Go to Post Lengthy posts are not discarded ones. Information comes in all sizes - Garii [more]
Unread 13-01-2006, 20:20
Epot86 Epot86 is offline
FRC #1389
Epot86 is an unknown quantity at this point
CIM motor shaft Coupler
Does anyone know of where to get a coupler for the small CIM motor shaft? We need something so we can connect the small output shaft (i think its like maybe 1/4) to a larger 5/8 in shaft to drive our ball launching wheels. We have something from a few years ago but its a three piece system and we were hoping to use just one piece. Thanks
Unread 13-01-2006, 20:35
Andrew Blair's Avatar
FRC #0306 (CRT)
Re: CIM motor shaft Coupler
It's a 5/16" output shaft. You can buy combination couplers, or you could just machine a 5/16" hole on one side of a piece of stock, and a 5/8" hole on the other. Or 5/8 ouput shaft.
EDIT----------------------------------------------------------------
Its an 8mm shaft. I was close...
-Sir Francis Bacon
-Albert Einstein
Unread 13-01-2006, 20:46
Manoel's Avatar
Manoel Manoel is offline
FRC #0383 (Brazilian Machine)
Manoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond repute
Send a message via ICQ to Manoel Send a message via MSN to Manoel
Actually, it's an 8 mm shaft. 5/16" is 7.9375 mm. Good luck with the interference fit!
Manoel Flores da Cunha
Brazilian Machine
Team # 383
Unread 13-01-2006, 20:52
FRC #0306 (CRT)
Whoops, we use english, I always thought I was just getting a bad measure.
-Sir Francis Bacon
-Albert Einstein
Unread 13-01-2006, 21:06
FRC #1389
so no one knows of a 8mm to 5/8 coupler existing. Also, where could a get the combination couplers that were mentioned above.
Unread 13-01-2006, 21:22
Manoel's Avatar
Machining one is entirely out of question?
Brazilian Machine
Team # 383
Unread 13-01-2006, 21:35
Kam-AL Kam-AL is offline
FRC #1310
Kam-AL is an unknown quantity at this point
Instead of having a direct connection why not make a mini gear box in which a gear from the small shaft attaches to a gear in the large shaft. I think it might work, havent tried it myself.
Unread 13-01-2006, 21:44
FRC #0306 (CRT)
http://www1.mscdirect.com/CGI/N2DRVSH
Unfortunately, I can't find a combo coupling, so you'll have to turn down the shaft you want to connect to 5/16" as well. You will have no trouble connecting 5/16" and 8mm, it's very close. Unless you really want it to be perfect.
-Sir Francis Bacon
-Albert Einstein
Unread 13-01-2006, 22:36
Ceal Craig's Avatar
Ceal Craig Ceal Craig is offline
Ceal Craig is a glorious beacon of lightCeal Craig is a glorious beacon of lightCeal Craig is a glorious beacon of lightCeal Craig is a glorious beacon of lightCeal Craig is a glorious beacon of lightCeal Craig is a glorious beacon of light
You could use the old 1" Al hex block, drill appropriate size holes on either side, broach for key stock.
That is what we did on one robot recently
Ceal Craig
Unread 13-01-2006, 22:41
FRC #1389
first, how do u "broach for key stock" all we have is a drill press no other fancier tools. Also, how do u ensure that the holes are perfectly centered. If they are not wont it wobble and all break apart.
Unread 13-01-2006, 23:04
Ceal Craig's Avatar
Well, that is a toughie with only a drill press, I admit. We cut the accurately holes using a lathe and have an arbor press and the tools to broach for the broaching.
Our first year (this is our fourth) we made one tool investment that has really paid off, we bought a bench top arbor press, for $200? or thereabouts. We broach key stock cuts in couplings, gears, sprockets, etc. and we press bearings in effectively and such. The lathe is a very old one we inherited when the auto shop closed at the school.
Sorry we couldn't be of more help. Best wishes!
Ceal Craig
Unread 14-01-2006, 15:56
DonRotolo's Avatar
Back to humble
FRC #0832
It can be done with care. It might take an hour or two and four tries...
Broaching by hand is also possible, but I'd recommend against it. If you must, use a small file, and you can't hold it by hand - clamp it and make a sliding block.
Alternative: Make a flexible coupling. You can buy one, one side 5/16" and drill it out, the other side 5/8. Make one by drilling out two seperate pieces, and use a heavy piece of stiff rubber hose to connect the two sides together (use hose clamps, balance the assembly).
Don
Unread 14-01-2006, 18:44
Theory6RobotiX's Avatar
Theory6RobotiX Theory6RobotiX is offline
Pi is exactly 3!!! Joking...
FRC #1241 (Theory6)
Theory6RobotiX is on a distinguished road
You could drill a 5/16 hole in the end of a 5/8 peice of bar stock(hard with only a drill press, but i think it can be done ). And then you could drill and tap for a set screw on the face of the shaft to hold the output shaft from the CIM motor.
Hope this helps. Good Luck
Unread 14-01-2006, 22:05
Biff Biff is offline
AKA: Tom Cooper
#1227 (Techno Gremlins)
Biff is a jewel in the roughBiff is a jewel in the roughBiff is a jewel in the roughBiff is a jewel in the rough
The shaft is really 8 mm we just used a 5/8" by 1" piece of keyed shaft and drilled a 8 mm hole in the center with a drill press. Starting with a 1/8" bit held near the tip vertically with the shaft in the drill press. With care it's not too hard to center. We set the speed all the way up for this, Then reduced to normal speeds to drill the final 8 mm hole through. Then tapped for the second set screw on the sprocket, drilled in place and tapped so the treads between the sprocket and shaft with the 8 mm hole line up. Put a small dimple in the cim shaft add key (before you tap) to help with balance. One or our mentors has a 8 mm bit. You can get metric drill bits on-line or from a good tool supply, most hardware and home building places don't carry metric. As mentioned above a broach and a arbor press can be a big help, But there are other ways to get what you need.
Big CIM Motor Specifics jakey Motors 1 13-01-2006 01:00
CIM Motors UlTiMaTeP Motors 13 10-01-2006 14:48
6 CIM Motors? psquared89 Kit & Additional Hardware 16 09-01-2006 08:47
CIM speed in reverse? colt527 Motors 41 06-12-2004 19:09
CIM vs. Drill motor duckshepherd Motors 3 15-02-2003 18:36
