Go to Post In the absence of a valid game hint, the natives in CD tend to get restless and resort to this sort of pun-ishment of one another. - David Brinza [more]
  #31   Spotlight this post!
Unread 11-01-2006, 20:56
Re: Nerf ball starting at 12m/s 45 degree angle ending at 8ft 6in w/ air resistance
Originally Posted by Mirza95vx
Air resistance is not a factor unless you are going 75+ mph.
Aerodynamic drag is definitely a factor for a fluffy object like a Poof ball. It's not an extremely large factor, but it has a real and noticeable effect.
  #32   Spotlight this post!
Unread 12-01-2006, 01:56
Tatsu Tatsu is offline
Audiophile and Physicist.
AKA: Tatsu Hashimoto
FRC #1072 (Harker Robotics Team)
Tatsu will become famous soon enough
Send a message via AIM to Tatsu
Air resistance is not a factor unless you are going 75+ mph. So you dont have to account air resistance into the equation.
You're kidding right? You lose around 4 meters to air resistance fireing 45 degrees from 0 -> 0 at 12 m/s. This is fairly nontrivial. Initial deceleration is easy to calculate
F= 1/2 Cd * rho * A * v^2
for a poof ball, thats's about
F= 7.52e-3 * v^2
F= 1.08 Newtons.. that may seem insignificant.. but the poof ball is light..
F=ma=1.08 , so taking m = .18 kg we get a = 6.016 m/s^2 deceleration..
yes, that's about 2/3rds g, that's nontrivial.
  #33   Spotlight this post!
Unread 12-01-2006, 07:59
You drive a Honda Scion, dont you?
(Aerodynamics ?! we dont need no stinking aerodynamics! :^)
  #34   Spotlight this post!
Unread 12-01-2006, 09:07
galewind's Avatar
galewind galewind is offline
... more like a temperate breeze
AKA: Chris Gregory
FRC #1089 (Team Mercury)
galewind has a reputation beyond reputegalewind has a reputation beyond reputegalewind has a reputation beyond reputegalewind has a reputation beyond reputegalewind has a reputation beyond reputegalewind has a reputation beyond reputegalewind has a reputation beyond reputegalewind has a reputation beyond reputegalewind has a reputation beyond reputegalewind has a reputation beyond reputegalewind has a reputation beyond repute
Send a message via AIM to galewind
ugliest...vehicle...ever...
Chris G
Advisor, Team Mercury (1089), Hightstown High School
  #35   Spotlight this post!
Unread 12-01-2006, 13:51
Btw, the 2-dimentional version of calculation is done.
check the programming section for my mathematica notebook its called something like traj.zip.. gimmie a day and I'll also upload the raw data in CSV form.
  #36   Spotlight this post!
Unread 12-01-2006, 19:49
racsan12345 racsan12345 is offline
FRC #1351
racsan12345 is an unknown quantity at this point
For launching 4.5 feet to 8.5 feet:
Please input the initial velocity in meters per second: 12.8
Please input the coefficient of drag (0.07 - 0.5): 0.416
The uber best range is 14.7775 meters at an uber angle of 47 degrees.
C++ Code:
#include <iostream.h>
#include <math.h>
int main()
// float i = cos(x); x is in radians
// float i = atan(x); i is in radians arctangent
float x;
float y;
float v_initial = 12.8;
float v_x;
float v_y;
float initial_angle;
float theta;
float drag;
float area = pow((3.5 * 2.54 / 100), 2) * 3.14159;
float mass = .206; //kilograms
float C_D; //Coefficient of Drag
float a_x;
float a_y;
float increment = .01; //Incrementing time
float best_range;
float rad_conv = 2.0 * 3.14159 / 360.0;
float uber_best_range = 0;
float uber_angle = 0;
cout << "This program will calculate the maximum range and best angle to launch a 7 inch diameter poof ball." << endl << endl;
cout << "Please input the initial velocity in meters per second: ";
cin >> v_initial;
cout << "Please input the coefficient of drag (0.07 - 0.5): ";
cin >> C_D;
for(initial_angle = 10; initial_angle <= 80; initial_angle++)
x = 0;
y = 0;
v_x = v_initial * cos(initial_angle * rad_conv);
v_y = v_initial * sin(initial_angle* rad_conv);
best_range = 0;
do
theta = atan(v_y/v_x);
drag = .5 * C_D * area * sqrt(pow(v_x, 2) + pow(v_y, 2));
a_x = drag / mass * cos(theta);
a_y = drag / mass * sin(theta) + 9.8;
v_x = v_x - a_x * increment;
v_y = v_y - a_y * increment;
x = x + v_x * increment;
y = y + v_y * increment;
if(y > 1.3 && v_y < 0)
best_range = x;
}while(y >= 0);
cout << "At " << initial_angle << " degrees, the best range is " << best_range << " meters." << endl << endl;
if(best_range > uber_best_range)
uber_best_range = best_range;
uber_angle = initial_angle;
cout << "The uber best range is " << uber_best_range << " meters at an uber angle of " << uber_angle << " degrees.";
return 0;
--Ownage
  #37   Spotlight this post!
Unread 12-01-2006, 20:06
nice, nearly identical code, different language.
(btw, you might want to run it for <1 degree increments)
  #38   Spotlight this post!
Unread 12-01-2006, 20:47
Have I been trolled?
The Scion Xb is Toyota's ugly cube. Honda's ugly cube is the Element.
  #39   Spotlight this post!
Unread 14-01-2006, 00:15
Nuttyman54's Avatar
Nuttyman54 Nuttyman54 is offline
Mentor, Tactician
AKA: Evan "Numbers" Morrison
FRC #5803 (Apex Robotics) and FRC #0971 (Spartan Robotics)
Nuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond repute
Send a message via AIM to Nuttyman54
971 got .41 ish as our Coefficient of drag (using wind-tunnel testing). Can we assume this is verified. Also, I don't know if this has been explained, but the "rho" in the drag equation is air density, generally around 1.2 kg/m^3.
  #40   Spotlight this post!
Unread 14-01-2006, 19:04
.41 matches prediction. prediction is .416 with flow of 12m/s
