, 22:15
Donut Donut is offline
The Arizona Mentor
AKA: Andrew
FRC #2662 (RoboKrew)
The center is higher than the center of the ball, but the bumpers can extend all the way down to 2 & 1/2", so there shouldn't really be problems rolling over balls unless a team doesn't extend all the way down to that level, I would think.
Unread 13-01-2006, 22:17
prettyyinpinkk9 prettyyinpinkk9 is offline
I <3 Robots!!!
AKA: Casey
FRC #1539 (CUPID)
prettyyinpinkk9 is an unknown quantity at this point
Send a message via AIM to prettyyinpinkk9
You're correct...if the center of the bumper is higher than the center of the ball, the ball will roll under the robot, causing 2 different scenarios...1)the ball will cause the wheels to come off the ground, hendering any type of movement 2) the ball will cause only the front wheels to come off the ground, but as the robot moves forward, the ball forces the back wheels off the ground, but at the same time the front wheels are lowered back onto the ground
Unread 14-01-2006, 01:24
Henry_Mareck's Avatar
Henry_Mareck Henry_Mareck is offline
FRC #0418 (Purple Haze / LASA Robotics)
Team Role: Student
Henry_Mareck is a jewel in the roughHenry_Mareck is a jewel in the roughHenry_Mareck is a jewel in the rough
Send a message via AIM to Henry_Mareck
the bumpers are designed so that balls will not go under, as well as impact reduction.
FIRST does not want ball around wheels or in chain and sprockets.
I can imagine a balls going under a robot, and a spray of foam pieces coming out the other side. oops.
Unread 14-01-2006, 13:06
Schneidie's Avatar
Schneidie Schneidie is offline
AKA: Marc Schneider
FRC #0177 (The Bobcats)
Schneidie will become famous soon enoughSchneidie will become famous soon enough
I seriously doubt the fact that FIRST would overlook a problem that could destroy their equipment for all the competitions.
Unread 14-01-2006, 14:07
adam adam is offline
FRC #1717 (DP Engineering)
adam is an unknown quantity at this point
Send a message via AIM to adam
If bumpers can be 2.5 inches off the ground, and the center of the ball is at 3.5 inches (7 inch diameter i believe)........I don't see there being any problems.
Besides, i'm pretty sure that you can have other non-bumper material below 2.5 inches.
Unread 14-01-2006, 14:15
Nuttyman54's Avatar
Nuttyman54 Nuttyman54 is offline
Mentor, Tactician
AKA: Evan "Numbers" Morrison
FRC #5803 (Apex Robotics) and FRC #0971 (Spartan Robotics)
Nuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond repute
Send a message via AIM to Nuttyman54
yes you can (otherwise we'd need hovercraft robots), but any non-bumper material must be within the original 28"x38" footprint
Unread 14-01-2006, 14:32
we were just thinking of going for the hovercraft design...
Unread 14-01-2006, 14:35
Nuttyman54's Avatar
Mentor, Tactician
you know...i never checked to see if that was legal...good luck getting it to run off of the Exide!
Unread 14-01-2006, 14:57
SenseiSkins's Avatar
SenseiSkins SenseiSkins is offline
Bow to your SENSEI!
AKA: Garrett
FRC #0177 (Bobcat Robotits)
Team Role: Student
SenseiSkins is an unknown quantity at this point
I like bumpers
Unread 14-01-2006, 14:58
Eria4044 Eria4044 is offline
None #0935 (Railerobotics)
Team Role: Webmaster
Eria4044 is on a distinguished road
Send a message via Yahoo to Eria4044
Talking Re: bumpers, a problem?
If you had a hovercraft, could you fly above 5 feet?
Team 935 web team captain.
The team website: http://www.railerobotics.com/
Unread 14-01-2006, 22:55
pez1959's Avatar
pez1959 pez1959 is offline
Cap'n Patty
AKA: Patrick
FRC #1959 (Aye Aye Robot)
pez1959 is on a distinguished road
Send a message via AIM to pez1959 Send a message via MSN to pez1959 Send a message via Yahoo to pez1959
Ok I'll bite, <R08> states "The robot may not exceed the 60-inch height restriction at any time during the match."
And on a non-rule point, getting a hovercraft more than a few inches off the ground is hard...5 feet is nearly impossible.
Unread 14-01-2006, 22:59
Nuttyman54's Avatar
Mentor, Tactician
I think he's asking (jokingly of course) if you could make a 60" robot and then raise it a few inches with the hover-drive, thus breaking the limit...and the answer would be no, you can't
Unread 15-01-2006, 10:15
robotoby35138's Avatar
robotoby35138 robotoby35138 is offline
FRC #1522
robotoby35138 can only hope to improve
Thumbs down Re: bumpers, a problem?
about the hover craft it would be almost impossible to steer. and when you are even bumped by another robot you would just start bouncing around the arena. you would not have the acceleration to stop you from bouncing around the arena
Need a realistic Statics Problem sanddrag Technical Discussion 10 05-12-2005 15:07
Problem w/Mesh Kevin Thorp 3D Animation and Competition 4 17-02-2005 23:04
Programming Problem: Extremely Frustrating chantilly_team Programming 19 12-02-2005 23:00
The problem with scouting... archiver 2001 10 23-06-2002 23:49
Major problem with chipphua motors aka Scott White Motors 18 19-03-2002 19:44
