Go to Post Your team will be more of a team and not a group of students who are just building a robot. Instead of being in FIRST, you will be FIRST. - JackN [more]
Unread 14-01-2006, 18:03
Leav's Avatar
Leav Leav is offline
Spud Gun Division
AKA: Leav Oz-Ari
FRC #3316 (D-Bug)
Leav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond repute
Send a message via ICQ to Leav Send a message via AIM to Leav Send a message via MSN to Leav
omni wheel instead of mecanum wheels
assuming a rectangular robot chassis, could you use normal omniwheels (andymark type, for example) turned at 45 degrees like this:
http://www.charmedlabs.com/robot3.jpg
give the same functionality as 4 mecanum wheels?
if so, what is the advantage of using mecanums?
Thanks,
-Leav
"We choose to build robots this season and do the other things; Not because they are easy, but because they are hard."
-Paraphrasing JFK
Participated in FIRST as a student: 2005-2006 (But still learning every season!)
Mentor: 2008 - ? (Team 2630 2008-2011, and Team 3316 since 2013)
Engineer: 2011 - ? (B.Sc. and M.Sc. in Mech. Eng. from the Technion IIT)
FIRST Volunteer - 2007 - ? (MC, FTA, FIRST Aid etc.)
Unread 14-01-2006, 18:17
MikeJ675's Avatar
MikeJ675 MikeJ675 is offline
Near Chaos Robotics
AKA: Mike Jeffries
no team (Near Chaos Robotics)
MikeJ675 is a name known to allMikeJ675 is a name known to allMikeJ675 is a name known to allMikeJ675 is a name known to allMikeJ675 is a name known to allMikeJ675 is a name known to all
Send a message via AIM to MikeJ675
Re: omni wheel instead of mecanum wheels
You have the wheels in line as opposed to at 45deg.
I--I
I--I
vs.
guess which is easier to build(and, somewhat more space efficient)
Team 675-Alumni
Near Chaos Robotics
Unread 14-01-2006, 18:20
REVving up for a new season
FRC #2848 (All-sparks)
yes you can, this is typically called a kiwi drive... the advantages of mecanum wheels come from the fact that they are still in a standard wheel orientation and can function as normal wheels or mecanum wheels while the drive system you are referring to only has 1 option of configurability. Both have different applications and both have been used in FIRST. It mostly comes down to preference.
Greg
Greg Needel│www.robogreg.com
Co-founder REV Robotics LLC www.REVrobotics.com
2014 FRC World Champions with 254, 469, & 74
Unread 14-01-2006, 18:23
Simon Strauss's Avatar
Simon Strauss Simon Strauss is offline
None #1155 (Sciborgs)
Simon Strauss has a brilliant futureSimon Strauss has a brilliant futureSimon Strauss has a brilliant futureSimon Strauss has a brilliant futureSimon Strauss has a brilliant futureSimon Strauss has a brilliant futureSimon Strauss has a brilliant futureSimon Strauss has a brilliant futureSimon Strauss has a brilliant futureSimon Strauss has a brilliant futureSimon Strauss has a brilliant future
Send a message via AIM to Simon Strauss
If i understand what your asking correctly i think your talking about a holonomic drive which looks like this
except on FRC not vex, which i believe can be done with the Andy mark trick wheels. they do more or less the same thing as mechanum wheels except with different methods, the only differences in function being that they are A) much easier to find and buy but are B) a possible disadvantage in this years game due to the issue of getting up the ramp with them(if i remember properly their was a thread on this issue) an issues that doesn't exist with mechanums.
my understanding of the basic idea behind them is that just like with mechanums they are designed to slip at certain angles which allows for lateral and diagonal movement of the robot. In actuality you are only pushing in the diagonal direction with a pair of wheels but the slip created by those rollers on them allows this to be converted into other directions
NYC Chairmen's Award Winners 2007 Thank you team 2265, you were our project and we couldnt have done it without you all
New Jersey Regional Finalists thanks to teams 359 and 486 Aloha
"Beware of the Ska Robot Army!" -The Aquabats
Unread 15-01-2006, 18:53
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
First off, thats a holonomic drive (a "kiwi drive" aka a kilo-drive only has 3 wheels as opposed to 4-or any other number-), and it has its advantages and disadvantages vs. a mechanum drive.
The advantage is programming simplicity, in favor of an omni-drive. With a "fixed roller" mecanum system, you have a 50% efficiency loss, as you do with a 4-wheeled holonomic system (unless spinning in a circle, when you are using all motors, therefore have 100%, giving an advantage to an omni-system in a spinning situation). In a system where you can actively turn the angle of the rollers on a mechanum wheel you can obtain a much higher efficiency, but that creates very very great depths of complexity in design, and is nearly impossible with the motor, money, and time limits imposed on FIRST.
Id also highly advice you mount your omni wheels in the corners, possibly even tilted to acheive a much greater support base, reducing the chances that you will be tipped over.
http://www.chiefdelphi.com/forums/sh...ght=drivetrain
see that thread for many details about omni-directional and other systems.
COTS Mecanum Wheels kmcclary Technical Discussion 1 10-01-2006 17:17
PITTSBURGH REGIONAL omutton Regional Competitions 49 18-03-2005 09:34
Four Wheel, all steering, non-omniwheel, ONE power/motor source drive FizMan Technical Discussion 31 27-04-2004 12:12
Lots of Wheels and F = u x N archiver 2001 17 23-06-2002 23:37
