Go to Post I saw 2274, a rookie team that had won the regional, gathered around their mentor. He was holding their trophy and saying, "This is what it is all about. Teamwork and cooperation. You guys did great." - Po-ser [more]
Unread 14-01-2006, 15:56
DonRotolo's Avatar
Back to humble
FRC #0832
Re: CIM motor shaft Coupler
Originally Posted by Epot86
first, how do u "broach for key stock" all we have is a drill press no other fancier tools. Also, how do u ensure that the holes are perfectly centered. If they are not wont it wobble and all break apart.
It can be done with care. It might take an hour or two and four tries...
Broaching by hand is also possible, but I'd recommend against it. If you must, use a small file, and you can't hold it by hand - clamp it and make a sliding block.
Alternative: Make a flexible coupling. You can buy one, one side 5/16" and drill it out, the other side 5/8. Make one by drilling out two seperate pieces, and use a heavy piece of stiff rubber hose to connect the two sides together (use hose clamps, balance the assembly).
Don
Big CIM Motor Specifics jakey Motors 1 13-01-2006 01:00
CIM Motors UlTiMaTeP Motors 13 10-01-2006 14:48
6 CIM Motors? psquared89 Kit & Additional Hardware 16 09-01-2006 08:47
CIM speed in reverse? colt527 Motors 41 06-12-2004 19:09
CIM vs. Drill motor duckshepherd Motors 3 15-02-2003 18:36
