Go to Post Just get a nice big box of maraschino cherries and a cup of coffee and settle yourself down for a fun read. You'll be amazed at the ideas that you are going to have pop into your head. - JaneYoung [more]
Unread 14-01-2006, 15:37
SavannahStasher's Avatar
SavannahStasher SavannahStasher is offline
Secret Sneaker Stasher
FRC #0974
SavannahStasher is an unknown quantity at this point
Compiler Issues
After downloading Kevin Watson's "bells and whistles program" and updating the MPLAB IDE v7.20, I attempted to compile camera.mcw but ended up with an error:
Couldn't locate build tool. Check tool locations.
Link step failed.
BUILD FAILED
I've tried reinstalling MPLAB but I still receive the same message. There are no records of a bug in camera.mcw so I am assuming I did something wrong with installation. Any help would be appreciated.
Unread 14-01-2006, 15:45
iBheat's Avatar
iBheat iBheat is offline
FRC #0418 (Lasa Robotics)
iBheat is on a distinguished road
Re: Compiler Issues
If you are installing from the CD did you install the MCC18 that is included in the CD, it is the second link on the startup page the first link is for the IDE?
Unread 14-01-2006, 16:32
FRC #0974
Re: Compiler Issues
Yes, I did install the MCC18 . . .
Unread 14-01-2006, 17:59
Greg Marra Greg Marra is offline
[automate(a) for a in tasks_to_do]
FRC #5507 (Robotic Eagles)
Greg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond repute
Re: Compiler Issues
Are you sure you have the C18 compiler correctly linked with MPLAB so that MPLAB knows it's supposed to use the compilier when compiling?
It sounds like the problem is MPLAB goes to get the compiler, but it doesn't know where to look.
Unread 14-01-2006, 18:05
FRC #0974
Re: Compiler Issues
I figured out the problem. Thanks for all of your help!
Unread 28-01-2006, 16:33
radicalnerd radicalnerd is offline
Registered Luser
FRC #0668 (Apes of Wrath)
radicalnerd is an unknown quantity at this point
Send a message via AIM to radicalnerd
Re: Compiler Issues
what was the problem? can you tell me how you solved it? thanks
C18 Compiler v.3.00 Problems prograid Programming 6 10-01-2006 22:10
C18 v2.4 compiler location b_mallerd Programming 1 14-12-2005 16:43
IMPORTANT regarding the new C Compiler dlavery General Forum 12 14-01-2005 05:05
issues with if then else Andrew Rudolph Programming 1 15-01-2003 09:15
