Go to Post And (the video) didn't show how to do the "Charlie Brown". I still don't know how to do this... GAH!!!! - Elgin Clock [more]
Unread 14-01-2006, 17:53
Kevin Watson's Avatar
La Cañada High School
FRC #2429
Re: FRC Camera code in YCrCb Mode?
Originally Posted by Eldarion
Yes, set COMA (Register 18) to equal 8 (enable raw mode).
The camera command would be "CR 18 8" for RGB, and "CR 18 0" for YCrCb.
You can try this right from the camera menu. Just select the COMA register, enter the new value, hit enter, save changes, and then restart the camera. You should now be using RGB color space.
-Kevin
Kevin Watson
http://kevin.org
Scripting Setup and the Camera + Serial Port Drivers CJO Programming 22 11-01-2006 17:42
CMUCam2 code (FRC and EDU?) Amber Programming 0 15-02-2005 22:23
Camera Code Fishdude404 Programming 1 25-01-2005 18:59
Kevin Watson's Kick-off Demo Code! Mr. Lim Programming 27 22-01-2005 03:38
autonomous mode problem on field Chris_C Programming 17 26-03-2003 19:11
