Go to Post They already tried that... But here is the thing: it wasn't a bunch of guys in white coats. It was 3 guys: 1 in denim, 1 with a pony-tail, and 1 with a bright colored shirt.... - FIRSTtm134 [more]
Unread 14-01-2006, 16:16
Mike's Avatar
Mike Mike is offline
has common ground with Matt Krass
AKA: Mike Sorrenti
FRC #0237 (Sie-H2O-Bots (See-Hoe-Bots) [T.R.I.B.E.])
Mike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond repute
Creating new MPLab Project
So today I tried opening up the '06 code on my MPLAB 6.3. It wouldn't open, so I figured "OK, I can just make a new project." I did that, got the correct chip to program for, etc. Now it gave me an error on
Generate_Pwms(pwm13,pwm14,pwm15,pwm16);
The error was
C:\FIRST\code\user_routines_fast.c:143:Error [1203] too few arguments in function call
So, I did a search for Generate_Pwms. It returned
#ifdef _FRC_BOARD
  /* located in ifi_library.lib */
void Generate_Pwms(unsigned char pwm_13,unsigned char pwm_14,
				   unsigned char pwm_15,unsigned char pwm_16);
#else
void Generate_Pwms(unsigned char pwm_1,unsigned char pwm_2,
				   unsigned char pwm_3,unsigned char pwm_4,
				   unsigned char pwm_5,unsigned char pwm_6,
				   unsigned char pwm_7,unsigned char pwm_8);
#endif
So I assume it is using the second function prototype. This is probably because I neglected to set the pre-processor _FRC_BOARD. I looked in all the menus and such, but couldn't find a listing of pre-processor directives and their values. How do I change that value?
Thanks
http://www.mikesorrenti.com/
Unread 14-01-2006, 18:13
Re: Creating new MPLab Project
I don't have a copy of MPLAB handy to check, but I'm pretty sure you'll find a "Compiler Options" choice under the Project menu.
Unread 14-01-2006, 18:22
Manoel's Avatar
Manoel Manoel is offline
FRC #0383 (Brazilian Machine)
Manoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond repute
Send a message via ICQ to Manoel Send a message via MSN to Manoel
With your project open in MPLAB:
Project > Build Options > Project
There, select the MPLAB C18 tab and, under Macro Definitions, add _FRC_BOARD.
You can also enable code optimizations by editing the "-Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa-" strings.
These two posts discuss it in more detail.
Manoel Flores da Cunha
Brazilian Machine
Team # 383
Unread 14-01-2006, 19:09
Mike's Avatar
AKA: Mike Sorrenti
Ok, so I did that. I also had to have a custom error suppressantt added to my build options, so I now use the "User alternate settings" function. So to add a macro, I found out that I needed to append -D_MACRO_NAME to my build options. My total build options are now
-D_FRC_BOARD -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa- -nw=2066
But now I get the error
Executing: "C:\Program Files\MPLAB IDE\MCHIP_Tools\mplink.exe" /l"c:\mcc18\lib" "18f8520.lkr" "C:\FIRST\code\camera.o" "C:\FIRST\code\ifi_startup.o" "C:\FIRST\code\ifi_utilities.o" "C:\FIRST\code\main.o" "C:\FIRST\code\serial_ports.o" "C:\FIRST\code\terminal.o" "C:\FIRST\code\tracking.o" "C:\FIRST\code\user_routines.o" "C:\FIRST\code\user_routines_fast.o" "C:\FIRST\code\FRC_alltimers.lib" "C:\FIRST\code\FRC_alltimers_8520.lib" "C:\FIRST\code\FRC_library.lib" "C:\FIRST\code\FRC_library_8520.lib" /o"FRC.cof"
MPLINK 3.50, Linker
Copyright (c) 2003 Microchip Technology Inc.
Assertion failed: 0, file ..\..\mplink\LanguageToolShared/mgproc.c, line 873
This application has requested the Runtime to terminate it in an unusual way.
Please contact the application's support team for more information.
Any idea of what's wrong now?
Unread 15-01-2006, 14:26
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
I believe this is akin to the infamous syntax error. It decided it didn't like you, or something.
First try cleaning the project and rebuilding (in case of file corruption). Then try changing some compilation options. (eg, optimization)
Programming Vex w/ MPLab dababyjebus FIRST Tech Challenge 27 25-04-2008 09:11
openFIRST Project Announces Pending Deadline for End of Support for Old Versions Timothy D. Ginn FIRST-related Organizations 0 11-07-2005 22:40
Printing of a project in MPLAB DanDon Programming 0 10-01-2005 21:10
