CMU camera search
Our camera is working, but it cannot find the green light. It just turns around randomly looking for the light. We know that it cannot be other lights, and our green light is visible. We are using Kevin Watsons most recent simple camera code. We would appreciate some help. Thank you.
Re: CMU camera search
Have you tried it while connected to the serial port of a computer? You can have the camera directly connected to the computer and a power supply, open the CMUCam2 program for LabView, then load the 2006 Target.cfg configuration straight onto it. If it doesn't work there, then you probably have a bigger issue on your hands. But, it's most likely the best place to start.
My guess is you need to focus the camera.. Open up labview, keep using grab frame and rotating the lens until the picture is pretty crisp. It's possible someone thought the lens was loose and tightened it, screwing up the focus
for reference you can change the com port # by going to device manager->ports (COM &LPT) then double click on the converter name. click on the port settings tab, and change it to a com port that is not currently in use. for me com1 worked. and then voila labview started working. and the camera was sucessfuly recognized. also, if your converter is not recognized in MAX you can manually change the port options so it can actually talk to the camera. this may be stupid, but make sure that the camera is actually powered on. |
If you click the arrow on the side of the serial port control, do you get a list of ports that has the port you expect in it? Can you connect to the camera in hyper-terminal on that same port? -Joe |
#10
We kind of have the same problem. But our problem is that the camera finds the green target, but doesn't lock onto it. It just posts its coordinates (when we're watching the screen from ifi_loader) and then just keeps going on its search pattern. Is this supposed to happen or is it supposed to actually track the target?
P.S. It tracks the target fine when we use labview with the servos connected to the camera |
#11
-Kevin |
#12
What exactly do you mean by "hyper-terminal?" |
#13
It's a simple terminal application. You could also use the IFI loader terminal window. Cheers! -Joe |
#14
just as an update, our camera will now track green when we program it with MPLAB. We got a more updated version of the program for labview and got a new different error. It says it can't find the file. Another programmer is presently working on it. Although we got a different error, we still might get an the same error as before when we solve this present one.
Thanks for all your help, update you later. |
#15
The error says the camera might: 1- not have power 2- not connected by serial cable (using converter and haven't gotten to try hyperterminal) 3- not in correct serial port We have checked and checked again 1 & 3 and are in the process trying hyperterminal. |
| Scripting Setup and the Camera + Serial Port Drivers | CJO | Programming | 22 | 11-01-2006 17:42 |
| New Model Posted - 2005 CMU Camera | Ed Sparks | Inventor | 1 | 04-01-2006 23:36 |
| CMU Camera: San Jose Area | Bill Gold | Kit & Additional Hardware | 1 | 11-04-2005 18:30 |
| CMU Camera Tracking | auditt241 | Programming | 0 | 03-02-2005 16:33 |
| Easter Egg in CMU Camera Manual | David Foster | Programming | 8 | 10-01-2005 03:21 |
