Go to Post COMPETE like crazy for the 2 minutes you are on the field, COOPERATE like crazy all the rest of the time. When we play this way, we all win. - Chris Fultz [more]
Unread 14-01-2006, 20:45
wilshire's Avatar
wilshire wilshire is offline
OSNAP. a gear flew out of the robot
wilshire is just really nicewilshire is just really nicewilshire is just really nicewilshire is just really nice
Send a message via AIM to wilshire
Making spheres in Inventor
I was wondering how you can make a sphere in Inventor. I currently am using Inventor 10 and would like to model the Poof balls in our robot drawing.
AIM: wilshire461
Purdue FIRST Teams
Team 461 -http://www.boilerinvasion.org/
Team 1646 - http://www.precisionguessworks.org/
Team 1747 - www.harrisonboilerrobotics.org
Unread 14-01-2006, 20:56
Andrew Blair's Avatar
FRC #0306 (CRT)
Re: Making spheres in Inventor
I would make a half of a cross section and then revolve it. Putting the markings on it and the dimples is another story...
-Sir Francis Bacon
-Albert Einstein
Unread 14-01-2006, 20:58
JoeXIII'007's Avatar
Happy Birthday! JoeXIII'007 JoeXIII'007 is offline
Pragmatic Strategy, I try...
AKA: Joeseph Smith
FRC #0066
JoeXIII'007 has a reputation beyond reputeJoeXIII'007 has a reputation beyond reputeJoeXIII'007 has a reputation beyond reputeJoeXIII'007 has a reputation beyond reputeJoeXIII'007 has a reputation beyond reputeJoeXIII'007 has a reputation beyond reputeJoeXIII'007 has a reputation beyond reputeJoeXIII'007 has a reputation beyond reputeJoeXIII'007 has a reputation beyond reputeJoeXIII'007 has a reputation beyond reputeJoeXIII'007 has a reputation beyond repute
Send a message via AIM to JoeXIII'007
It's relatively easy, but I haven't drawn a sphere in months (since CAD II class last school year) so forgive me if my instructions are wrong.
1. Draw a circle 7 inches in diameter.
2. Draw a line straight through the center of the circle vertically.
3. Trim one half of the circle.
4. Get out of sketch mode (finish sketch). I'm assuming you were in sketch mode previously.
5. Find the command called revolve. Click on it.
6. Highlight the remaining half of the circle, and choose to revolve 360 degrees around the vertical line as your axis. Revolve to a full extent.
7. Click OK and that should do it, you will have a sphere.
I was trying to load inventor up while doing this to create better instructions, but the video card screwed up. So if I got any of this wrong, I will edit.
-Joe
[Edit] It's all correct now, that should do. [/Edit]
Joeseph P. Smith
jpthesmithe.com
University of Michigan - Informatics (B. Sci. 2012)
General Purpose Programmer - Cooperative Institute for Limnology and Ecosystems Research (CILER) at NOAA-GLERL
Daniel_H's Avatar
Daniel_H Daniel_H is offline
FRC #1156 (Under Control)
Daniel_H is just really niceDaniel_H is just really niceDaniel_H is just really niceDaniel_H is just really nice
you have to use the Revolve tool in the 3D menu.
your sketch must be a half-circle with a line closing it, like this:
note: the line must pass the center of the circle otherwise it will not be a sphere
[<o>] gogogo [<o>]
http://undercontrol1156.com/
Unread 14-01-2006, 21:20
team222badbrad's Avatar
3D Printing Specialist
AKA: Bradley Rigdon
FRC #0222 (The Tigertrons)
OR...
You could extrude a 7'' cylinder
Then fillet both ends by 3.5''
Tigertrons are on Facebook!
http://www.printo3d.com
16th FIRST season for me.
Unread 14-01-2006, 21:22
Daniel_H's Avatar
Originally Posted by team222badbrad
OR...
hahah that's a creative one
[<o>] gogogo [<o>]
Unread 14-01-2006, 21:37
John Gutmann John Gutmann is offline
I'm right here
AKA: sparksandtabs
FRC #0340 (GRR)
John Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant future
Send a message via AIM to John Gutmann Send a message via MSN to John Gutmann Send a message via Yahoo to John Gutmann
After all that you should put a work plane going half way through the sphere. Then click split faces, use the work plane as the plane and click the face of the sphere for the face. Then you can right click on each half individually and color each one accordingly.
Unread 14-01-2006, 22:12
wilshire's Avatar
thanks guys
AIM: wilshire461
Purdue FIRST Teams
Unread 14-01-2006, 23:24
Ebolagirl's Avatar
Ebolagirl Ebolagirl is offline
I <3 Inventor!!!
AKA: Tracey
FRC #0418 (Purple Haze/LASA Robotics)
Ebolagirl has a spectacular aura aboutEbolagirl has a spectacular aura aboutEbolagirl has a spectacular aura about
Send a message via AIM to Ebolagirl
Hah, I just helped out a team member with the same exact thing. The way I make spheres in by making a line the diameter of the circle, then I make a semi-circle with the center point arc thing. Then I revolve. I think that's the easiest way to do it, or the way that requires the least number of steps.
"Show a girl how to use a wrench, and she'll put those skills to use for a lifetime. Hand it to her and tell her she's probably better off shopping, and she'll clonk you over the head with it, do your pneumatics system, and CAD the robot."
-Someone
My other passion... http://www.cdc.gov/ncidod/dvrd/spb/m...s/ebola/qa.htm
Isn't it adorable?
http://www.giantmicrobes.com/calamities/ebola.html
Inventor Help bjimster1 Inventor 9 14-01-2006 17:01
**FIRST EMAIL**/Autodesk Software Donation, Inventor Training and Awards Information Beth Sweet FIRST E-Mail Blast Archive 3 05-10-2005 23:34
Inventor 201 Whitepaper petek Inventor 0 10-05-2005 13:03
**FIRST EMAIL**/Autodesk Inventor Training and Technical Questions Information Rich Wong FIRST E-Mail Blast Archive 0 07-12-2004 17:22
Autodesk Inventor Award 2002 Digo Inventor 1 24-03-2002 12:07
