Go to Post Maybe someone should start a FIRST Anonymous meeting to try to help the tragicly addicted... - BiTurboS4 [more]
Unread 14-01-2006, 11:50
railerobotics's Avatar
railerobotics railerobotics is offline
FRC #0935
railerobotics will become famous soon enough
Re: Can't find CMUCam2 demo.llb
After downloading the code to the robot controller and the terminal window pops up, nothing happens in it. Why is this?
Unread 14-01-2006, 13:25
Kevin Watson's Avatar
La Caņada High School
FRC #2429
If you downloaded the code a few days ago, the code was messed-up for a while.
-Kevin
Kevin Watson
http://kevin.org
Unread 14-01-2006, 14:55
FRC #0935
-Kevin
We've tried that and it still didn't work.
Unread 14-01-2006, 15:12
FRC #2429
Rebuild the code with debugging messages on (see camera.h) and post the output (if any) here.
-Kevin
Kevin Watson
http://kevin.org
Unread 14-01-2006, 15:32
FRC #0935
Here is the debug.
Camera: Initialized abnormally with code 131
Camera: Initialization state = 1
Camera: No EEPROM configuration data found; using default parameters
Camera: Initialization state = 2
Camera: Initializatoin state =3
This continues over and over again.
Unread 14-01-2006, 15:54
FRC #2429
Here is the debug.
Hmmm... You're camera is hanging on initialization state 3. Open camera.h and look for this line: "#define MAX_ACK_LOOP_COUNT 10" and change the 10 to 100 and let me know what happens when you re-run the code. This gives the camera more time to acknowledge the command before the initialization state machine gives up and starts over.
-Kevin
Kevin Watson
http://kevin.org
Unread 14-01-2006, 16:03
FRC #0935
-Kevin
We did that and it told us exactly the same thing.
Unread 14-01-2006, 16:19
FRC #2429
You've got power to the camera per the instructions? You've hooked-up the serial cable and TTL-RS232 board per the instructions? Have you tried the camera with the LabVIEW code? What does line 450 of serial_ports.c say?
-Kevin
Kevin Watson
http://kevin.org
Unread 14-01-2006, 16:32
FRC #0935
Yes we have power and have the ttl hooked up and the camera does work with labview and is calibrated. I have edited the code and changed line 450 of the serial port code to SPBRG2 = BAUD_115200
Unread 14-01-2006, 16:47
FRC #2429
Well, I don't know what to tell you. The debugging information indicates that your camera isn't communicating with the RC. Grasping at straws, try using the programming port of the RC to communicate with the camera. You'll need to modify the first option of camera.h to use the other serial port and use a male to male null modem serial cable (pin 3 -> pin 2, pin 2 -> pin 3, pin 5 -> pin 5) between the RC and camera.
-Kevin
Kevin Watson
http://kevin.org
Unread 14-01-2006, 17:22
FRC #0935
I really appreciate you taking time to help. I'll have to try that thing with the modem cable on monday if I can get a hold of one. If not, I have no idea what to do next.
Unread 15-01-2006, 03:16
FRC #2429
Can you try the software mentioned here and report back with the results?
-Kevin
Kevin Watson
http://kevin.org
Unread 15-01-2006, 11:46
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
One thing I have seen that causes the camera to hang, though I didn't notice if it is at STATE 3, is having BOTH the PWM/TTL connected to the RC AND the serial cable connected to the PC from the DB-9 on the camera. As I recall from last year, the camera can not run both simultaneously. And, yes, I know this from personal experience. It was definitely one of those "Bill, you doofus" moments.
This is what I observed the camera and servos do when it was hooked up incorrectly. Camera powers on correctly, RC boots normally, servos drive to what appears to be 127 or center position, and absolutely nothing shows up on the terminal window. When sending a "c" or "t" command to the port, a "NAK" will be returned sometimes.
I hope this helps out someone.
Unread 15-01-2006, 11:52
FRC #0935
-Kevin
We will try that and report back on monday.
Unread 15-01-2006, 13:12
N3OW N3OW is offline
FRC #0869
N3OW is an unknown quantity at this point
Post Re: Can't find CMUCam2 demo.llb
We have the Lab View code and it is working somewhat.
We have an issue with the pan going the wrong way from the target.
We had a issue with the image being upside down so we rotated the camera and that fixed that problem bur the pan goes opposite of the target any ideas as to why?
We are planning on using the Easy C programming, and lab view has the ability to export the configuration file for Easy C.
So if any one has any ideas how to correct the panning issues that would be great.
Thank you
Jay
n3ow11@gmail.com.
Example LabVIEW Apps - Dashboard, CMUcam2 and Motors Russ Beavis National Instruments LabVIEW and Data Acquisition 9 21-01-2007 17:19
CMUcam2 disclaimer Cody Carey General Forum 4 12-01-2006 01:19
CMUcam2 interfacing Kram Programming 2 27-05-2005 07:17
CMUCam2 Camera Code - Are important parts commented out? Mr. Lim Programming 4 14-01-2005 12:11
3dmax - setting a display option that I can't find DanL 3D Animation and Competition 5 05-01-2003 12:42
